Difference uboot-fslc <-> uboot-imx ?
2,815件の閲覧回数
woutervh
What's the difference between uboot-fslc and uboot-imx?
I'm trying to build an image based on yocto community-bsp. I see this one takes uboot-fslc per default. But I keep on getting -74 nand read errors with this version (old AND new versions). When I switch to a uboot-imx version, I have no problems at all, not with old, nor with newer versions.
So what's the difference? Are they not kept in sync? What can be the problem? What version to prefer?
ラベル(4)
3 返答(返信)
2,151件の閲覧回数
Hi Wouter
difference is explained on
https://community.freescale.com/message/402940#402940
support for third party boards is described on
FSL Community BSP Release Notes 2.2 documentation
2,151件の閲覧回数
angelo_d
Senior Contributor I
Hello Igor,
i am interested in your above thread, but links are now broken. Could you kindly provide working links ? thanks !
