Close cameras error when use max9286 cameras on imx8qm Android P OS
次の代わりに検索
4,193件の閲覧回数
jack-cap
hi nxp ,
I found some errors when closing cameras that is openned at the same time on imx8qm platform with Android P OS. Please help me analysis  to resolve ,Thanks a lot for your reply.
The error log as follw:
--------- beginning of main
02-22 03:47:55.943 I/SELinux ( 3160): SELinux: Loaded service_contexts from:
02-22 03:47:55.943 I/SELinux ( 3160):     /vendor/etc/selinux/vndservice_contexts
02-22 03:47:55.958 I/SELinux ( 3158): SELinux: Loaded service_contexts from:
02-22 03:47:55.959 I/SELinux ( 3158):     /system/etc/selinux/plat_service_contexts
02-22 03:47:44.978 W/auditd  ( 3157): type=2000 audit(0.0:1): state=initialized audit_enabled=0 res=1
02-22 03:47:53.988 I/auditd  ( 3157): type=1403 audit(0.0:2): policy loaded auid=4294967295 ses=4294967295
02-22 03:47:54.008 W/auditd  ( 3157): type=1404 audit(0.0:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
02-22 03:47:54.216 W/init    (    1): type=1400 audit(0.0:4): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:54.220 I/chatty  (    1): uid=0(root) /init identical 4 lines
02-22 03:47:54.220 W/init    (    1): type=1400 audit(0.0:9): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:54.220 W/init    (    1): type=1400 audit(0.0:10): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:54.220 W/init    (    1): type=1400 audit(0.0:11): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:55.984 W/init    ( 2537): type=1400 audit(0.0:38): avc: denied { getattr } for path="/data/cache" dev="mmcblk0p12" ino=131094 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
02-22 03:47:55.984 W/init    (    1): type=1400 audit(0.0:39): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:55.988 I/chatty  (    1): uid=0(root) /init identical 4 lines
02-22 03:47:55.988 W/init    (    1): type=1400 audit(0.0:44): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:55.988 W/init    (    1): type=1400 audit(0.0:45): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:55.988 W/init    (    1): type=1400 audit(0.0:46): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:55.990 I/hwservicemanager( 3159): hwservicemanager is ready now.
02-22 03:47:56.051 I/ServiceManagement( 3168): Removing namespace from process name android.hardware.boot@1.0-service to boot@1.0-service.
02-22 03:47:56.052 I/android.hardware.boot@1.0-service( 3168): Registration complete for android.hardware.boot@1.0::IBootControl/default.
02-22 03:47:56.067 I/android.hardware.keymaster@3.0-impl( 3169): Fetching keymaster device name default
02-22 03:47:56.067 I/android.hardware.keymaster@3.0-impl( 3169): Could not find any keystore module, using software-only implementation.
02-22 03:47:56.068 I/ServiceManagement( 3169): Removing namespace from process name android.hardware.keymaster@3.0-service to keymaster@3.0-service.
02-22 03:47:56.069 I/android.hardware.keymaster@3.0-service( 3169): Registration complete for android.hardware.keymaster@3.0::IKeymasterDevice/default.
--------- beginning of system
02-22 03:47:56.105 I/vold    ( 3170): Vold 3.0 (the awakening) firing up
02-22 03:47:56.106 V/vold    ( 3170): Detected support for: ext4 vfat
02-22 03:47:56.110 V/vold    ( 3170): Found unmanaged dm device named vroot
02-22 03:47:56.110 V/vold    ( 3170): Found unmanaged dm device named vendor
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop3: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop1: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop0: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop4: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop5: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop7: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop2: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop6: No such device or address
02-22 03:47:56.113 D/vold    ( 3170): VoldNativeService::start() completed OK
02-22 03:47:56.120 I/vold    ( 3170): e4crypt_initialize_global_de
02-22 03:47:56.126 D/vold    ( 3170): Key exists, using: /data/unencrypted/key
02-22 03:47:56.131 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.keymaster@4.0::IKeymasterDevice/default in either framework or device manifest.
02-22 03:47:56.132 I/vold    ( 3170): List of Keymaster HALs found:
02-22 03:47:56.133 I/vold    ( 3170): Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:47:56.133 I/vold    ( 3170): Using SoftwareKeymasterDevice from Google for encryption.  Security level: SOFTWARE, HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:47:56.139 D/vold    ( 3170): Added key 247563587 (ext4:0bfa77f9264d39c3) to keyring 625017044 in process 3170
02-22 03:47:56.139 D/vold    ( 3170): Added key 368405187 (f2fs:0bfa77f9264d39c3) to keyring 625017044 in process 3170
02-22 03:47:56.140 D/vold    ( 3170): Added key 895425416 (fscrypt:0bfa77f9264d39c3) to keyring 625017044 in process 3170
02-22 03:47:56.141 I/vold    ( 3170): Wrote system DE key reference to:/data/unencrypted/ref
02-22 03:47:56.219 D/vold    ( 3170): e4crypt_init_user0
02-22 03:47:56.219 D/vold    ( 3170): Preparing: /data/misc/vold/user_keys
02-22 03:47:56.220 D/vold    ( 3170): Preparing: /data/misc/vold/user_keys/ce
02-22 03:47:56.220 D/vold    ( 3170): Preparing: /data/misc/vold/user_keys/de
02-22 03:47:56.221 D/vold    ( 3170): Skipping non-de-key ..
02-22 03:47:56.224 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.keymaster@4.0::IKeymasterDevice/default in either framework or device manifest.
02-22 03:47:56.226 I/vold    ( 3170): List of Keymaster HALs found:
02-22 03:47:56.226 I/vold    ( 3170): Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:47:56.226 I/vold    ( 3170): Using SoftwareKeymasterDevice from Google for encryption.  Security level: SOFTWARE, HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:47:56.227 D/vold    ( 3170): Added key 195702228 (ext4:24f6ce487e658803) to keyring 625017044 in process 3170
02-22 03:47:56.227 D/vold    ( 3170): Added key 1034099187 (f2fs:24f6ce487e658803) to keyring 625017044 in process 3170
02-22 03:47:56.227 D/vold    ( 3170): Added key 422420984 (fscrypt:24f6ce487e658803) to keyring 625017044 in process 3170
02-22 03:47:56.227 D/vold    ( 3170): Installed de key for user 0
02-22 03:47:56.227 D/vold    ( 3170): Skipping non-de-key .
02-22 03:47:56.227 D/vold    ( 3170): e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 1
02-22 03:47:56.227 D/vold    ( 3170): Preparing: /data/system/users/0
02-22 03:47:56.228 D/vold    ( 3170): Preparing: /data/misc/profiles/cur/0
02-22 03:47:56.228 D/vold    ( 3170): Preparing: /data/system_de/0
02-22 03:47:56.228 D/vold    ( 3170): Preparing: /data/misc_de/0
02-22 03:47:56.229 D/vold    ( 3170): Preparing: /data/vendor_de/0
02-22 03:47:56.229 D/vold    ( 3170): Preparing: /data/user_de/0
02-22 03:47:56.230 I/vold    ( 3170): Found policy 24f6ce487e658803 at /data/system_de/0 which matches expected value
02-22 03:47:56.230 I/vold    ( 3170): Found policy 24f6ce487e658803 at /data/misc_de/0 which matches expected value
02-22 03:47:56.231 I/vold    ( 3170): Found policy 24f6ce487e658803 at /data/vendor_de/0 which matches expected value
02-22 03:47:56.232 I/vold    ( 3170): Found policy 24f6ce487e658803 at /data/user_de/0 which matches expected value
02-22 03:47:56.232 V/vold    ( 3170): /system/bin/vold_prepare_subdirs
02-22 03:47:56.232 V/vold    ( 3170):     prepare
02-22 03:47:56.232 V/vold    ( 3170):     0
02-22 03:47:56.232 V/vold    ( 3170):     1
02-22 03:47:56.258 I/vold_prepare_subdirs( 3170): SELinux: Loaded file_contexts
02-22 03:47:56.261 D/vold_prepare_subdirs( 3214): Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_de/0/vold
02-22 03:47:56.261 D/vold_prepare_subdirs( 3214): Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_de/0/storaged
02-22 03:47:56.262 D/vold_prepare_subdirs( 3214): Setting up mode 700 uid 1000 gid 1000 context u:object_r:fingerprint_vendor_data_file:s0 on path: /data/vendor_de/0/fpdata
02-22 03:47:56.282 I//system/bin/tzdatacheck( 3216): timezone distro dir /data/misc/zoneinfo/current does not exist. No action required.
02-22 03:47:56.470 I/android.hardware.wifi@1.0-service( 3224): Wifi Hal is booting up...
02-22 03:47:56.471 I/ServiceManagement( 3224): Removing namespace from process name android.hardware.wifi@1.0-service to wifi@1.0-service.
02-22 03:47:56.482 I/Netd    ( 3219): Netd 1.0 starting
02-22 03:47:56.487 D/TetherController( 3219): Setting IP forward enable = 0
02-22 03:47:56.513 I/ServiceManagement( 3229): Removing namespace from process name android.hidl.allocator@1.0-service to allocator@1.0-service.
02-22 03:47:56.517 I/ServiceManagement( 3232): Removing namespace from process name android.hardware.bluetooth@1.0-service to bluetooth@1.0-service.
02-22 03:47:56.517 I/health@2.0/( 3230): health@2.0/backup: Hal starting main loop...
02-22 03:47:56.517 I/health@2.0/( 3230): health@2.0/backup Hal is starting up...
02-22 03:47:56.518 I/android.hardware.bluetooth@1.0-service( 3232): Registration complete for android.hardware.bluetooth@1.0::IBluetoothHci/default.
02-22 03:47:56.521 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.health@1.0::IHealth/default in either framework or device manifest.
02-22 03:47:56.526 I/health@2.0/( 3230): health@2.0/backup: Hal init done
02-22 03:47:56.555 I/Netd    ( 3219): Creating child chains: 53.1ms
02-22 03:47:56.555 I/Netd    ( 3219): Setting up OEM hooks: 0.1ms
02-22 03:47:56.555 I/Netd    ( 3219): Setting up FirewallController hooks: 0.0ms
02-22 03:47:56.557 I/Netd    ( 3219): Setting up TetherController hooks: 1.4ms
02-22 03:47:56.558 I/Netd    ( 3219): Setting up BandwidthController hooks: 1.7ms
02-22 03:47:56.559 I/Netd    ( 3219): Setting up IdletimerController hooks: 0.1ms
02-22 03:47:56.650 I/ServiceManagement( 3246): Removing namespace from process name android.hardware.power@1.0-service to power@1.0-service.
02-22 03:47:56.652 I/android.hardware.power@1.0-service( 3246): Registration complete for android.hardware.power@1.0::IPower/default.
02-22 03:47:56.653 I/ServiceManagement( 3240): Removing namespace from process name android.hardware.gatekeeper@1.0-service to gatekeeper@1.0-service.
02-22 03:47:56.655 I/android.hardware.gatekeeper@1.0-service( 3240): Registration complete for android.hardware.gatekeeper@1.0::IGatekeeper/default.
02-22 03:47:56.666 I/installd( 3263): installd firing up
02-22 03:47:56.693 I/health@2.0/( 3243): health@2.0/default: Hal starting main loop...
02-22 03:47:56.693 I/health@2.0/( 3243): health@2.0/default Hal is starting up...
02-22 03:47:56.695 I/ServiceManagement( 3243): Removing namespace from process name android.hardware.health@2.0-service.imx to health@2.0-service.imx.
02-22 03:47:56.696 I/health@2.0/( 3243): health@2.0/default: Hal init done
02-22 03:47:56.715 E/        ( 3247): couldn't find 'FSL_SENS_HUB' input device
02-22 03:47:56.715 I//system/bin/tombstoned( 3274): tombstoned successfully initialized
02-22 03:47:56.716 I/ServiceManagement( 3248): Removing namespace from process name android.hardware.usb@1.1-service.imx to usb@1.1-service.imx.
02-22 03:47:56.727 D/android.hardware.drm@1.0-service( 3237): android.hardware.drm@1.0-service starting...
02-22 03:47:56.736 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: allowing syscall: connect
02-22 03:47:56.736 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: allowing syscall: fcntl
02-22 03:47:56.736 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: allowing syscall: sendto
02-22 03:47:56.736 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: allowing syscall: socket
02-22 03:47:56.736 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: allowing syscall: writev
02-22 03:47:56.740 I/android.hardware.usb@1.1-service.imx( 3248): USB HAL Ready.
