Distinguish between disconnect and suspend events on i.MX28 in USB Device mode
FredrikMoller
When the USB cable is removed from the i.MX28 EVK board, an interrupt is triggered. The HW_USBCTRL_USBSTS register in the USB controller block indicates that it is the SLI interrupt (DC Suspend). When a Suspend is received from host, the same interrupt is generated. How do I distinguish between these two kinds of events?
I'm not using Linux.
Tags (2)
igorpadykov
Hi Frederik
in device mode 5V is provided by host on usb connector,
this can be detected using sect.2.2.2.1 5-V detection methods AN4199
application note http://cache.freescale.com/files/32bit/doc/app_note/AN4199.pdf
FredrikMoller
Thanks for the reply.
However, that won't work for me as I get 5V from wall, meaning that 5V will always be detected whether USB cable is connected or not.
