Controlling PFUZE100 VGEN in Linux
1,120 次查看
erezsteinberg
Hello experts,
I have some components that are powered by the VGEN LDOs in PFUZE0100
Currently I enable them in U-Boot, but I need to have control over them during runtime in Linux.
I tried regulator_get("vgen1") or regulator_get("PFUZE100_VGEN1"), but both fail.
How can I get control these?
Erez
标签 (2)
标记 (3)
654 次查看
igorpadykov
mx6q_sabresd_pmic_pfuze100.c:
static struct regulator_consumer_supply vgen1_consumers[] = {
    .supply = "VGEN1_1V5",
4 回复数
654 次查看
igorpadykov
Hi Erez
I think you can look at cpu_vdd3p0 example :
arch/arm/mach-mx6/mx6_anatop_regulator.c:
/* USB phy 3P0 */
static struct regulator_consumer_supply vdd3p0_consumers[] = {
        .supply = "cpu_vdd3p0",
pm.c  pm_init( )  :
vdd3p0_regulator = regulator_get(NULL, "cpu_vdd3p0");
    if (IS_ERR(vdd3p0_regulator)) {
   printk(KERN_ERR "%s: failed to get 3p0 regulator Err: %d\n",
   __func__, ret);
   return PTR_ERR(vdd3p0_regulator);
    ret = regulator_set_voltage(vdd3p0_regulator, VDD3P0_VOLTAGE,
   VDD3P0_VOLTAGE);
    if (ret) {
   printk(KERN_ERR "%s: failed to set 3p0 regulator voltage Err: %d\n",
   __func__, ret);
    ret = regulator_enable(vdd3p0_regulator);
    if (ret) {
   printk(KERN_ERR "%s: failed to enable 3p0 regulator Err: %d\n",
   __func__, ret);
654 次查看
erezsteinberg
Yes, this is what I'm trying to do --
But.. what is the name for the PFUZE VGEN regulators?
regulator_get(NULL, "?????????");
655 次查看
igorpadykov
654 次查看
erezsteinberg
Thanks --- that worked!