02-22 03:47:56.747 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: logging seccomp filter failures
02-22 03:47:56.747 I/ServiceManagement( 3235): Removing namespace from process name android.hardware.configstore@1.1-service to configstore@1.1-service.
02-22 03:47:56.757 D/android.hardware.cas@1.0-service( 3234): android.hardware.cas@1.0-service starting...
02-22 03:47:56.758 I/ServiceManagement( 3234): Removing namespace from process name android.hardware.cas@1.0-service to cas@1.0-service.
02-22 03:47:56.759 I/usbd    ( 3276): Usb HAL found.
02-22 03:47:56.759 I/usbd    ( 3276): peristent prop is adb
02-22 03:47:56.762 I/Netd    ( 3219): initializing traffic control: 203.1ms
02-22 03:47:56.762 I/android.hardware.usb.gadget@1.0-service.imx( 3248): setCurrentUsbFunctions None
02-22 03:47:56.762 I/android.hardware.usb.gadget@1.0-service.imx( 3248): Gadget cannot be pulled down
02-22 03:47:56.765 W/hw-IPCThreadState( 3276): Calling IPCThreadState::self() during shutdown is dangerous, expect a crash.
--------- beginning of crash
02-22 03:47:56.765 F/libc    ( 3276): Fatal signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x178 in tid 3282 (HwBinder:3276_1), pid 3276 (usbd)
02-22 03:47:56.770 I/Netd    ( 3219): Disabling bandwidth control: 8.7ms
02-22 03:47:56.772 E/Netd    ( 3219): cannot find interface dummy0
02-22 03:47:56.772 I/Netd    ( 3219): Initializing RouteController: 1.9ms
02-22 03:47:56.773 D/XfrmController( 3219): Sending Netlink XFRM Message: XFRM_MSG_FLUSHSA
02-22 03:47:56.773 D/XfrmController( 3219): Sending Netlink XFRM Message: XFRM_MSG_FLUSHPOLICY
02-22 03:47:56.773 I/Netd    ( 3219): Initializing XfrmController: 0.7ms
02-22 03:47:56.774 E/Netd    ( 3219): Unable to create netlink socket: Protocol not supported
02-22 03:47:56.774 W/Netd    ( 3219): Unable to open qlog quota socket, check if xt_quota2 can send via UeventHandler
02-22 03:47:56.775 D/MDnsDS  ( 3219): MDnsSdListener::Hander starting up
02-22 03:47:56.777 I/Netd    ( 3219): Registering NetdNativeService: 2.1ms
02-22 03:47:56.778 I/Netd    ( 3219): Starting CommandListener: 0.3ms
02-22 03:47:56.778 E/lights  ( 3244): cannot open backlight file /sys/class/backlight/56228000.mipi_dsi_bridge.0/max_brightness
02-22 03:47:56.778 E/light   ( 3244): light_open lights backlight failed: -22
02-22 03:47:56.778 E/light   ( 3244): Light passthrough failed to load legacy HAL.
02-22 03:47:56.779 E/light   ( 3244): light_open lights keyboard failed: -22
02-22 03:47:56.779 E/light   ( 3244): Light passthrough failed to load legacy HAL.
02-22 03:47:56.779 W/libc    ( 3248): Unable to set property "sys.usb.ffs.ready" to "0": error code: 0x18
02-22 03:47:56.779 E/light   ( 3244): light_open lights buttons failed: -22
02-22 03:47:56.779 E/light   ( 3244): light_open lights battery failed: -22
02-22 03:47:56.779 I/android.hardware.usb.gadget@1.0-service.imx( 3248): mMonitor not running
02-22 03:47:56.780 E/light   ( 3244): light_open lights notifications failed: -22
02-22 03:47:56.780 E/light   ( 3244): Light passthrough failed to load legacy HAL.
02-22 03:47:56.780 E/light   ( 3244): light_open lights attention failed: -22
02-22 03:47:56.780 D/MDnsDS  ( 3219): MDnsSdListener starting to monitor
02-22 03:47:56.780 D/MDnsDS  ( 3219): Going to poll with pollCount 1
02-22 03:47:56.787 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.thermal@1.1::IThermal/default in either framework or device manifest.
02-22 03:47:56.788 I/ServiceManagement( 3245): Removing namespace from process name android.hardware.memtrack@1.0-service to memtrack@1.0-service.
02-22 03:47:56.788 W/thermalserviced( 3251): Unable to get Thermal HAL V1.1, vendor thermal event notification not available
02-22 03:47:56.789 I/android.hardware.memtrack@1.0-service( 3245): Registration complete for android.hardware.memtrack@1.0::IMemtrack/default.
02-22 03:47:56.789 I/Netd    ( 3219): Registering NetdHwService: 11.0ms
02-22 03:47:56.789 I/Netd    ( 3219): Netd started in 307ms
02-22 03:47:56.794 E/light   ( 3244): light_open lights bluetooth failed: -22
02-22 03:47:56.794 E/light   ( 3244): Light passthrough failed to load legacy HAL.
02-22 03:47:56.795 E/light   ( 3244): light_open lights wifi failed: -22
02-22 03:47:56.795 E/light   ( 3244): Light passthrough failed to load legacy HAL.
02-22 03:47:56.795 I/light   ( 3244): Could not open any lights.
02-22 03:47:56.795 W/statsd  ( 3267): statscompanion service unavailable!
02-22 03:47:56.796 I/ServiceManagement( 3244): Removing namespace from process name android.hardware.light@2.0-service to light@2.0-service.
02-22 03:47:56.797 I/statsd  ( 3267): using statsd socket
02-22 03:47:56.797 I/android.hardware.light@2.0-service( 3244): Registration complete for android.hardware.light@2.0::ILight/default.
02-22 03:47:56.804 I/gatekeeperd( 3272): Starting gatekeeperd...
02-22 03:47:56.808 I/ServiceManagement( 3241): Removing namespace from process name android.hardware.graphics.allocator@2.0-service to allocator@2.0-service.
02-22 03:47:56.817 I/android.hardware.graphics.allocator@2.0-service( 3241): Registration complete for android.hardware.graphics.allocator@2.0::IAllocator/default.
02-22 03:47:56.823 I/android.hardware.camera.provider@2.4-service( 3233): Camera provider Service is starting.
02-22 03:47:56.838 I/ServiceManagement( 3237): Removing namespace from process name android.hardware.drm@1.0-service to drm@1.0-service.
02-22 03:47:56.839 E/DEBUG   ( 3303): failed to open directory /proc/3282/fd: No such file or directory
02-22 03:47:56.839 E/crash_dump64( 3303): failed to open /proc/3282: No such file or directory
02-22 03:47:56.839 F/crash_dump64( 3303): crash_dump.cpp:398] failed to get process threads: No such file or directory
02-22 03:47:56.839 I/android.hardware.drm@1.0-service( 3237): Registration complete for android.hardware.drm@1.0::IDrmFactory/default.
02-22 03:47:56.840 I//system/bin/tombstoned( 3274): received crash request for pid 3282
02-22 03:47:56.841 I/ServiceManagement( 3237): Removing namespace from process name android.hardware.drm@1.0-service to drm@1.0-service.
02-22 03:47:56.843 I/wificond( 3269): wificond is starting up...
02-22 03:47:56.844 W//system/bin/tombstoned( 3274): crash socket received short read of length 0 (expected 12)
02-22 03:47:56.848 I/android.hardware.drm@1.0-service( 3237): Registration complete for android.hardware.drm@1.0::ICryptoFactory/default.
02-22 03:47:56.854 I/mediaserver( 3253): ServiceManager: 0xfee8eba3d480
02-22 03:47:56.871 I/hwcomposer( 3242): hwc_device_open,1239
02-22 03:47:56.875 I/ServiceManagement( 3242): Removing namespace from process name android.hardware.graphics.composer@2.1-service to composer@2.1-service.
02-22 03:47:56.880 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.883 I/ServiceManagement( 3231): Removing namespace from process name android.hardware.audio@2.0-service to audio@2.0-service.
02-22 03:47:56.884 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.887 I/audiohalservice( 3231): Registration complete for android.hardware.audio@4.0::IDevicesFactory/default.
02-22 03:47:56.888 I/android.hardware.graphics.composer@2.1-service( 3242): Registration complete for android.hardware.graphics.composer@2.1::IComposer/default.
02-22 03:47:56.897 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.keymaster@4.0::IKeymasterDevice/default in either framework or device manifest.
02-22 03:47:56.900 I/keystore( 3264): found android.hardware.keymaster@3.0::IKeymasterDevice with interface name default and seclevel SOFTWARE
02-22 03:47:56.900 W/keystore( 3264): No secure Keymaster implementation found, but device offers insecure Keymaster HAL. Using as default.
02-22 03:47:56.904 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.925 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.934 I/audiohalservice( 3231): Registration complete for android.hardware.audio.effect@4.0::IEffectsFactory/default.
02-22 03:47:56.934 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.soundtrigger@2.1::ISoundTriggerHw/default in either framework or device manifest.
02-22 03:47:56.937 I/adbd    ( 3308): initializing functionfs
02-22 03:47:56.938 I/adbd    ( 3308): opening control endpoint /dev/usb-ffs/adb/ep0
02-22 03:47:56.939 E/audiohalservice( 3231): Could not get passthrough implementation for android.hardware.soundtrigger@2.1::ISoundTriggerHw/default.
02-22 03:47:56.939 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.soundtrigger@2.0::ISoundTriggerHw/default in either framework or device manifest.
02-22 03:47:56.940 E/audiohalservice( 3231): Could not get passthrough implementation for android.hardware.soundtrigger@2.0::ISoundTriggerHw/default.
02-22 03:47:56.940 W/audiohalservice( 3231): Could not register soundtrigger API 2.0 nor 2.1
02-22 03:47:56.940 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.bluetooth.a2dp@1.0::IBluetoothAudioOffload/default in either framework or device manifest.
02-22 03:47:56.940 E/audiohalservice( 3231): Could not get passthrough implementation for android.hardware.bluetooth.a2dp@1.0::IBluetoothAudioOffload/default.
02-22 03:47:56.940 W/audiohalservice( 3231): Could not register Bluetooth audio offload 1.0
02-22 03:47:56.945 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.955 I/adbd    ( 3308): functionfs successfully initialized
02-22 03:47:56.955 I/adbd    ( 3308): registering usb transport
02-22 03:47:56.964 I/update_engine( 3275): [0222/034756.963862:INFO:main.cc(182)] Chrome OS Update Engine starting
02-22 03:47:56.966 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.968 I/update_engine( 3275): [0222/034756.968109:INFO:boot_control_android.cc(64)] Loaded boot control hidl hal.
02-22 03:47:56.968 I/update_engine( 3275): [0222/034756.968232:INFO:daemon_state_android.cc(43)] Booted in dev mode.
