If one starts by downloading this version of poky/imx:
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-zeus -m imx-5.4.24-2.1.0.xml
The meta-imx repo had bad md5sums for the license.
The old license (V11) was:
228c72f2a91452b8a03c4cab30f30ef9 EULA.txt
The new license is:
1b4db4b25c3a1e422c0c0ed64feb65d2 EULA.txt
You can find the old license in the following recipes:
/meta-bsp/recipes-security/ml-security/ml-security_1.0.2.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-multimedia/imx-codec/imx-codec_4.5.5.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-multimedia/imx-sw-pdm/imx-sw-pdm_1.0.0.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-multimedia/imx-vpuwrap/imx-vpuwrap_4.5.5.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-multimedia/imx-parser/imx-parser_4.5.5.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-bsp/imx-seco/imx-seco-libs_git.bb:LIC_FILES_CHKSUM = "file://EULA.txt;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-bsp/imx-seco/imx-seco_3.6.3.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-bsp/imx-vpu-hantro-vc/imx-vpu-hantro-vc_1.1.0.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-bsp/imx-vpu/imx-vpu_5.4.39.3.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-bsp/imx-vpu-hantro/imx-vpu-hantro_1.18.0.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-bsp/firmware-imx/firmware-imx-8.8.inc:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-bsp/isp-imx/isp-imx_4.0.8.2.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-bsp/isp-imx/basler-camera_1.0.2.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/conf/layer.conf:FSL_EULA_FILE_MD5SUM_LA_OPT_NXP_SOFTWARE_LICENSE_V11 = "228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-graphics/imx-gpu-viv/imx-gpu-viv_6.4.0.p2.4-aarch64.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-graphics/imx-gpu-viv/imx-gpu-viv_6.4.0.p2.4-aarch32.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-graphics/imx-dpu-g2d/imx-dpu-g2d_1.8.7.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-bsp/recipes-graphics/imx-gpu-g2d/imx-gpu-g2d_6.4.0.p2.4.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-sdk/recipes-fsl/m4-demos/imx-m7-demos_2.8.0.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
./meta-sdk/recipes-fsl/m4-demos/imx-m4-demos_2.8.0.bb:LIC_FILES_CHKSUM = "file://COPYING;md5=228c72f2a91452b8a03c4cab30f30ef9"
For instance the firmware file build fails.
ERROR: firmware-imx-1_8.8-r0 do_populate_lic: QA Issue: firmware-imx: The LIC_FILES_CHKSUM does not match for file:///home/jenkins/workspace/mlinux/mtcap3-nxp/poky-build/sources/meta-imx/meta-bsp/../EULA.txt;md5=228c72f2a91452b8a03c4cab30f30ef9
firmware-imx: The new md5 checksum is 1b4db4b25c3a1e422c0c0ed64feb65d2
firmware-imx: Here is the selected license text:
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
LA_OPT_NXP_Software_License v13 June 2020
Solved! Go to Solution.
The problem was a local problem.
In the build script I copied over this file with local changes:
meta-imx/meta-bsp/conf/layer.conf.
This took out this update:
https://source.codeaurora.org/external/imx/meta-imx/patch/meta-bsp/conf/layer.conf?id=37201974dc8a35...
I should either write a patch for this file, or put my local changes elsewhere.
What change do you claim fixes this issue? I gave you the results of our automated nightly build, which retrieves source from scratch.
Build Configuration:
BB_VERSION = "1.44.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-18.04"
TARGET_SYS = "arm-poky-linux-gnueabi"
MACHINE = "imx6ull14x14evk"
DISTRO = "fsl-imx-fb"
DISTRO_VERSION = "5.4-zeus"
TUNE_FEATURES = "arm vfp cortexa7 neon thumb callconvention-hard"
TARGET_FPU = "hard"
meta
meta-poky = "HEAD:cba967414370e195d109353e51510bd829aa86c3"
meta-oe
meta-multimedia
meta-python = "HEAD:9e60d30669a2ad0598e9abf0cd15ee06b523986b"
meta-freescale = "HEAD:c2a0d924f6200eea1fb1d1b61e7420ea5da2f8fb"
meta-freescale-3rdparty = "HEAD:dbcc686f52c3c84db8cb86aa8973a4e373651b98"
meta-freescale-distro = "HEAD:ca27d12e4964d1336e662bcc60184bbff526c857"
meta-bsp
meta-sdk
meta-ml = "HEAD:2fe0ea17e86f040c5da48acf81c7e26ca4cd8ba9"
meta-browser = "HEAD:5f365ef0f842ba4651efe88787cf9c63bc8b6cb3"
meta-rust = "HEAD:a012a1027defe28495f06ed522a7a82bdd59a610"
meta-gnome
meta-networking
meta-filesystems = "HEAD:9e60d30669a2ad0598e9abf0cd15ee06b523986b"
meta-qt5 = "HEAD:b8bcf8cb576d072f435a0177375e54424f67d1c9"
meta-python2 = "HEAD:231c3d74cfcf734c3415e86ea8dd97f73ddced9d"
I still have an older build that worked. The following change broke the EULA for numerous builds:
This is the change that broke things (in meta-imx):
Author: Ann Thornton <ann.thornton@nxp.com>
Date: Tue Jun 16 09:35:36 2020 -0500
EULA.txt meta-bsp/conf/layer.conf: Update to v13
commit 0d1ae53326fd2d8c3cc50398e81fa1a96207c94f
Note that someone must have changed the XML for the release. In older builds of imx-5.4.24-2.1.0.xml, this change was not included.
When I started working on this imx project, last November the release was here:
commit a083ffbbc3f4d1c02b1542746784d7f641a75b60 (HEAD, m/imx-linux-zeus, CAF/zeus-5.4.24-2.1.0)
Author: Jun Zhu <junzhu@nxp.com>
Date: Tue Jul 7 19:56:54 2020 -0700
iso-codes: Set branch as main in SRC_URI to fix fetch issue
backport the patch from openembedded community
-- https://github.com/openembedded/openembedded-core/commit/6e16ef0c2e0ec2bbb862231cd84e7650bd5789af
Signed-off-by: Jun Zhu <junzhu@nxp.com>
New build:
commit 2fe0ea17e86f040c5da48acf81c7e26ca4cd8ba9 (HEAD, tag: rel_imx_5.4.24_2.1.0, m/imx-linux-zeus, CAF/zeus-5.4.24-2.1.0)
Author: Tom Hochstein <tom.hochstein@nxp.com>
Date: Sat Feb 13 13:29:19 2021 -0600
Hi JohnKlug
Please try to reinstall repo .
Zhiming
