Differences between iMX7 Sabre Rev B and Rev D
967 次查看
brianpaiva
I have an MCIMX7D-SABRE RevB (SCH-28590 Rev B), but the only schematic that I can find is for Rev D(SCH-28590 Rev D).  Are there any major differences between the two and is there a Rev B schematic available?  I'm trying to get support for SDR104 SD Cards, but can't get it to work in 1.8V mode.
789 次查看
jan_spurek
Hello Brian,
all changes should be listed on the first page of the board schematic.
Jan
789 次查看
brianpaiva
Based on what I read, am I right in assuming that for SD1 the only way to support SDR104 is to set it in the fuses?
789 次查看
Yuri
  NVCC_SD1 supply voltage is provided by the PMIC on the i.MX7 SABRE
design. This voltage is configured using SD_VSEL signal of the PMIC:
SD_VSEL is input from i.MX processor (GPIO1_IO08 on the SABRE) to select
VCC_SD regulator voltage. So, SD1 supply voltage is programmable.
   IMX7 GPIO1_IO08 default state is GPIO port, input, pulled down, therefore
just after reset NVCC_SD1 is 3 V. Customers cannot change it for SD1 boot,
but can modify the voltage after boot in OS.
Yuri