02-22 03:47:56.986 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.004 W/usb@1.1-service( 3248): type=1400 audit(0.0:558): avc: denied { read } for name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=11475 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
02-22 03:47:57.007 I/chatty  ( 3248): uid=0(root) usb@1.1-service identical 1 line
02-22 03:47:57.024 I/chatty  ( 3248): uid=0(root) usb@1.1-service identical 1 line
02-22 03:47:57.030 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.030 I/mediametrics( 3266): ServiceManager: 0xf87f5b83d740
02-22 03:47:57.030 D/MediaAnalyticsService( 3266): MediaAnalyticsService created
02-22 03:47:57.048 W/usb@1.1-service( 3248): type=1400 audit(0.0:560): avc: denied { read } for name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=11475 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
02-22 03:47:57.050 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.068 W/usb@1.1-service( 3248): type=1400 audit(0.0:561): avc: denied { read } for name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=11475 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
02-22 03:47:57.071 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.071 I/FslCameraHAL( 3233): enumSensorSet
02-22 03:47:57.072 I/FslCameraHAL( 3233): matchDevNodes
02-22 03:47:57.072 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video5
02-22 03:47:57.072 W/FslCameraHAL( 3233): getNodeName dev path:/dev/video5 is not capture
02-22 03:47:57.072 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video3
02-22 03:47:57.073 I/FslCameraHAL( 3233): getNodeName: node name:mxc-isi
02-22 03:47:57.073 I/FslCameraHAL( 3233): getNodeNames: node name:mxc-isi,imx8_max9286_mipi_3
02-22 03:47:57.082 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video13
02-22 03:47:57.088 W/usb@1.1-service( 3248): type=1400 audit(0.0:562): avc: denied { read } for name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=11475 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
02-22 03:47:57.091 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.110 I/FslCameraHAL( 3233): getNodeName: node name:vpu encoder
02-22 03:47:57.110 I/FslCameraHAL( 3233): getNodeName CHIP_IDENT dev path:/dev/video13 failed
02-22 03:47:57.110 I/FslCameraHAL( 3233): getNodeNames: node name:vpu encoder,vpu encoder
02-22 03:47:57.111 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.118 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video1
02-22 03:47:57.119 I/FslCameraHAL( 3233): getNodeName: node name:mxc-isi
02-22 03:47:57.119 I/FslCameraHAL( 3233): getNodeNames: node name:mxc-isi,imx8_max9286_mipi_1
02-22 03:47:57.126 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video6
02-22 03:47:57.126 W/FslCameraHAL( 3233): getNodeName dev path:/dev/video6 is not capture
02-22 03:47:57.126 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video4
02-22 03:47:57.132 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.134 I/FslCameraHAL( 3233): getNodeName: node name:mxc-isi
02-22 03:47:57.134 I/FslCameraHAL( 3233): getNodeName CHIP_IDENT dev path:/dev/video4 failed
02-22 03:47:57.134 I/FslCameraHAL( 3233): getNodeNames: node name:mxc-isi,mxc-isi
02-22 03:47:57.142 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video2
02-22 03:47:57.142 I/FslCameraHAL( 3233): getNodeName: node name:mxc-isi
02-22 03:47:57.142 I/FslCameraHAL( 3233): getNodeNames: node name:mxc-isi,imx8_max9286_mipi_2
02-22 03:47:57.150 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video12
02-22 03:47:57.152 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.168 D/AndroidRuntime( 3220): >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
02-22 03:47:57.172 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.184 W/FslCameraHAL( 3233): getNodeName dev path:/dev/video12 is not capture
02-22 03:47:57.184 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video0
02-22 03:47:57.185 I/FslCameraHAL( 3233): getNodeName: node name:mxc-isi
02-22 03:47:57.185 I/FslCameraHAL( 3233): getNodeNames: node name:mxc-isi,imx8_max9286_mipi_0
02-22 03:47:57.191 V/MediaUtils( 3265): physMem: 5996650496
02-22 03:47:57.191 V/MediaUtils( 3265): requested limit: 1199330080
02-22 03:47:57.191 V/MediaUtils( 3265): actual limit: 3221225471
02-22 03:47:57.191 V/MediaUtils( 3265): original limits: -1/-1
02-22 03:47:57.191 V/MediaUtils( 3265): new limits: 3221225471/-1
02-22 03:47:57.193 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchPropertyName: index:0, max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): index:0, propName:max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,imx8_max9286_mipi_3, dev:/dev/video3, node:max9286_mipi, index:0
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 0: name mxc-isi,imx8_max9286_mipi_3, Facing 0, orientation 0, dev path /dev/video3
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchPropertyName: index:1, max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): index:1, propName:max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:vpu encoder,vpu encoder, dev:/dev/video13, node:max9286_mipi, index:1
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,imx8_max9286_mipi_1, dev:/dev/video1, node:max9286_mipi, index:1
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 1: name mxc-isi,imx8_max9286_mipi_1, Facing 2, orientation 0, dev path /dev/video1
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchPropertyName: index:2, max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): index:2, propName:max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:vpu encoder,vpu encoder, dev:/dev/video13, node:max9286_mipi, index:2
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,mxc-isi, dev:/dev/video4, node:max9286_mipi, index:2
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,imx8_max9286_mipi_2, dev:/dev/video2, node:max9286_mipi, index:2
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 2: name mxc-isi,imx8_max9286_mipi_2, Facing 2, orientation 0, dev path /dev/video2
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchPropertyName: index:3, max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): index:3, propName:max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:vpu encoder,vpu encoder, dev:/dev/video13, node:max9286_mipi, index:3
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,mxc-isi, dev:/dev/video4, node:max9286_mipi, index:3
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,imx8_max9286_mipi_0, dev:/dev/video0, node:max9286_mipi, index:3
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 3: name mxc-isi,imx8_max9286_mipi_0, Facing 2, orientation 0, dev path /dev/video0
02-22 03:47:57.195 I/FslCameraHAL( 3233): **************************************** test start *************************************
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 0: name mxc-isi,imx8_max9286_mipi_3, Facing 0, orientation 0, dev path /dev/video3, mExisting true, mPropertyName max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 1: name mxc-isi,imx8_max9286_mipi_1, Facing 2, orientation 0, dev path /dev/video1, mExisting true, mPropertyName max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 2: name mxc-isi,imx8_max9286_mipi_2, Facing 2, orientation 0, dev path /dev/video2, mExisting true, mPropertyName max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 3: name mxc-isi,imx8_max9286_mipi_0, Facing 2, orientation 0, dev path /dev/video0, mExisting true, mPropertyName max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): **************************************** test end *************************************
02-22 03:47:57.195 I/FslCameraHAL( 3233): create id:0 Max9286Mipi device
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera:0: new camera device
02-22 03:47:57.195 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp Max9286Mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): create id:1 Max9286Mipi device
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera:1: new camera device
02-22 03:47:57.195 I/FslCameraHAL( 3233): create id:2 Max9286Mipi device
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera:2: new camera device
02-22 03:47:57.195 I/FslCameraHAL( 3233): create id:3 Max9286Mipi device
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera:3: new camera device
02-22 03:47:57.195 I/FslCameraHAL( 3233): camera number is 4
02-22 03:47:57.195 I/CamProvider@2.4-impl( 3233): Loaded "Default Camera HAL" camera module
02-22 03:47:57.196 I/FslCameraHAL( 3233): getCameraInfo: camera id 0: info=0xffc10fd0
02-22 03:47:57.196 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp initSensorStaticData
02-22 03:47:57.196 I/FslCameraHAL( 3233): enum frame size w:1280, h:720
02-22 03:47:57.196 I/FslCameraHAL( 3233): SupportedPictureSizes: 1280 x 720
02-22 03:47:57.196 I/FslCameraHAL( 3233): SupportedPreviewSizes: 1280 x 720
02-22 03:47:57.196 I/FslCameraHAL( 3233): FrameDuration is 33331760, 30000000000
02-22 03:47:57.196 I/FslCameraHAL( 3233): mMaxWidth:1280, mMaxHeight:720
02-22 03:47:57.196 I/FslCameraHAL( 3233): ImxdpuCsi, mFocalLength:3.370000, mPhysicalWidth:3.628800, mPhysicalHeight 2.721600
02-22 03:47:57.202 I/FslCameraHAL( 3233): getCameraInfo: camera id 1: info=0xffc10fd0
02-22 03:47:57.202 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp initSensorStaticData
02-22 03:47:57.202 I/FslCameraHAL( 3233): enum frame size w:1280, h:720
02-22 03:47:57.202 I/FslCameraHAL( 3233): SupportedPictureSizes: 1280 x 720
02-22 03:47:57.202 I/FslCameraHAL( 3233): SupportedPreviewSizes: 1280 x 720
02-22 03:47:57.202 I/FslCameraHAL( 3233): FrameDuration is 33331760, 30000000000
02-22 03:47:57.202 I/FslCameraHAL( 3233): mMaxWidth:1280, mMaxHeight:720
02-22 03:47:57.202 I/FslCameraHAL( 3233): ImxdpuCsi, mFocalLength:3.370000, mPhysicalWidth:3.628800, mPhysicalHeight 2.721600
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: failed to get path of fd 4: No such file or directory
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: allowing syscall: connect
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: allowing syscall: fcntl
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: allowing syscall: sendto
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: allowing syscall: socket
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: allowing syscall: writev
02-22 03:47:57.208 W//system/bin/mediaextractor( 3265): libminijail[3265]: compile_file: <fd>(47): nonexistent syscall 'ftruncate64'
02-22 03:47:57.208 W//system/bin/mediaextractor( 3265): libminijail[3265]: logging seccomp filter failures
02-22 03:47:57.209 I/FslCameraHAL( 3233): getCameraInfo: camera id 2: info=0xffc10fd0
02-22 03:47:57.213 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp initSensorStaticData
02-22 03:47:57.213 I/FslCameraHAL( 3233): enum frame size w:1280, h:720
02-22 03:47:57.213 I/FslCameraHAL( 3233): SupportedPictureSizes: 1280 x 720
02-22 03:47:57.213 I/FslCameraHAL( 3233): SupportedPreviewSizes: 1280 x 720
02-22 03:47:57.213 I/FslCameraHAL( 3233): FrameDuration is 33331760, 30000000000
02-22 03:47:57.213 I/FslCameraHAL( 3233): mMaxWidth:1280, mMaxHeight:720
02-22 03:47:57.213 I/FslCameraHAL( 3233): ImxdpuCsi, mFocalLength:3.370000, mPhysicalWidth:3.628800, mPhysicalHeight 2.721600
02-22 03:47:57.213 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.222 I/zygote64( 3220): option[0]=-Xzygote
02-22 03:47:57.222 I/zygote64( 3220): option[1]=-Xusetombstonedtraces
02-22 03:47:57.222 I/zygote64( 3220): option[2]=exit
02-22 03:47:57.222 I/zygote64( 3220): option[3]=vfprintf
02-22 03:47:57.222 I/zygote64( 3220): option[4]=sensitiveThread
02-22 03:47:57.222 I/zygote64( 3220): option[5]=-verbose:gc
02-22 03:47:57.222 I/zygote64( 3220): option[6]=-Xms16m
02-22 03:47:57.222 I/zygote64( 3220): option[7]=-Xmx512m
02-22 03:47:57.222 I/zygote64( 3220): option[8]=-XX:HeapGrowthLimit=192m
02-22 03:47:57.222 I/zygote64( 3220): option[9]=-XX:HeapMinFree=512k
02-22 03:47:57.222 I/zygote64( 3220): option[10]=-XX:HeapMaxFree=8m
02-22 03:47:57.222 I/zygote64( 3220): option[11]=-XX:HeapTargetUtilization=0.75
02-22 03:47:57.222 I/zygote64( 3220): option[12]=-Xusejit:true
02-22 03:47:57.222 I/zygote64( 3220): option[13]=-Xjitsaveprofilinginfo
02-22 03:47:57.222 I/zygote64( 3220): option[14]=-XjdwpOptions:suspend=n,server=y
02-22 03:47:57.222 I/zygote64( 3220): option[15]=-XjdwpProvider:default
02-22 03:47:57.222 I/zygote64( 3220): option[16]=-Xlockprofthreshold:500
02-22 03:47:57.222 I/zygote64( 3220): option[17]=-Ximage-compiler-option
02-22 03:47:57.222 I/zygote64( 3220): option[18]=--runtime-arg
02-22 03:47:57.222 I/zygote64( 3220): option[19]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[20]=-Xms64m
02-22 03:47:57.223 I/zygote64( 3220): option[21]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[22]=--runtime-arg
02-22 03:47:57.223 I/zygote64( 3220): option[23]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[24]=-Xmx64m
02-22 03:47:57.223 I/zygote64( 3220): option[25]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[26]=--profile-file=/system/etc/boot-image.prof
02-22 03:47:57.223 I/zygote64( 3220): option[27]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[28]=--compiler-filter=speed-profile
02-22 03:47:57.223 I/zygote64( 3220): option[29]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[30]=--runtime-arg
02-22 03:47:57.223 I/zygote64( 3220): option[31]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[32]=-Xms64m
02-22 03:47:57.223 I/zygote64( 3220): option[33]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[34]=--runtime-arg
02-22 03:47:57.223 I/zygote64( 3220): option[35]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[36]=-Xmx512m
02-22 03:47:57.223 I/zygote64( 3220): option[37]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[38]=--instruction-set-variant=cortex-a53
02-22 03:47:57.223 I/zygote64( 3220): option[39]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[40]=--instruction-set-variant=cortex-a53
02-22 03:47:57.223 I/zygote64( 3220): option[41]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[42]=--instruction-set-features=default
02-22 03:47:57.223 I/zygote64( 3220): option[43]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[44]=--instruction-set-features=default
02-22 03:47:57.223 I/zygote64( 3220): option[45]=-Duser.locale=zh-Hans-CN
02-22 03:47:57.223 I/zygote64( 3220): option[46]=--cpu-abilist=arm64-v8a
02-22 03:47:57.223 I/zygote64( 3220): option[47]=-Xfingerprint:Android/mek_8q/mek_8q:9/2.0.1-ga-rc1/neolix01061131:userdebug/dev-keys
02-22 03:47:57.225 I/FslCameraHAL( 3233): getCameraInfo: camera id 3: info=0xffc10fd0
02-22 03:47:57.225 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp initSensorStaticData
02-22 03:47:57.227 I/FslCameraHAL( 3233): enum frame size w:1280, h:720
02-22 03:47:57.227 I/FslCameraHAL( 3233): SupportedPictureSizes: 1280 x 720
02-22 03:47:57.227 I/FslCameraHAL( 3233): SupportedPreviewSizes: 1280 x 720
02-22 03:47:57.227 I/FslCameraHAL( 3233): FrameDuration is 33331760, 30000000000
02-22 03:47:57.227 I/FslCameraHAL( 3233): mMaxWidth:1280, mMaxHeight:720
02-22 03:47:57.227 I/FslCameraHAL( 3233): ImxdpuCsi, mFocalLength:3.370000, mPhysicalWidth:3.628800, mPhysicalHeight 2.721600
02-22 03:47:57.234 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.238 I/ServiceManagement( 3233): Removing namespace from process name android.hardware.camera.provider@2.4-service to provider@2.4-service.
