Default disabled the lockscreen problem in android 4.4.2 system
1,061 次查看
mrleo
Hi all,
I found a problem in android 4.4.2 system on my custom imx6dl board.
When boot the system,I want to default disable the lockscreen.
I modify the code in path android_4.4/frameworks/base/packages/Keyguard/src/com/android/keyguard/KeyguardViewMediator.java
below is the modifed code. Change mExternallyEnabled to false.
     * External apps (like the phone app) can tell us to disable the keygaurd.
    private boolean mExternallyEnabled = false;//true
Then build the android system code.
After burn the new system imge to the board.
First boot the system the virtcul key recent key is can view,google browser app can open ok.
But reboot the system,or second boot the system, virtcul key recent key is disappear,home key is all not work ok, browser app can not open ok.
Open google  browser can found below errors:
--------- beginning of /dev/log/main
I/ActivityManager( 2578): Start proc com.android.browser for activity com.android.browser/.BrowserActivity: pid=3037 uid=10017 gids={50017, 3003, 1028, 1015, 1023}
E/ActivityThread( 3037): Failed to find provider info for com.google.settings
W/InputMethodManagerService( 2578): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@41caac50 attribute=null, token = android.os.BinderProxy@41da1578
Is this the freescale imx6 android 4.4.2_1.0.0-ga bsp BUG???
Have some one met this issues?
Please give me a help to solve this issues.
Leo
797 次查看
mrleo
HI,all
I have solved this issue!
Leo
797 次查看
conteczxy
Hi Leo,
How did you fix the problem, could you give your solution here?
I met the same problem as you, and my friend met it too, we are confused by it.
798 次查看
mrleo
HI,all
Leo
