Enable systemd-time-wait-sync.service in rootfs image
Search instead for
dvlogic
I have a service that requires time being set.  By googling around I found that the "systemd-time-wait-sync.service" is responsible for letting the system know when time is set.
I have a systemd service with the following unit requirements:
[Unit]
Description=My Service
After=network-online.target
After=time-sync.target
Wants=time-sync.target
I see that the systemd-time-wait-sync service is installed but its not enabled.  If I don't have systemd-time-wait-sync.service enabled, my service runs even if time is not set (and for that matter network isn't online).  However, if I manually enable the systemd-time-wait-sync.service, my service works and will not run until time is actually set, after we get the network online.
How do I make the systemd-time-wait-sync.service enabled at install time? (e.g. automatically create the symbolic link to the /etc/systemd/system/sysinit.target.wants?
Thanks.
dvlogic
Never mind, I figured it out.  I had to add a "Wants=systemd-time-wait-sync.service" to my service Unit settings.
b36401
Thanx for letting us know. I'm closing the case.
dvlogic