02-22 03:47:57.239 I/android.hardware.camera.provider@2.4-service( 3233): Registration complete for android.hardware.camera.provider@2.4::ICameraProvider/legacy/0.
02-22 03:47:57.240 I/media.codec( 3270): mediacodecservice starting
02-22 03:47:57.243 I/zygote64( 3220): VerifyImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-directory=/data/dalvik-cache/arm64 --instruction-set=arm64 --verify
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: failed to get path of fd 4: No such file or directory
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: allowing syscall: clock_gettime
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: allowing syscall: connect
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: allowing syscall: fcntl64
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: allowing syscall: socket
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: allowing syscall: writev
02-22 03:47:57.247 W/media.codec( 3270): libminijail[3270]: compile_file: <fd>(61): nonexistent syscall 'create'
02-22 03:47:57.247 W/media.codec( 3270): libminijail[3270]: compile_file: <fd>(63): nonexistent syscall 'mkfifo'
02-22 03:47:57.247 W/media.codec( 3270): libminijail[3270]: logging seccomp filter failures
02-22 03:47:57.252 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::startGraphicsAllocatorService retrieved: 0
02-22 03:47:57.253 I/SurfaceFlinger( 3250): Using HWComposer service: 'default'
02-22 03:47:57.253 I/SurfaceFlinger( 3250): SurfaceFlinger is starting
02-22 03:47:57.254 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.255 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncEventPhaseOffsetNs retrieved: 1000000 (default)
02-22 03:47:57.255 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncSfEventPhaseOffsetNs retrieved: 1000000 (default)
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasSyncFramework retrieved: 1
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::presentTimeOffsetFromVSyncNs retrieved: 0
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useHwcForRGBtoYUV retrieved: 0
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxVirtualDisplaySize retrieved: 0 (default)
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useVrFlinger retrieved: 0 (default)
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxFrameBufferAcquiredBuffers retrieved: 3
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:47:57.258 I/ConfigStore( 3250): android::hardware::configstore::V1_1::ISurfaceFlingerConfigs::primaryDisplayOrientation retrieved: ORIENTATION_0 (default)
02-22 03:47:57.258 I/SurfaceFlinger( 3250): Enabling HWC virtual displays
02-22 03:47:57.258 I/SurfaceFlinger( 3250): Disabling Triple Buffering
02-22 03:47:57.258 I/SurfaceFlinger( 3250): Treble testing override: 'false'
02-22 03:47:57.259 I/SurfaceFlinger( 3250): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
02-22 03:47:57.259 I/SurfaceFlinger( 3250): Phase offest NS: 1000000
02-22 03:47:57.275 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.294 W/MediaCodecsXmlParser( 3270): unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
02-22 03:47:57.294 W/MediaCodecsXmlParser( 3270): parseTopLevelXMLFile(/data/misc/media/media_codecs_profiling_results.xml) failed
02-22 03:47:57.296 I/ServiceManagement( 3270): Removing namespace from process name android.hardware.media.omx@1.0-service to omx@1.0-service.
02-22 03:47:57.297 D/libEGL  ( 3250): loaded /vendor/lib64/egl/libEGL_VIVANTE.so
02-22 03:47:57.298 I/android.hardware.usb.gadget@1.0-service.imx( 3248): setCurrentUsbFunctions Adb
02-22 03:47:57.298 I/android.hardware.usb.gadget@1.0-service.imx( 3248): Service started
02-22 03:47:57.299 I/android.hardware.usb.gadget@1.0-service.imx( 3248): Usb Gadget setcurrent functions called successfully
02-22 03:47:57.325 I/cameraserver( 3260): ServiceManager: 0xe8e9c100
02-22 03:47:57.325 I/CameraService( 3260): CameraService started (pid=3260)
02-22 03:47:57.325 I/CameraService( 3260): CameraService process starting
02-22 03:47:57.325 W/BatteryNotifier( 3260): batterystats service unavailable!
02-22 03:47:57.329 I/CameraProviderManager( 3260): Connecting to new camera provider: legacy/0, isRemote? 1
02-22 03:47:57.330 I/CameraProviderManager( 3260): Enumerating new camera device: device@3.4/legacy/0
02-22 03:47:57.331 I/CameraProviderManager( 3260): Enumerating new camera device: device@3.4/legacy/1
02-22 03:47:57.332 I/CameraProviderManager( 3260): Enumerating new camera device: device@3.4/legacy/2
02-22 03:47:57.332 I/CameraProviderManager( 3260): Enumerating new camera device: device@3.4/legacy/3
02-22 03:47:57.332 I/CameraProviderManager( 3260): Camera provider legacy/0 ready with 4 camera devices
02-22 03:47:57.333 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.camera.provider@2.4::ICameraProvider/external/0 in either framework or device manifest.
02-22 03:47:57.334 W/CameraProviderManager( 3260): addProviderLocked: Camera provider HAL with name 'legacy/0' already registered
02-22 03:47:57.334 I/CameraHardwareInterface( 3260): Opening camera 0
02-22 03:47:57.334 E/CameraHardwareInterface( 3260): initialize: openSession failed! No such file or directory (-2)
02-22 03:47:57.334 E/CameraFlashlight( 3260): connectCameraDevice: initializing camera 0 failed
02-22 03:47:57.334 I/mediaserver( 3254): ServiceManager: 0xe9c1c1c0
02-22 03:47:57.334 I/CameraHardwareInterface( 3260): Destroying camera 0
02-22 03:47:57.334 E/CameraFlashlight( 3260): findFlashUnits: failed to check if camera 0 has a flash unit. No such file or directory (-2)
02-22 03:47:57.335 I/CameraHardwareInterface( 3260): Opening camera 1
02-22 03:47:57.335 E/CameraHardwareInterface( 3260): initialize: openSession failed! No such file or directory (-2)
02-22 03:47:57.335 E/CameraFlashlight( 3260): connectCameraDevice: initializing camera 1 failed
02-22 03:47:57.335 I/CameraHardwareInterface( 3260): Destroying camera 1
02-22 03:47:57.335 W/BatteryNotifier( 3254): batterystats service unavailable!
02-22 03:47:57.335 E/CameraFlashlight( 3260): findFlashUnits: failed to check if camera 1 has a flash unit. No such file or directory (-2)
02-22 03:47:57.336 I/CameraHardwareInterface( 3260): Opening camera 2
02-22 03:47:57.336 E/CameraHardwareInterface( 3260): initialize: openSession failed! No such file or directory (-2)
02-22 03:47:57.336 E/CameraFlashlight( 3260): connectCameraDevice: initializing camera 2 failed
02-22 03:47:57.336 I/CameraHardwareInterface( 3260): Destroying camera 2
02-22 03:47:57.336 E/CameraFlashlight( 3260): findFlashUnits: failed to check if camera 2 has a flash unit. No such file or directory (-2)
02-22 03:47:57.336 I/CameraHardwareInterface( 3260): Opening camera 3
02-22 03:47:57.336 E/CameraFlashlight( 3260): connectCameraDevice: initializing camera 3 failed
02-22 03:47:57.336 I/CameraHardwareInterface( 3260): Destroying camera 3
02-22 03:47:57.336 E/CameraFlashlight( 3260): findFlashUnits: failed to check if camera 3 has a flash unit. No such file or directory (-2)
02-22 03:47:57.336 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=3, newStatus=1
02-22 03:47:57.336 I/CameraService( 3260): onDeviceStatusChanged: Unknown camera ID 3, a new camera is added
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=2, newStatus=1
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Unknown camera ID 2, a new camera is added
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=1, newStatus=1
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Unknown camera ID 1, a new camera is added
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=0, newStatus=1
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Unknown camera ID 0, a new camera is added
02-22 03:47:57.338 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=3, newStatus=1
02-22 03:47:57.338 E/CameraService( 3260): onDeviceStatusChanged: State transition to the same status 0x1 not allowed
02-22 03:47:57.338 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=2, newStatus=1
02-22 03:47:57.338 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=1, newStatus=1
02-22 03:47:57.338 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=0, newStatus=1
02-22 03:47:57.338 I/        ( 3260): Waiting for activity service
02-22 03:47:57.360 I/OMXPlayer( 3270): LEVEL: 1 FUNCTION: Open LINE: 39
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_ac3
02-22 03:47:57.360 I/OMXPlayer( 3270): LEVEL: 1 FUNCTION: ComponentRegister LINE: 75
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_ac3 fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_ddp
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_ddp fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_ms
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_ms fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_wmv9
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_wmv9 fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_ra
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_ra fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_rv
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_rv fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_dsp_aacp
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_dsp_aacp fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_dsp fail.
02-22 03:47:57.375 D/libEGL  ( 3250): loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
02-22 03:47:57.378 W/MediaCodecsXmlParser( 3270): unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
02-22 03:47:57.378 W/MediaCodecsXmlParser( 3270): parseTopLevelXMLFile(/data/misc/media/media_codecs_profiling_results.xml) failed
02-22 03:47:57.378 I/ServiceManagement( 3270): Removing namespace from process name android.hardware.media.omx@1.0-service to omx@1.0-service.
02-22 03:47:57.379 I/media.codec( 3270): IOmx HAL service created.
02-22 03:47:57.439 I/FastMixerState( 3252): sMaxFastTracks = 8
02-22 03:47:57.441 V/MediaUtils( 3252): physMem: 4294967295
02-22 03:47:57.441 V/MediaUtils( 3252): requested limit: 536870912
02-22 03:47:57.441 V/MediaUtils( 3252): actual limit: 536870912
02-22 03:47:57.441 V/MediaUtils( 3252): original limits: 4294967295/4294967295
02-22 03:47:57.441 V/MediaUtils( 3252): new limits: 536870912/4294967295
02-22 03:47:57.442 I/audioserver( 3252): ServiceManager: 0xf189c100
02-22 03:47:57.442 W/BatteryNotifier( 3252): batterystats service unavailable!
02-22 03:47:57.445 D/libEGL  ( 3250): loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
02-22 03:47:57.447 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.audio@4.0::IDevicesFactory/msd in either framework or device manifest.
02-22 03:47:57.451 I/AudioFlinger( 3252): Using default 3000 mSec as standby time.
02-22 03:47:57.454 E/APM::Serializer( 3252): deserialize: Could not parse /odm/etc/audio_policy_configuration.xml document.
