Enable LPSPI2 for iMX8QUADMAX
771 次查看
kasandesh
Hello ALL,
What is the procedure to enable SPI2 in iMX8QUADMAX ?
It is seen from the device tree that lpspi0 is at address 5a000000 and also lpspi3 is at address 5a030000.
lpspi0 creates a flash device and lpspi3 creates a spidev.
I want to enable the SPI2 device and use it in master mode to connect to a sensor and measure a value.
Any leads on this would be appreciated.
Best Regards
687 次查看
Hi Sandesh
one can look at explanations provided on
Adding new spi module on IMX8 quad max with Yocto
