(Edit) How to change i.MX 8M Quad Evaluation Kit, Win10 iot display resolution?
1,316件の閲覧回数
alzip79
Hello. NXP
My Board : i.MX 8M Quad Evaluation Kit
My OS : windows 10 iot
Using MCIMX8M-EVK Image FFU File,
When connected to a monitor that supports 3840x2160 resolution using the native HDMI port, it displays at 1280x720 resolution.
How to change to 3840x2160 Display Resolution?
I found this document a while ago.
https://www.nxp.com/docs/en/release-note/IMXWNR.pdf
Will this problem be solved soon?
I want to solve this problem in a short time.
Do I need to use a package like i.MX8 or i.MX8M Plus to use 4K resolution?
Thank you for your help.
2 返答(返信)
1,165件の閲覧回数
vfilip
this is SW/BSP limitation. Switch to another 64-bit processor will not resolve this issue for you. I would recommend to follow the steps provided by Jiri Rezler in this thread: https://community.nxp.com/thread/524880
best regards
Vojtech Filip
1,165件の閲覧回数
Bio_TICFSL
Good!