02-22 03:47:57.494 D/AndroidRuntime( 3221): >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
02-22 03:47:57.504 I/zygote  ( 3221): option[0]=-Xzygote
02-22 03:47:57.504 I/zygote  ( 3221): option[1]=-Xusetombstonedtraces
02-22 03:47:57.504 I/zygote  ( 3221): option[2]=exit
02-22 03:47:57.504 I/zygote  ( 3221): option[3]=vfprintf
02-22 03:47:57.504 I/zygote  ( 3221): option[4]=sensitiveThread
02-22 03:47:57.504 I/zygote  ( 3221): option[5]=-verbose:gc
02-22 03:47:57.504 I/zygote  ( 3221): option[6]=-Xms16m
02-22 03:47:57.504 I/zygote  ( 3221): option[7]=-Xmx512m
02-22 03:47:57.504 I/zygote  ( 3221): option[8]=-XX:HeapGrowthLimit=192m
02-22 03:47:57.504 I/zygote  ( 3221): option[9]=-XX:HeapMinFree=512k
02-22 03:47:57.504 I/zygote  ( 3221): option[10]=-XX:HeapMaxFree=8m
02-22 03:47:57.504 I/zygote  ( 3221): option[11]=-XX:HeapTargetUtilization=0.75
02-22 03:47:57.504 I/zygote  ( 3221): option[12]=-Xusejit:true
02-22 03:47:57.504 I/zygote  ( 3221): option[13]=-Xjitsaveprofilinginfo
02-22 03:47:57.504 I/zygote  ( 3221): option[14]=-XjdwpOptions:suspend=n,server=y
02-22 03:47:57.504 I/zygote  ( 3221): option[15]=-XjdwpProvider:default
02-22 03:47:57.504 I/zygote  ( 3221): option[16]=-Xlockprofthreshold:500
02-22 03:47:57.504 I/zygote  ( 3221): option[17]=-Ximage-compiler-option
02-22 03:47:57.504 I/zygote  ( 3221): option[18]=--runtime-arg
02-22 03:47:57.504 I/zygote  ( 3221): option[19]=-Ximage-compiler-option
02-22 03:47:57.504 I/zygote  ( 3221): option[20]=-Xms64m
02-22 03:47:57.505 I/zygote  ( 3221): option[21]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[22]=--runtime-arg
02-22 03:47:57.505 I/zygote  ( 3221): option[23]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[24]=-Xmx64m
02-22 03:47:57.505 I/zygote  ( 3221): option[25]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[26]=--profile-file=/system/etc/boot-image.prof
02-22 03:47:57.505 I/zygote  ( 3221): option[27]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[28]=--compiler-filter=speed-profile
02-22 03:47:57.505 I/zygote  ( 3221): option[29]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[30]=--runtime-arg
02-22 03:47:57.505 I/zygote  ( 3221): option[31]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[32]=-Xms64m
02-22 03:47:57.505 I/zygote  ( 3221): option[33]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[34]=--runtime-arg
02-22 03:47:57.505 I/zygote  ( 3221): option[35]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[36]=-Xmx512m
02-22 03:47:57.505 I/zygote  ( 3221): option[37]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[38]=--instruction-set-variant=cortex-a9
02-22 03:47:57.505 I/zygote  ( 3221): option[39]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[40]=--instruction-set-variant=cortex-a9
02-22 03:47:57.505 I/zygote  ( 3221): option[41]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[42]=--instruction-set-features=default
02-22 03:47:57.505 I/zygote  ( 3221): option[43]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[44]=--instruction-set-features=default
02-22 03:47:57.505 I/zygote  ( 3221): option[45]=-Duser.locale=zh-Hans-CN
02-22 03:47:57.505 I/zygote  ( 3221): option[46]=--cpu-abilist=armeabi-v7a,armeabi
02-22 03:47:57.505 I/zygote  ( 3221): option[47]=-Xfingerprint:Android/mek_8q/mek_8q:9/2.0.1-ga-rc1/neolix01061131:userdebug/dev-keys
02-22 03:47:57.506 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:47:57.506 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:47:57.507 W/SurfaceFlinger( 3250): no suitable EGLConfig found, trying a simpler query
02-22 03:47:57.507 I/SurfaceFlinger( 3250): EGL information:
02-22 03:47:57.507 I/SurfaceFlinger( 3250): vendor    : Android
02-22 03:47:57.507 I/SurfaceFlinger( 3250): version   : 1.4 Android META-EGL
02-22 03:47:57.507 I/SurfaceFlinger( 3250): extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_swap_buffers_with_damage EGL_ANDROID_get_native_client_buffer EGL_ANDROID_front_buffer_auto_refresh EGL_ANDROID_get_frame_timestamps EGL_EXT_surface_SMPTE2086_metadata EGL_EXT_surface_CTA861_3_metadata EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_lock_surface EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_create_context EGL_KHR_surfaceless_context EGL_ANDROID_image_native_buffer EGL_KHR_wait_sync EGL_ANDROID_recordable EGL_KHR_partial_update EGL_EXT_buffer_age
02-22 03:47:57.507 I/SurfaceFlinger( 3250): Client API: OpenGL_ES
02-22 03:47:57.507 I/SurfaceFlinger( 3250): EGLSurface: 8-8-8-8, config=0x15
02-22 03:47:57.511 W/audio_hw_primary( 3231): card 0, id wm8960audio, driver wm8960-audio, name wm8960-audio
02-22 03:47:57.516 W/audio_hw_primary( 3231): out rate 44100
02-22 03:47:57.519 I/zygote  ( 3221): VerifyImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-directory=/data/dalvik-cache/arm --instruction-set=arm --verify
02-22 03:47:57.531 I/SurfaceFlinger( 3250): OpenGL ES informations:
02-22 03:47:57.531 I/SurfaceFlinger( 3250): vendor    : Vivante Corporation
02-22 03:47:57.531 I/SurfaceFlinger( 3250): renderer  : Vivante GC7000XSVX
02-22 03:47:57.531 I/SurfaceFlinger( 3250): version   : OpenGL ES 3.2 V6.2.4.p4.190076
02-22 03:47:57.531 I/SurfaceFlinger( 3250): extensions: GL_EXT_debug_marker GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_half_float GL_OES_element_index_uint GL_OES_mapbuffer GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_rgb8_rgba8 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32 GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_fragment_precision_high GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_texture_stencil8 GL_OES_shader_image_atomic GL_OES_sample_variables GL_OES_sample_shading GL_OES_texture_storage_multisample_2d_array GL_OES_shader_multisample_interpolation GL_OES_required_internalformat GL_OES_surfaceless_context GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_geometry_shader GL_OES_geometry_point_size GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_border_clamp GL_OES_texture_buffer GL_OES_tessellation
02-22 03:47:57.531 I/SurfaceFlinger( 3250): GL_MAX_TEXTURE_SIZE = 8192
02-22 03:47:57.531 I/SurfaceFlinger( 3250): GL_MAX_VIEWPORT_DIMS = 8192
02-22 03:47:57.532 W/audio_hw_primary( 3231): in rate 44100, channels 1 format 0
02-22 03:47:57.532 W/audio_hw_primary( 3231): card 1, id xtoraudio, driver xtor-audio, name xtor-audio
02-22 03:47:57.537 W/audio_hw_primary( 3231): out rate 48000
02-22 03:47:57.545 I/display ( 3242): HWC disabled!
02-22 03:47:57.545 I/display ( 3242): Opengl ES 3D composition enabled!
02-22 03:47:57.559 W/audio_hw_primary( 3231): in rate 48000, channels 1 format 0
02-22 03:47:57.559 W/audio_hw_primary( 3231): card 2, id amixaudiosai, driver amix-audio-sai, name amix-audio-sai
02-22 03:47:57.559 W/audio_hw_primary( 3231): unrecognized card found.
02-22 03:47:57.559 I/audio_hw_primary( 3231): Total 2 cards match
02-22 03:47:57.559 I/audio_hw_primary( 3231): card idx 0, name wm8960-audio
02-22 03:47:57.559 I/audio_hw_primary( 3231): card idx 1, name bt-sai-audio
02-22 03:47:57.562 I/audio_hw_primary( 3231): select_output_device(), headphone 0 ,headset 0 ,speaker 2, earpiece 0,
02-22 03:47:57.563 W/DeviceHAL( 3231): Error from HAL Device in function set_master_volume: Function not implemented
02-22 03:47:57.564 I/AudioFlinger( 3252): loadHwModule() Loaded primary audio interface, handle 10
02-22 03:47:57.564 I/AudioFlinger( 3252): openOutput() this 0xf18be000, module 10 Device 0x2, SamplingRate 48000, Format 0x000001, Channels 0x3, flags 0x2
02-22 03:47:57.564 I/audio_hw_primary( 3231): adev_open_output_stream: enter: sample_rate(48000) channel_mask(0x3) format(0x1) devices(0x2) flags(0x2), address()
02-22 03:47:57.564 I/audio_hw_primary( 3231): adev_open_output_stream: exit: output_type 1, output 0xee2d2000
02-22 03:47:57.565 I/AudioFlinger( 3252): HAL output buffer size 192 frames, normal sink buffer size 960 frames
02-22 03:47:57.591 I/display ( 3242): load /vendor/lib64/libg2d.so library!
02-22 03:47:57.592 I/display ( 3242): open gpu gralloc module!
02-22 03:47:57.623 I/display ( 3242): try dev:/dev/dri/card0
02-22 03:47:57.624 I/libedid ( 3242): Try to check fd 19 connector:82 edid info
02-22 03:47:57.639 I/BufferProvider( 3252): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
02-22 03:47:57.640 I/AudioFlinger( 3252): Using module 10 as the primary audio interface
02-22 03:47:57.640 I/audio_hw_primary( 3231): adev_set_mode mode 0
02-22 03:47:57.641 I/AudioFlinger( 3252): AudioFlinger's thread 0xf0e03c00 tid=3361 ready to run
02-22 03:47:57.641 W/AudioFlinger( 3252): no wake lock to update, system not ready yet
02-22 03:47:57.641 W/AudioFlinger( 3252): moveEffects() bad srcOutput 0
02-22 03:47:57.642 D/audio_hw_primary( 3231): out_set_parameters: enter: kvpairs: routing=2
02-22 03:47:57.642 D/audio_hw_primary( 3231): out_set_parameters: exit: code(0)
02-22 03:47:57.642 W/audio_hw_primary( 3231): In channels 2, rate 48000, devices 0x80000004
02-22 03:47:57.643 W/audio_hw_primary( 3231): get_input_buffer_size size = 512, channel_count = 2
02-22 03:47:57.644 I/AudioFlinger( 3252): AudioFlinger's thread 0xf0b03000 tid=3363 ready to run
02-22 03:47:57.644 E/FastThread( 3252): did not receive expected priority boost on time
02-22 03:47:57.664 I/bt_a2dp_hw( 3252): adev_open:  adev_open in A2dp_hw module
02-22 03:47:57.664 I/AudioFlinger( 3252): loadHwModule() Loaded a2dp audio interface, handle 18
02-22 03:47:57.670 I/AudioFlinger( 3252): loadHwModule() Loaded usb audio interface, handle 26
02-22 03:47:57.700 I/display ( 3242): readConnection: id:1, connection:1, count_modes:19, count_encoders:1
02-22 03:47:57.700 I/display ( 3242): Require mode:width:1920, height:1080, vrefresh 60, prefermode 1
02-22 03:47:57.700 I/display ( 3242): Find best mode w:1920, h:1080, vrefresh:60 at mode index 0
02-22 03:47:57.715 E/        ( 3247): retrying to open(FSL_SENS_HUB)
02-22 03:47:57.719 I/r_submix( 3231): adev_open(name=audio_hw_if)
02-22 03:47:57.719 I/r_submix( 3231): adev_init_check()
02-22 03:47:57.719 W/DeviceHAL( 3231): Error from HAL Device in function set_master_mute: Function not implemented
02-22 03:47:57.720 I/AudioFlinger( 3252): loadHwModule() Loaded r_submix audio interface, handle 34
02-22 03:47:57.720 D/r_submix( 3231): adev_open_input_stream(addr=0)
02-22 03:47:57.720 D/r_submix( 3231): submix_audio_device_create_pipe_l(addr=0, idx=9)
02-22 03:47:57.720 D/r_submix( 3231):   now using address 0 for route 9
02-22 03:47:57.721 I/AudioFlinger( 3252): AudioFlinger's thread 0xf0b03440 tid=3364 ready to run
02-22 03:47:57.722 D/r_submix( 3231): adev_close_input_stream()
02-22 03:47:57.722 I/        ( 3252): Waiting for activity service
02-22 03:47:57.722 D/r_submix( 3231): submix_audio_device_release_pipe_l(idx=9) addr=0
02-22 03:47:57.722 D/r_submix( 3231): submix_audio_device_destroy_pipe_l(): pipe destroyed
02-22 03:47:57.738 I/display ( 3242): Require mode:width:1920, height:1080, vrefresh 60, prefermode 1
02-22 03:47:57.738 I/display ( 3242): Find best mode w:1920, h:1080, vrefresh:60 at mode index 0
02-22 03:47:57.739 E/display ( 3242): can't find property ID for 'ANDROID_OUT_FENCE_PTR'.
02-22 03:47:57.739 E/display ( 3242): can't find property ID for 'alpha'.
02-22 03:47:57.740 E/display ( 3242): can't find property ID for 'dtrc_table_ofs'.
02-22 03:47:57.740 E/display ( 3242): can't find property ID for 'alpha'.
