The iMX6 DQ Reference Manual doesn't say anything about it. With the information from chapter 13 that each AIPS supports up to 32 16-Kbyte peripherals plus 2 global peripheral spaces one can try guessing from the memory map given in chapter 2 but with no confidence. Anyway, the addresses for AIPS1 and AIPS2 given in the register map in chapter 13 are wrong. The correct ones can be found in the memory map in chapter 2.
解決済! 解決策の投稿を見る。
Hi all,
I got a response to my SR from Freescale, which more or less gave the answers. So I post here a version created by myself and as suggested to Freescale of those parts (Tables 2-2 and 2-3 in RM):
Start Address | End Address | Region | NIC Port | Size |
020FC000 | 020FFFFF | AIPS-1 (OPACR31) | Reserved | 16 KB |
020F8000 | 020FBFFF | AIPS-1 (OPACR30) | Reserved | 16 KB |
020F4000 | 020F7FFF | AIPS-1 (OPACR29) | Reserved | 16 KB |
020F0000 | 020F3FFF | AIPS-1 (OPACR28) | Reserved | 16 KB |
020EC000 | 020EFFFF | AIPS-1 (OPACR27) | SDMA | 16 KB |
020E8000 | 020EBFFF | AIPS-1 (OPACR26) | DCIC2 | 16 KB |
020E4000 | 020E7FFF | AIPS-1 (OPACR25) | DCIC1 | 16 KB |
020E0000 | 020E3FFF | AIPS-1 (OPACR24) | IOMUXC | 16 KB |
020DC2B0 | 020DFFFF | AIPS-1 (OPACR23) | Reserved | 15696 B |
020DC2A0 | 020DC2AF | PGC_CPU | 16 B | |
020DC270 | 020DC29F | Reserved | 48 B | |
020DC260 | 020DC26F | PGC_GPU | 16 B | |
020DC1C4 | 020DC25F | Reserved | 156 B | |
020DC180 | 020DC1C3 | DVFS | 68 B | |
020DC028 | 020DC17F | Reserved | 344 B | |
020DC000 | 020DC027 | GPC | 40 B | |
020D8000 | 020DBFFF | AIPS-1 (OPACR22) | SRC | 16 KB |
020D4000 | 020D7FFF | AIPS-1 (OPACR21) | EPIT2 | 16 KB |
020D0000 | 020D3FFF | AIPS-1 (OPACR20) | EPIT1 | 16 KB |
020CC000 | 020CFFFF | AIPS-1 (OPACR19) | SNVS_HP | 16 KB |
020CB000 | 020CBFFF | AIPS-1 (OPACR18) | Reserved | 4 KB |
020CA000 | 020CAFFF | USBPHY2 | 4 KB | |
020C9000 | 020C9FFF | USBPHY1 | 4 KB | |
020C8000 | 020C8FFF | CCM_ANALOG | 4 KB | |
020C4000 | 020C7FFF | AIPS-1 (OPACR17) | CCM_DIGITAL | 16 KB |
020C0000 | 020C3FFF | AIPS-1 (OPACR16) | WDOG2 | 16 KB |
020BC000 | 020BFFFF | AIPS-1 (OPACR15) | WDOG1 | 16 KB |
020B8000 | 020BBFFF | AIPS-1 (OPACR14) | KPP | 16 KB |
020B4000 | 020B7FFF | AIPS-1 (OPACR13) | GPIO7 | 16 KB |
020B0000 | 020B3FFF | AIPS-1 (OPACR12) | GPIO6 | 16 KB |
020AC000 | 020AFFFF | AIPS-1 (OPACR11) | GPIO5 | 16 KB |
020A8000 | 020ABFFF | AIPS-1 (OPACR10) | GPIO4 | 16 KB |
020A4000 | 020A7FFF | AIPS-1 (OPACR9) | GPIO3 | 16 KB |
020A0000 | 020A3FFF | AIPS-1 (OPACR8) | GPIO2 | 16 KB |
0209C000 | 0209FFFF | AIPS-1 (OPACR7) | GPIO1 | 16 KB |
02098000 | 0209BFFF | AIPS-1 (OPACR6) | GPT | 16 KB |
02094000 | 02097FFF | AIPS-1 (OPACR5) | CAN2 | 16 KB |
02090000 | 02093FFF | AIPS-1 (OPACR4) | CAN1 | 16 KB |
0208C000 | 0208FFFF | AIPS-1 (OPACR3) | PWM4 | 16 KB |
02088000 | 0208BFFF | AIPS-1 (OPACR2) | PWM3 | 16 KB |
02084000 | 02087FFF | AIPS-1 (OPACR1) | PWM2 | 16 KB |
