Does the uuu recipe emmc_all verify after programming?
997 次查看
dvlogic
We are using the uuu tool with the script emmc_all to program our custom i.MX8 boards.  I'm trying to understand if the programming is verified after writing to the eMMC memory.
I see the script is predominately using the FB (fast-boot) protocol to burn the image.
FB: ucmd setenv fastboot_dev mmc
FB: ucmd setenv mmcdev ${emmc_dev}
FB: ucmd mmc dev ${emmc_dev}
FB: flash -raw2sparse all _image
I'm not familiar enough with how that protocol works to know if it does both a programming and a verify step or just a programming step.
The reason I ask is we found a board, in our factory production, that failed the FVT test due to what appears as bad eMMC memory.  However, this board passed the programming station without fail.
Thanks. -- dave
962 次查看
Harvey021
Hi @dvlogic
By default, it is just a programming step. There is a command crc in new version.
Harvey
963 次查看
Harvey021
Hi @dvlogic
Harvey
926 次查看
dvlogic
@Harvey021 can you point me to any examples of doing a CRC verification on the programming?  I also assume the new version you refer to is 3.0 from here: https://github.com/nxp-imx/mfgtools?
Dave
916 次查看
Harvey021
I am not quite sure since which version. I had one on my host. the version is 1.5.11 (tag). Release 1.5.11 · nxp-imx/mfgtools · GitHub
You can use command "uuu -H" on your host with more details.
Harvey
