When connecting PCI/PCIe devices to I.MX7 evaluation board, devices do not work for multiple reasons.
We tried to connect multiple devices, such as Realtek RTL8723AE Wi-Fi (rtlwifi module, included in Linux kernel) and National Instruments GPIB (tnt4882 module), and each device didn't work for various reasons. the Wi-Fi Realtek RTL8723AE didn't work because of RF-Kill hardware block, the GPIB was registered but did not actually operate the GPIB.
Original Attachment has been moved to: imx_7pcimemoryerror.zip
Hello Danny,
According to your logs, we can confirm PCIe on CPU side is correct, it means CPU can found PCIe device on BUS, but at the time, RTL8723AE Wi-Fi can't still work normally, you need to add RTL8723AE's driver to linux kernel, then the WIFI should work.
you can use "netcfg" comand to check if the wlan can be listed, then use "iwconfig" to debug it.
Hope above information can help you!
Weidong
