Hi all
I'm developing a board with i.MX6SoloLite and I have a question about start-up sequence.
I want to know a copy mechanism to SDRAM from boot device such as SD card etc.
During start-up sequence, U-boot that is got from boot device will be copied to SDRAM.
However, I think that their file formats are different.
How it can be copied ?
Is there any description about the copy mechanism ?
ko-hey
Solved! Go to Solution.
The system boot up sequence is as following :
So, for proper boot the U-boot image should contain the IVT and DCD.
Yuri
Yuri
Hi Yuri
Thank you for your reply.
I'll share your answer to my team and if I have additional question, I'll ask you.
Ko-hey