02-22 03:47:57.740 W/display ( 3242): xres         = 1920 px
02-22 03:47:57.740 W/display ( 3242): yres         = 1080 px
02-22 03:47:57.740 W/display ( 3242): format       = 1
02-22 03:47:57.740 W/display ( 3242): xdpi         = 69.67 ppi
02-22 03:47:57.740 W/display ( 3242): ydpi         = 70.34 ppi
02-22 03:47:57.740 W/display ( 3242): fps          = 60.00 Hz
02-22 03:47:57.740 W/display ( 3242): mode.width   = 1920 px
02-22 03:47:57.740 W/display ( 3242): mode.height  = 1080 px
02-22 03:47:57.740 E/ion     ( 3242): ioctl c0044901 failed with code -1: Not a typewriter
02-22 03:47:57.770 E/        ( 3247): couldn't find 'FSL_SENS_HUB' input device
02-22 03:47:57.791 I/display ( 3242): enumKmsDisplay set 1 as primary display
02-22 03:47:57.791 E/display ( 3242): failed to set DPMS mode:3
02-22 03:47:57.791 I/display ( 3242): try dev:/dev/dri/card1
02-22 03:47:57.791 E/display ( 3242): Failed to set atomic cap -1
02-22 03:47:57.793 E/HWComposer( 3250): getSupportedPerFrameMetadata: getSupportedPerFrameMetadata failed for display 0: Unsupported (8)
02-22 03:47:57.800 I/display ( 3241): open gpu gralloc module!
02-22 03:47:57.802 E/ion     ( 3241): ioctl c0044901 failed with code -1: Not a typewriter
02-22 03:47:57.804 I/android.hardware.usb.gadget@1.0-service.imx( 3248): GADGET pulled up
02-22 03:47:57.805 E/display ( 3242): threadLoop invalid uevent change@/devices/platform/5b110000.usb3/gadget-cdns3/udc/gadget-cdns3
02-22 03:47:57.807 I/display ( 3250): open gpu gralloc module!
02-22 03:47:57.808 E/gralloc ( 3250): gralloc1_device_open invalid name:fb0
02-22 03:47:57.808 I/v_egl   ( 3250): FramebufferSurface: bufferCount=3
02-22 03:47:57.877 I/ServiceManager( 3268): Waiting for service package_native...
02-22 03:47:58.026 D/SurfaceFlinger( 3250): shader cache generated - 24 shaders in 195.013870 ms
02-22 03:47:58.028 W/init    (    1): type=1400 audit(0.0:572): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:58.028 I/chatty  (    1): uid=0(root) /init identical 2 lines
02-22 03:47:58.028 W/init    (    1): type=1400 audit(0.0:575): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:58.028 D/SurfaceFlinger( 3250): Set power mode=2, type=0 flinger=0xfa0244858000
02-22 03:47:58.028 D/SurfaceFlinger( 3250): Finished set power mode=2, type=0
02-22 03:47:58.082 E/display ( 3242): threadLoop invalid uevent change@/devices/virtual/android_usb/android0
02-22 03:47:58.107 E/display ( 3242): threadLoop invalid uevent change@/devices/virtual/android_usb/android0
02-22 03:47:58.120 D/Zygote  ( 3220): begin preload
02-22 03:47:58.120 I/Zygote  ( 3220): Installing ICU cache reference pinning...
02-22 03:47:58.120 I/Zygote  ( 3220): Preloading ICU data...
02-22 03:47:58.183 D/Zygote64Timing( 3220): BeginIcuCachePinning took to complete: 63ms
02-22 03:47:58.184 I/Zygote  ( 3220): Preloading classes...
02-22 03:47:58.203 I/Zygote  ( 3220): ...preloaded 0 classes in 20ms.
02-22 03:47:58.204 I/zygote64( 3220): VMRuntime.preloadDexCaches starting
02-22 03:47:58.262 I/zygote64( 3220): VMRuntime.preloadDexCaches strings total=339243 before=12303 after=12303
02-22 03:47:58.262 I/zygote64( 3220): VMRuntime.preloadDexCaches types total=31355 before=7818 after=7819
02-22 03:47:58.262 I/zygote64( 3220): VMRuntime.preloadDexCaches fields total=140849 before=9174 after=9174
02-22 03:47:58.262 I/zygote64( 3220): VMRuntime.preloadDexCaches methods total=247792 before=12783 after=12783
02-22 03:47:58.262 I/zygote64( 3220): VMRuntime.preloadDexCaches finished
02-22 03:47:58.262 D/Zygote64Timing( 3220): PreloadClasses took to complete: 79ms
02-22 03:47:58.298 I/zygote64( 3220): Thread[6,tid=3379,Native,Thread*=0xff8e17886800,peer=0x12cf9198,"Thread-1"] recursive attempt to load library "/system/lib64/libmedia_jni.so"
02-22 03:47:58.298 D/MtpDeviceJNI( 3220): register_android_mtp_MtpDevice
02-22 03:47:58.407 I/zygote  ( 3221): Explicit concurrent copying GC freed 179(9KB) AllocSpace objects, 0(0B) LOS objects, 98% free, 22KB/1558KB, paused 83us total 9.038ms
02-22 03:47:58.417 I/zygote  ( 3221): Explicit concurrent copying GC freed 5(32KB) AllocSpace objects, 0(0B) LOS objects, 98% free, 22KB/1558KB, paused 59us total 8.650ms
02-22 03:47:58.417 D/Zygote32Timing( 3221): PostZygoteInitGC took to complete: 18ms
02-22 03:47:58.417 D/Zygote32Timing( 3221): ZygoteInit took to complete: 19ms
02-22 03:47:58.446 I/Zygote  ( 3221): Accepting command socket connections
02-22 03:47:58.465 D/libEGL  ( 3376): loaded /vendor/lib64/egl/libEGL_VIVANTE.so
02-22 03:47:58.476 D/libEGL  ( 3376): loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
02-22 03:47:58.524 I/Zygote  ( 3220): Preloading resources...
02-22 03:47:58.549 W/Resources( 3220): Preloaded drawable resource #0x1080265 (android:drawable/dialog_background_material) that varies with configuration!!
02-22 03:47:58.562 D/libEGL  ( 3376): loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
02-22 03:47:58.574 I/Zygote  ( 3220): ...preloaded 64 resources in 50ms.
02-22 03:47:58.581 I/Zygote  ( 3220): ...preloaded 41 resources in 7ms.
02-22 03:47:58.581 D/Zygote64Timing( 3220): PreloadResources took to complete: 317ms
02-22 03:47:58.604 D/libEGL  ( 3220): loaded /vendor/lib64/egl/libEGL_VIVANTE.so
02-22 03:47:58.617 D/libEGL  ( 3220): loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
02-22 03:47:58.630 I/ConfigStore( 3376): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:47:58.630 I/ConfigStore( 3376): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:47:58.637 I/display ( 3376): open gpu gralloc module!
02-22 03:47:58.662 D/BootAnimation( 3376): BootAnimationShownTiming start time: 14719ms
02-22 03:47:58.680 D/libEGL  ( 3220): loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
02-22 03:47:58.710 I/SurfaceFlinger( 3250): Enter boot animation
02-22 03:47:58.720 W/SurfaceFlinger( 3250): Unable to determine the display type for display 1
02-22 03:47:58.725 I/Zygote  ( 3220): Preloading shared libraries...
02-22 03:47:58.743 I/Zygote  ( 3220): Uninstalled ICU cache reference pinning...
02-22 03:47:58.744 I/Zygote  ( 3220): Installed AndroidKeyStoreProvider in 0ms.
02-22 03:47:58.750 I/Zygote  ( 3220): Warmed up JCA providers in 7ms.
02-22 03:47:58.750 D/Zygote  ( 3220): end preload
02-22 03:47:58.750 D/Zygote64Timing( 3220): ZygotePreload took to complete: 630ms
02-22 03:47:58.770 E/        ( 3247): retrying to open(FSL_SENS_HUB)
02-22 03:47:58.780 I/zygote64( 3220): Explicit concurrent copying GC freed 51536(5MB) AllocSpace objects, 165(3MB) LOS objects, 50% free, 2MB/4MB, paused 47us total 29.456ms
02-22 03:47:58.809 I/zygote64( 3220): Explicit concurrent copying GC freed 2801(136KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 2MB/4MB, paused 22us total 18.994ms
02-22 03:47:58.809 D/Zygote64Timing( 3220): PostZygoteInitGC took to complete: 59ms
02-22 03:47:58.809 D/Zygote64Timing( 3220): ZygoteInit took to complete: 689ms
02-22 03:47:58.822 E/        ( 3247): couldn't find 'FSL_SENS_HUB' input device
02-22 03:47:58.885 I/ServiceManager( 3268): Waiting for service package_native...
02-22 03:47:59.142 I/Zygote  ( 3220): System server process 3407 has been created
02-22 03:47:59.145 I/Zygote  ( 3220): Accepting command socket connections
02-22 03:47:59.161 I/Zygote  ( 3407): Process: zygote socket RESERVED/zygote_secondary opened, supported ABIS: armeabi-v7a,armeabi
02-22 03:47:59.256 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:47:59.279 W/cmd     ( 3423): Can't find service package
02-22 03:47:59.282 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:47:59.302 I/SystemServer( 3407): InitBeforeStartServices
02-22 03:47:59.303 I/SystemServer( 3407): Entered the Android system server!
02-22 03:47:59.284 I/chatty  ( 3407): uid=1000 system_server identical 1 line
02-22 03:47:59.286 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:47:59.326 W/cmd     ( 3427): Can't find service package
02-22 03:47:59.508 E/UsbAlsaJackDetectorJNI( 3407): Can't register UsbAlsaJackDetector native methods
02-22 03:47:59.523 D/SystemServerTiming( 3407): InitBeforeStartServices took to complete: 221ms
02-22 03:47:59.523 I/SystemServer( 3407): StartServices
02-22 03:47:59.524 I/SystemServer( 3407): Reading configuration...