02080000 | 02083FFF | AIPS-1 (OPACR0) | PWM1 | 16 KB |
0207C000 | 0207FFFF | AIPS-1 | AIPS1 | 16 KB |
02040000 | 0207BFFF | AIPS-2 Global Module Enable (OPACR33) | VPU | 240 KB |
0203C000 | 0203FFFF | AIPS-2 Global Module Enable (OPACR32) | SPBA | 16 KB |
02038000 | 0203BFFF | Reserved | 16 KB | |
02034000 | 02037FFF | ASRC | 16 KB | |
02030000 | 02033FFF | SSI3 | 16 KB | |
0202C000 | 0202FFFF | SSI2 | 16 KB | |
02028000 | 0202BFFF | SSI1 | 16 KB | |
02024000 | 02027FFF | ESAI | 16 KB | |
02020000 | 02023FFF | UART1 | 16 KB | |
0201C000 | 0201FFFF | Reserved | 16 KB | |
02018000 | 0201BFFF | eCSPI5 | 16 KB | |
02014000 | 02017FFF | eCSPI4 | 16 KB | |
02010000 | 02013FFF | eCSPI3 | 16 KB | |
0200C000 | 0200FFFF | eCSPI2 | 16 KB | |
02008000 | 0200BFFF | eCSPI1 | 16 KB | |
02004000 | 02007FFF | SPDIF | 16 KB | |
02000000 | 02003FFF | Reserved | 16 KB |
021FC000 | 021FFFFF | AIPS-2 (OPACR31) | Reserved | 16 KB |
021F8000 | 021FBFFF | AIPS-2 (OPACR30) | Reserved | 16 KB |
021F4000 | 021F7FFF | AIPS-2 (OPACR29) | UART5 | 16 KB |
021F0000 | 021F3FFF | AIPS-2 (OPACR28) | UART4 | 16 KB |
021EC000 | 021EFFFF | AIPS-2 (OPACR27) | UART3 | 16 KB |
021E8000 | 021EBFFF | AIPS-2 (OPACR26) | UART2 | 16 KB |
021E4000 | 021E7FFF | AIPS-2 (OPACR25) | VDOA | 16 KB |
021E0000 | 021E3FFF | AIPS-2 (OPACR24) | MIPI_DSI | 16 KB |
021DC000 | 021DFFFF | AIPS-2 (OPACR23) | MIPI_CSI | 16 KB |
021D8000 | 021DBFFF | AIPS-2 (OPACR22) | AUDMUX | 16 KB |
021D4000 | 021D7FFF | AIPS-2 (OPACR21) | TZASC2 | 16 KB |
021D0000 | 021D3FFF | AIPS-2 (OPACR20) | TZASC1 | 16 KB |
021CC000 | 021CFFFF | AIPS-2 (OPACR19) | Reserved | 16 KB |
021C8000 | 021CBFFF | AIPS-2 (OPACR18) | Reserved | 16 KB |
021C4000 | 021C7FFF | AIPS-2 (OPACR17) | Reserved | 16 KB |
021C0000 | 021C3FFF | AIPS-2 (OPACR16) | CSU | 16 KB |
021BC000 | 021BFFFF | AIPS-2 (OPACR15) | OCOTP_CTRL | 16 KB |
021B8000 | 021BBFFF | AIPS-2 (OPACR14) | EIM | 16 KB |
021B4000 | 021B7FFF | AIPS-2 (OPACR13) | MMDC1 | 16 KB |
021B0000 | 021B3FFF | AIPS-2 (OPACR12) | MMDC0 | 16 KB |
021AC000 | 021AFFFF | AIPS-2 (OPACR11) | ROMCP | 16 KB |
021A8000 | 021ABFFF | AIPS-2 (OPACR10) | I2C3 | 16 KB |
021A4000 | 021A7FFF | AIPS-2 (OPACR9) | I2C2 | 16 KB |
021A0000 | 021A3FFF | AIPS-2 (OPACR8) | I2C1 | 16 KB |
0219C000 | 0219FFFF | AIPS-2 (OPACR7) | uSDHC4 | 16 KB |
02198000 | 0219BFFF | AIPS-2 (OPACR6) | uSDHC3 | 16 KB |
02194000 | 02197FFF | AIPS-2 (OPACR5) | uSDHC2 | 16 KB |
02190000 | 02193FFF | AIPS-2 (OPACR4) | uSDHC1 | 16 KB |
0218C000 | 0218FFFF | AIPS-2 (OPACR3) | MLB150 | 16 KB |
02188000 | 0218BFFF | AIPS-2 (OPACR2) | ENET | 16 KB |
02184000 | 02187FFF | AIPS-2 (OPACR1) | USBOH3 | 16 KB |
02180000 | 02183FFF | AIPS-2 (OPACR0) | Reserved | 16 KB |
0217C000 | 0217FFFF | AIPS-2 | AIPS2 | 16 KB |
02161000 | 0217BFFF | AIPS-2 Global Module Enable (OPACR33) | Reserved | 108 KB |
02140000 | 02160FFF | ARM_MPCORE_DAP | 132 KB | |
