Disable power key in Android 12.1 in imx8mp
664 次查看
dgeier315
I need to disable the power button function when our unit enters a certain state and enable it when it leaves that state.
Does Android have a function call for that(imx_snvs_pwrkey_pm_ops?), or do I need to disable the interrupt?
                snvs_pwrkey: snvs-powerkey {
                    compatible = "fsl,sec-v4.0-pwrkey";
                    regmap = <&snvs>;
                    interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
                    clocks = <&clk IMX8MP_CLK_SNVS_ROOT>;
                    clock-names = "snvs-pwrkey";
                    linux,keycode = <KEY_POWER>;
                    debounce-interval = <2000>;
                    wakeup-source;
                    status = "okay";
594 次查看
dgeier315
echo \"30370000.snvs:snvs-powerkey\" > /sys/bus/platform/drivers/snvs_pwrkey/bind
echo \"30370000.snvs:snvs-powerkey\" > /sys/bus/platform/drivers/snvs_pwrkey/unbind
These commands were able to disable the power button.
595 次查看
dgeier315
592 次查看
dgeier315
647 次查看
Alejandro_Salas
Hello @dgeier315
As you mentioned, disabling the IRQ can works, and re-enabling again. Take a look to the ICR1, ICR2 and IMR registers on Reference Manual.
Salas.