02-22 03:47:59.524 I/SystemServer( 3407): ReadingSystemConfig
02-22 03:47:59.524 D/SystemServerTiming( 3407): ReadingSystemConfig took to complete: 1ms
02-22 03:47:59.524 I/SystemServer( 3407): StartInstaller
02-22 03:47:59.524 I/SystemServiceManager( 3407): Starting com.android.server.pm.Installer
02-22 03:47:59.525 D/SystemServerInitThreadPool( 3407): Started executing ReadingSystemConfig
02-22 03:47:59.526 D/installd( 3263): Found quota mount /dev/block/by-name/userdata at /data
02-22 03:47:59.526 D/SystemServerTiming( 3407): StartInstaller took to complete: 2ms
02-22 03:47:59.526 I/SystemServer( 3407): DeviceIdentifiersPolicyService
02-22 03:47:59.526 I/SystemServiceManager( 3407): Starting com.android.server.os.DeviceIdentifiersPolicyService
02-22 03:47:59.527 D/SystemServerTiming( 3407): DeviceIdentifiersPolicyService took to complete: 0ms
02-22 03:47:59.527 I/SystemServer( 3407): StartActivityManager
02-22 03:47:59.527 I/SystemServiceManager( 3407): Starting com.android.server.am.ActivityManagerService$Lifecycle
02-22 03:47:59.537 I/ActivityManager( 3407): Memory class: 192
02-22 03:47:59.546 D/BatteryStatsImpl( 3407): Reading daily items from /data/system/batterystats-daily.xml
02-22 03:47:59.552 E/BluetoothAdapter( 3407): Bluetooth binder is null
02-22 03:47:59.553 E/BatteryExternalStatsWorker( 3407): no controller energy info supplied for telephony
02-22 03:47:59.554 E/KernelUidCpuFreqTimeReader( 3407): Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
02-22 03:47:59.560 W/KernelCpuProcReader( 3407): File not exist: /proc/uid_cpupower/concurrent_active_time
02-22 03:47:59.560 W/KernelCpuProcReader( 3407): File not exist: /proc/uid_cpupower/concurrent_policy_time
02-22 03:47:59.565 I/PowerManagerService-JNI( 3407): Loaded power HAL 1.0 service
02-22 03:47:59.565 E/KernelUidCpuFreqTimeReader( 3407): Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
02-22 03:47:59.581 D/SystemServerInitThreadPool( 3407): Finished executing ReadingSystemConfig
02-22 03:47:59.612 W/AppOps  ( 3407): Unknown attribute in 'op' tag: n
02-22 03:47:59.616 I/chatty  ( 3407): uid=1000 system_server identical 125 lines
02-22 03:47:59.616 W/AppOps  ( 3407): Unknown attribute in 'op' tag: n
02-22 03:47:59.619 I/IntentFirewall( 3407): Read new rules (A:0 B:0 S:0)
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1003/pid_3376: Device or resource busy
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1003: Permission denied
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1001/pid_3271: Device or resource busy
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1001: Permission denied
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1058/pid_3274: Device or resource busy
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1058: Permission denied
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1066/pid_3267: Device or resource busy
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1066: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1046/pid_3270: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1046: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1036/pid_3157: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1036: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_2000/pid_3258: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_2000: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1040/pid_3265: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1040: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1002/pid_3232: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1002: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1010/pid_3269: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1010/pid_3224: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1010: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1067/pid_3262: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1067: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3229: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3247: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3160: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3245: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3235: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3169: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3159: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3243: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3251: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3241: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3246: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3244: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3272: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3158: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3242: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3250: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3240: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000: Permission denied
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1019/pid_3255: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1019: Permission denied
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1047/pid_3233: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1047/pid_3260: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1047: Permission denied
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1017/pid_3264: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1017: Permission denied
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3230: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3220: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3249: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3219: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3275: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3170: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3273: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3263: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3308: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_2540: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3221: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_2539: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3268: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3248: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3168: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3148: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0: Permission denied
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013/pid_3237: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013/pid_3253: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013/pid_3266: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013/pid_3254: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013/pid_3234: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013: Permission denied
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1041/pid_3231: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1041/pid_3252: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1041: Permission denied
02-22 03:47:59.629 D/AppOps  ( 3407): AppOpsService published
02-22 03:47:59.629 D/SystemServerTiming( 3407): StartActivityManager took to complete: 103ms
02-22 03:47:59.629 I/SystemServer( 3407): StartPowerManager
02-22 03:47:59.629 I/SystemServiceManager( 3407): Starting com.android.server.power.PowerManagerService
02-22 03:47:59.632 D/SystemServerTiming( 3407): StartPowerManager took to complete: 3ms
02-22 03:47:59.632 I/SystemServer( 3407): InitPowerManagement
02-22 03:47:59.633 D/SystemServerTiming( 3407): InitPowerManagement took to complete: 1ms
02-22 03:47:59.633 I/SystemServer( 3407): StartRecoverySystemService
02-22 03:47:59.633 I/SystemServiceManager( 3407): Starting com.android.server.RecoverySystemService
02-22 03:47:59.634 D/SystemServerTiming( 3407): StartRecoverySystemService took to complete: 0ms
02-22 03:47:59.634 V/RescueParty( 3407): Disabled because of active USB connection
02-22 03:47:59.634 I/SystemServer( 3407): StartLightsService
02-22 03:47:59.634 I/SystemServiceManager( 3407): Starting com.android.server.lights.LightsService
02-22 03:47:59.635 D/SystemServerTiming( 3407): StartLightsService took to complete: 0ms
02-22 03:47:59.635 I/SystemServer( 3407): StartSidekickService
02-22 03:47:59.635 D/SystemServerTiming( 3407): StartSidekickService took to complete: 0ms
02-22 03:47:59.635 I/SystemServer( 3407): StartDisplayManager
02-22 03:47:59.635 I/SystemServiceManager( 3407): Starting com.android.server.display.DisplayManagerService
02-22 03:47:59.637 D/SystemServerTiming( 3407): StartDisplayManager took to complete: 3ms
02-22 03:47:59.637 I/SystemServer( 3407): WaitForDisplay
02-22 03:47:59.637 I/SystemServiceManager( 3407): Starting phase 100
02-22 03:47:59.650 I/DisplayManagerService( 3407): Display device added: DisplayDeviceInfo{"内置屏幕": uniqueId="local:0", 1920 x 1080, modeId 1, defaultModeId 1, supportedModes [{id=1, width=1920, height=1080, fps=60.000004}], colorMode 0, supportedColorModes [0], HdrCapabilities android.view.Display$HdrCapabilities@40f3c928, density 213, 320.0 x 320.0 dpi, appVsyncOff 1000000, presDeadline 16666666, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
02-22 03:47:59.651 D/SurfaceFlinger( 3250): Set power mode=2, type=0 flinger=0xfa0244858000
02-22 03:47:59.653 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:47:59.653 D/SystemServerTiming( 3407): WaitForDisplay took to complete: 16ms
02-22 03:47:59.653 I/SystemServer( 3407): StartPackageManagerService
02-22 03:47:59.653 I/DisplayManagerService( 3407): Display device changed state: "内置屏幕", ON
02-22 03:47:59.666 D/SELinuxMMAC( 3407): Using policy file /system/etc/selinux/plat_mac_permissions.xml
02-22 03:47:59.667 D/SELinuxMMAC( 3407): Using policy file /vendor/etc/selinux/vendor_mac_permissions.xml
02-22 03:47:59.670 D/FallbackCategoryProvider( 3407): Found 1 fallback categories
02-22 03:47:59.778 E/display ( 3242): threadLoop invalid uevent remove@/bus/pci/drivers/hif_pci
02-22 03:47:59.782 D/PackageManager( 3407): No files in app dir /product/overlay
02-22 03:47:59.785 W/PackageManager( 3407): Failed to parse /system/framework/oat: Missing base APK in /system/framework/oat
02-22 03:47:59.785 W/PackageManager( 3407): Failed to parse /system/framework/arm64: Missing base APK in /system/framework/arm64
02-22 03:47:59.786 W/PackageManager( 3407): Failed to parse /system/framework/arm: Missing base APK in /system/framework/arm
02-22 03:47:59.798 E/display ( 3242): threadLoop invalid uevent remove@/module/wlan
02-22 03:47:59.822 E/        ( 3247): retrying to open(FSL_SENS_HUB)
02-22 03:47:59.888 I/ServiceManager( 3268): Waiting for service package_native...
02-22 03:47:59.890 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:47:59.913 D/PackageManager( 3407): No files in app dir /vendor/priv-app
02-22 03:47:59.920 D/PackageManager( 3407): No files in app dir /odm/priv-app
02-22 03:47:59.920 D/PackageManager( 3407): No files in app dir /odm/app
02-22 03:47:59.920 D/PackageManager( 3407): No files in app dir /oem/app
02-22 03:47:59.921 D/PackageManager( 3407): No files in app dir /system/product/priv-app
02-22 03:47:59.921 D/PackageManager( 3407): No files in app dir /system/product/app
02-22 03:47:59.921 I/PackageManager( 3407): Finished scanning system apps. Time: 148 ms, packageCount: 88 , timePerPackage: 1 , cached: 88
02-22 03:47:59.941 W/PackageParser( 3407): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.MOUNT_UNMOUNT_FILESYSTEMS in package: com.neolix.videoRecorder at: Binary XML file line #14
02-22 03:47:59.942 I/PackageBackwardCompatibility( 3407): Loaded android.content.pm.OrgApacheHttpLegacyUpdater
02-22 03:47:59.942 I/PackageBackwardCompatibility( 3407): Could not find android.content.pm.AndroidTestBaseUpdater, ignoring
02-22 03:47:59.944 D/PackageManager( 3407): No files in app dir /data/app-private
02-22 03:47:59.944 I/PackageManager( 3407): Finished scanning non-system apps. Time: 23 ms, packageCount: 2 , timePerPackage: 11 , cached: 1
02-22 03:47:59.948 I/PackageManager( 3407): Time to scan packages: 0.174 seconds
02-22 03:47:59.952 V/PackageManager( 3407): reconcileAppsData for null u0 0x1 migrateAppData=true
02-22 03:47:59.948 W/Binder:3263_1( 3263): type=1400 audit(0.0:576): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
02-22 03:47:59.948 W/Binder:3263_1( 3263): type=1400 audit(0.0:577): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
02-22 03:47:59.955 I/SELinux ( 3263): SELinux: Loaded file_contexts
02-22 03:47:59.952 W/Binder:3263_1( 3263): type=1400 audit(0.0:578): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
02-22 03:48:00.001 V/PackageManager( 3407): reconcileAppsData finished 21 packages
02-22 03:48:00.003 D/SystemServerInitThreadPool( 3407): Started executing prepareAppData
02-22 03:47:59.952 I/chatty  ( 3263): uid=0(root) Binder:3263_2 identical 2 lines
02-22 03:47:59.952 W/Binder:3263_1( 3263): type=1400 audit(0.0:581): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
02-22 03:48:00.067 E/PackageManager( 3407): There should probably be a verifier, but, none were found
02-22 03:48:00.071 D/PackageManager( 3407): Ephemeral resolver NOT found; no matching intent filters
02-22 03:48:00.071 D/PackageManager( 3407): Instant App installer not found with android.intent.action.INSTALL_INSTANT_APP_PACKAGE
02-22 03:48:00.071 D/PackageManager( 3407): Clear ephemeral installer activity
02-22 03:48:00.077 W/installd( 3263): Ignoring /data/data/X3Spv81RIFil,BUIjwMwoKeHaoG/vhKpxfcYk38h9tv274NSbB with unexpected GID 0 instead of 10056
02-22 03:48:00.117 D/SystemServerTimingAsync( 3407): AppDataFixup took to complete: 114ms
02-22 03:48:00.164 I/system_server( 3407): Explicit concurrent copying GC freed 19932(1048KB) AllocSpace objects, 8(292KB) LOS objects, 42% free, 3MB/5MB, paused 88us total 86.356ms
02-22 03:48:00.166 D/SystemServerTiming( 3407): StartPackageManagerService took to complete: 513ms
02-22 03:48:00.167 I/SystemServer( 3407): StartOtaDexOptService
02-22 03:48:00.168 D/OTADexopt( 3407): No upgrade, skipping A/B artifacts check.
02-22 03:48:00.168 D/SystemServerTiming( 3407): StartOtaDexOptService took to complete: 0ms
02-22 03:48:00.168 I/SystemServer( 3407): StartUserManagerService
02-22 03:48:00.168 I/SystemServiceManager( 3407): Starting com.android.server.pm.UserManagerService$LifeCycle
02-22 03:48:00.169 D/SystemServerTiming( 3407): StartUserManagerService took to complete: 0ms
02-22 03:48:00.169 I/SystemServer( 3407): InitAttributerCache
02-22 03:48:00.169 D/SystemServerTiming( 3407): InitAttributerCache took to complete: 0ms
02-22 03:48:00.169 I/SystemServer( 3407): SetSystemProcess
02-22 03:48:00.175 I/lowmemorykiller( 3249): lmkd data connection established
02-22 03:48:00.176 D/SystemServerTiming( 3407): SetSystemProcess took to complete: 7ms
02-22 03:48:00.180 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.soundtrigger@2.0::ISoundTriggerHw/default in either framework or device manifest.
02-22 03:48:00.180 E/SoundTriggerHwService( 3252): could not read implementation properties
02-22 03:48:00.182 I/SystemServer( 3407): StartOverlayManagerService
02-22 03:48:00.183 D/SystemServerTiming( 3407): StartOverlayManagerService took to complete: 1ms
02-22 03:48:00.183 D/SystemServerInitThreadPool( 3407): Started executing Init OverlayManagerService
02-22 03:48:00.184 I/SystemServer( 3407): StartBatteryService
02-22 03:48:00.184 D/SystemServerInitThreadPool( 3407): Started executing StartSensorService
02-22 03:48:00.184 I/SystemServiceManager( 3407): Starting com.android.server.BatteryService
02-22 03:48:00.184 D/SensorService( 3407): nuSensorService starting...
02-22 03:48:00.188 I/ServiceManagement( 3407): getService: Trying again for android.hardware.sensors@1.0::ISensors/default...
02-22 03:48:00.188 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.health@2.0::IHealth
02-22 03:48:00.212 E/LightsService( 3407): Light requested not available on this device. 3
02-22 03:48:00.213 E/KernelUidCpuFreqTimeReader( 3407): Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
02-22 03:48:00.214 I/chatty  ( 3407): uid=1000(system) batterystats-wo identical 1 line
02-22 03:48:00.218 E/KernelUidCpuFreqTimeReader( 3407): Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
02-22 03:48:00.251 I/storaged( 3268): storaged: Start
02-22 03:48:00.252 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
02-22 03:48:00.253 I/HealthServiceWrapper( 3407): health: HealthServiceWrapper listening to instance default
02-22 03:48:00.253 I/BatteryService( 3407): health: Waited 1ms and received the update.
