Our application basically needs to transfer approx. 175 32bit words, ideally in one EIM burst. Is this possible and if so how? The docs mention EIM 'continuous burst length' (see snippets below) but with no helpful info. Our local Freescale FAEs don't know either. Does anyone?
Continuous burst length is used to read / write any (reasonable) amount of data
from / to an external device via the EIM by internal (i.MX6) masters, such as core caches
or SDMA, when a number of bytes may be application dependent, assuming the EIM in itself
does not split the access . In any case the access should be finished by the internal master.
As for continuous burst of 175 32-bit words, I am afraid, i.MX6 masters do not support it.
Yuri
Thanks Yuri,
Is there documentation with the details needed to design this capability into our application?
I am afraid, there are no app notes / examples how to use the
continuous burst mode.
Two mains ideas are behind this mode :
- burst length is not predefined ;
- wrap is not needed.
~Yuri.