02110000 | 0213FFFF | AIPS-2 Global Module Enable (OPACR32) | Reserved | 192 KB |
02100000 | 0210FFFF | CAAM | 64 KB |
Hi all,
Hi Frank
I've just stumbled upon the same question...
Did you get the mappings from Fresscale? If so, could you please post them here?
Thanks in advance and best regards,
-Urs
Hi Rob,
I did not yet get an answer from Frescale support. Otherwise I would of course have posted the mapping here to be available to the comunity. Anyway I started manually testing, which of the peripherals shows a reaction on changing the flags. It seamsthat the order of the peripherals (16K-blocks) in the memory map in chapter 2 matches the order of the OPACR registers. Currently I checked only the following peripherals:
PWM1 -> AIPSTZ1_OPACR.OPAC0
PWM2 -> AIPSTZ1_OPACR.OPAC1
GPIO1 -> AIPSTZ1_OPACR.OPAC7
GPIO2 -> AIPSTZ1_OPACR1.OPAC8
GPIO7 -> AIPSTZ1_OPACR1.OPAC13
CCM -> AIPSTZ1_OPACR2.OPAC17
IOMUXC -> AIPSTZ1_OPACR3.OPAC24
I further guess that AIPSTZ1_OPACR3.OPAC32 and AIPSTZ1_OPACR3.OPAC33 are the so called global module enables and map to all or at least multiple of those peripherals in the memory map in chapter 2, which are stated to be AIPS-1 Global Module Enable. The question here, which I can't answer yet, is: Do all those peripherals map to AIPSTZ1_OPACR3.OPAC32 or is there a split between AIPSTZ1_OPACR3.OPAC32 and AIPSTZ1_OPACR3.OPAC33? If there is no split, which peripheral(s) map to AIPSTZ1_OPACR3.OPAC33?
Another point is, that it seams that the AIPS itself, which is also a peripheral (16K-block), has no access control.
And one more point is, that the iMX6 implements another peripheral, the so called central security unit (CSU) which has very similar purpose and features. Some of the peripherals are access controlled by both, one AIPS and the CSU, others are access controlled by the CSU only. I'm not yet sure whether peripherals exist which are access controlled only by the AIPS and I even do not know the priority/dependency of the access permission between those two control facilities (AIPS and CSU).
Regards, Frank
Hi Frank
Thanks a lot for this insight, very interesting! For now I will leave accesses open, though... and come back to this mapping question later, once everything works.
-Urs or Rob, my middle name, as the first name is pretty unkown... :-)
Hi Frank
suggest to create SR to tech support, this table with peripherals
will be provided. Regarding " addresses for AIPS1 and AIPS2 given in the
register map in chapter 13 are wrong" - RM Chapter description is just generic description,
specific addresses one needs to look at chapter 2.
chip
Hi chipexpert,
thanks for your answer. I will create ans SR.
Regarding the address issue: Don't you assent that in a generic desription it would be better to give just the register offsets rather than absoulute addresses?
Regards, Frank
Hi Frank
I think yes
chip