02-22 03:48:00.255 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.health@2.0::IHealth
02-22 03:48:00.255 W/SystemServiceManager( 3407): Service com.android.server.BatteryService took 71 ms in onStart
02-22 03:48:00.255 D/SystemServerTiming( 3407): StartBatteryService took to complete: 72ms
02-22 03:48:00.255 I/SystemServer( 3407): StartUsageService
02-22 03:48:00.255 I/SystemServiceManager( 3407): Starting com.android.server.usage.UsageStatsService
02-22 03:48:00.277 I/UsageStatsService( 3407): User[0] Rollover scheduled @ 2020-02-23 02:46:02(1582425962694)
02-22 03:48:00.278 D/SystemServerTiming( 3407): StartUsageService took to complete: 22ms
02-22 03:48:00.278 I/SystemServer( 3407): StartWebViewUpdateService
02-22 03:48:00.278 I/SystemServiceManager( 3407): Starting com.android.server.webkit.WebViewUpdateService
02-22 03:48:00.281 D/SystemServerTiming( 3407): StartWebViewUpdateService took to complete: 3ms
02-22 03:48:00.281 I/SystemServer( 3407): StartBinderCallsStatsService
02-22 03:48:00.281 D/SystemServerTiming( 3407): StartBinderCallsStatsService took to complete: 1ms
02-22 03:48:00.282 I/SystemServer( 3407): StartKeyAttestationApplicationIdProviderService
02-22 03:48:00.282 D/SystemServerInitThreadPool( 3407): Started executing SecondaryZygotePreload
02-22 03:48:00.282 I/SystemServer( 3407): SecondaryZygotePreload
02-22 03:48:00.283 D/SystemServerTiming( 3407): StartKeyAttestationApplicationIdProviderService took to complete: 1ms
02-22 03:48:00.283 I/SystemServer( 3407): StartKeyChainSystemService
02-22 03:48:00.283 I/SystemServiceManager( 3407): Starting com.android.server.security.KeyChainSystemService
02-22 03:48:00.283 I/Zygote  ( 3407): Process: zygote socket RESERVED/zygote opened, supported ABIS: arm64-v8a
02-22 03:48:00.283 D/SystemServerTiming( 3407): StartKeyChainSystemService took to complete: 1ms
02-22 03:48:00.283 I/SystemServer( 3407): StartSchedulingPolicyService
02-22 03:48:00.285 D/SystemServerTiming( 3407): StartSchedulingPolicyService took to complete: 1ms
02-22 03:48:00.285 I/SystemServer( 3407): StartTelecomLoaderService
02-22 03:48:00.285 I/SystemServiceManager( 3407): Starting com.android.server.telecom.TelecomLoaderService
02-22 03:48:00.285 D/SystemServerTiming( 3407): StartTelecomLoaderService took to complete: 0ms
02-22 03:48:00.285 I/SystemServer( 3407): StartTelephonyRegistry
02-22 03:48:00.287 D/SystemServerTiming( 3407): StartTelephonyRegistry took to complete: 2ms
02-22 03:48:00.287 I/SystemServer( 3407): StartEntropyMixer
02-22 03:48:00.291 W/EntropyMixer( 3407): Failed to add HW RNG output to entropy pool
02-22 03:48:00.291 W/EntropyMixer( 3407): java.io.IOException: read failed: ENODEV (No such device)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at libcore.io.IoBridge.read(IoBridge.java:511)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at java.io.FileInputStream.read(FileInputStream.java:307)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.RandomBlock.fromStream(RandomBlock.java:56)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.RandomBlock.fromFile(RandomBlock.java:46)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.EntropyMixer.addHwRandomEntropy(EntropyMixer.java:205)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.EntropyMixer.<init>(EntropyMixer.java:115)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.EntropyMixer.<init>(EntropyMixer.java:97)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.SystemServer.startOtherServices(SystemServer.java:829)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.SystemServer.run(SystemServer.java:447)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.SystemServer.main(SystemServer.java:300)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at java.lang.reflect.Method.invoke(Native Method)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:893)
02-22 03:48:00.291 W/EntropyMixer( 3407): Caused by: android.system.ErrnoException: read failed: ENODEV (No such device)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at libcore.io.Linux.readBytes(Native Method)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at libcore.io.Linux.read(Linux.java:184)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at libcore.io.BlockGuardOs.read(BlockGuardOs.java:254)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at libcore.io.IoBridge.read(IoBridge.java:501)
02-22 03:48:00.291 W/EntropyMixer( 3407):  ... 12 more
02-22 03:48:00.291 I/EntropyMixer( 3407): Writing entropy...
02-22 03:48:00.297 D/SystemServerTiming( 3407): StartEntropyMixer took to complete: 9ms
02-22 03:48:00.297 I/SystemServer( 3407): StartAccountManagerService
02-22 03:48:00.297 I/SystemServiceManager( 3407): Starting com.android.server.accounts.AccountManagerService$Lifecycle
02-22 03:48:00.301 D/SystemServerTiming( 3407): StartAccountManagerService took to complete: 5ms
02-22 03:48:00.301 I/SystemServer( 3407): StartContentService
02-22 03:48:00.301 I/SystemServiceManager( 3407): Starting com.android.server.content.ContentService$Lifecycle
02-22 03:48:00.303 D/SystemServerTiming( 3407): StartContentService took to complete: 2ms
02-22 03:48:00.303 I/SystemServer( 3407): InstallSystemProviders
02-22 03:48:00.304 I/Zygote  ( 3407): Process: zygote socket RESERVED/zygote_secondary opened, supported ABIS: armeabi-v7a,armeabi
02-22 03:48:00.315 I/Zygote  ( 3221): Lazily preloading resources.
02-22 03:48:00.315 D/Zygote  ( 3221): begin preload
02-22 03:48:00.315 I/Zygote  ( 3221): Installing ICU cache reference pinning...
02-22 03:48:00.315 I/Zygote  ( 3221): Preloading ICU data...
02-22 03:48:00.327 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:48:00.331 D/ZygoteInitTiming_lazy( 3221): BeginIcuCachePinning took to complete: 15ms
02-22 03:48:00.331 I/Zygote  ( 3221): Preloading classes...
02-22 03:48:00.356 D/SystemServerTiming( 3407): InstallSystemProviders took to complete: 52ms
02-22 03:48:00.356 I/SystemServer( 3407): StartDropBoxManager
02-22 03:48:00.356 I/SystemServiceManager( 3407): Starting com.android.server.DropBoxManagerService
02-22 03:48:00.357 D/SystemServerTiming( 3407): StartDropBoxManager took to complete: 1ms
02-22 03:48:00.357 I/SystemServer( 3407): StartVibratorService
02-22 03:48:00.358 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.vibrator@1.0::IVibrator/default in either framework or device manifest.
02-22 03:48:00.359 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.vibrator@1.0::IVibrator/default in either framework or device manifest.
02-22 03:48:00.359 E/VibratorService( 3407): vibratorOff command failed (1).
02-22 03:48:00.362 D/SystemServerTiming( 3407): StartVibratorService took to complete: 4ms
02-22 03:48:00.362 I/SystemServer( 3407): StartConsumerIrService
02-22 03:48:00.363 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.ir@1.0::IConsumerIr/default in either framework or device manifest.
02-22 03:48:00.364 D/SystemServerTiming( 3407): StartConsumerIrService took to complete: 1ms
02-22 03:48:00.364 I/SystemServer( 3407): StartAlarmManagerService
02-22 03:48:00.364 I/SystemServiceManager( 3407): Starting com.android.server.AlarmManagerService
02-22 03:48:00.365 D/AlarmManagerService( 3407): Kernel timezone updated to 0 minutes west of GMT
02-22 03:48:00.370 D/SystemServerTiming( 3407): StartAlarmManagerService took to complete: 6ms
02-22 03:48:00.370 I/SystemServer( 3407): InitWatchdog
02-22 03:48:00.370 D/SystemServerTiming( 3407): InitWatchdog took to complete: 1ms
02-22 03:48:00.370 I/SystemServer( 3407): StartInputManagerService
02-22 03:48:00.371 I/InputManager( 3407): Initializing input manager, mUseDevInputEventForAudioJack=false
02-22 03:48:00.372 D/SystemServerTiming( 3407): StartInputManagerService took to complete: 1ms
02-22 03:48:00.372 I/SystemServer( 3407): StartWindowManagerService
02-22 03:48:00.404 I/Zygote  ( 3221): ...preloaded 0 classes in 73ms.
02-22 03:48:00.404 I/zygote  ( 3221): VMRuntime.preloadDexCaches starting
02-22 03:48:00.480 I/zygote  ( 3221): VMRuntime.preloadDexCaches strings total=339243 before=12303 after=12303
02-22 03:48:00.480 I/zygote  ( 3221): VMRuntime.preloadDexCaches types total=31355 before=7818 after=7820
02-22 03:48:00.480 I/zygote  ( 3221): VMRuntime.preloadDexCaches fields total=140849 before=9174 after=9174
02-22 03:48:00.480 I/zygote  ( 3221): VMRuntime.preloadDexCaches methods total=247792 before=12783 after=12783
02-22 03:48:00.480 I/zygote  ( 3221): VMRuntime.preloadDexCaches finished
02-22 03:48:00.480 D/ZygoteInitTiming_lazy( 3221): PreloadClasses took to complete: 149ms
02-22 03:48:00.514 I/zygote  ( 3221): Background concurrent copying GC freed 25398(3MB) AllocSpace objects, 160(2MB) LOS objects, 49% free, 2MB/4MB, paused 378us total 103.375ms
02-22 03:48:00.520 I/zygote  ( 3221): Thread[6,tid=3493,Native,Thread*=0xf3d68000,peer=0x13200088,"Thread-1"] recursive attempt to load library "/system/lib/libmedia_jni.so"
02-22 03:48:00.521 D/MtpDeviceJNI( 3221): register_android_mtp_MtpDevice
02-22 03:48:00.521 I/zygote  ( 3221): Thread[6,tid=3493,Native,Thread*=0xf3d68000,peer=0x13200088,"Thread-1"] recursive attempt to load library "/system/lib/libmedia_jni.so"
02-22 03:48:00.588 I/Zygote  ( 3221): Preloading resources...
02-22 03:48:00.597 W/Resources( 3221): Preloaded drawable resource #0x1080265 (android:drawable/dialog_background_material) that varies with configuration!!
02-22 03:48:00.616 I/Zygote  ( 3221): ...preloaded 64 resources in 28ms.
02-22 03:48:00.621 I/Zygote  ( 3221): ...preloaded 41 resources in 5ms.
02-22 03:48:00.621 D/ZygoteInitTiming_lazy( 3221): PreloadResources took to complete: 140ms
02-22 03:48:00.636 D/SystemServerInitThreadPool( 3407): Finished executing Init OverlayManagerService
02-22 03:48:00.636 D/SystemServerInitThreadPool( 3407): Started executing SchedulingPolicyService.<init>
02-22 03:48:00.642 I/SchedulingPolicyService( 3407): Moving 3270 back to group default
02-22 03:48:00.643 D/SystemServerInitThreadPool( 3407): Finished executing SchedulingPolicyService.<init>
02-22 03:48:00.654 D/libEGL  ( 3221): loaded /vendor/lib/egl/libEGL_VIVANTE.so
02-22 03:48:00.660 D/SystemServerTimingAsync( 3407): AppDataPrepare took to complete: 543ms
02-22 03:48:00.661 I/PackageManager( 3407): Deferred reconcileAppsData finished 69 packages
02-22 03:48:00.661 D/SystemServerInitThreadPool( 3407): Finished executing prepareAppData
02-22 03:48:00.677 D/libEGL  ( 3221): loaded /vendor/lib/egl/libGLESv1_CM_VIVANTE.so
02-22 03:48:00.745 D/libEGL  ( 3221): loaded /vendor/lib/egl/libGLESv2_VIVANTE.so
02-22 03:48:00.798 I/Zygote  ( 3221): Preloading shared libraries...
02-22 03:48:00.809 I/Zygote  ( 3221): Uninstalled ICU cache reference pinning...
02-22 03:48:00.810 I/Zygote  ( 3221): Installed AndroidKeyStoreProvider in 1ms.
02-22 03:48:00.831 I/Zygote  ( 3221): Warmed up JCA providers in 21ms.
02-22 03:48:00.831 D/Zygote  ( 3221): end preload
02-22 03:48:00.831 D/SystemServerTimingAsync( 3407): SecondaryZygotePreload took to complete: 549ms
02-22 03:48:00.831 D/SystemServerInitThreadPool( 3407): Finished executing SecondaryZygotePreload
02-22 03:48:00.890 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:00.922 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:48:01.188 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:01.922 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:01.962 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:48:02.188 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:02.962 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:02.962 D/        ( 3247): sendrolon press sensor init
02-22 03:48:02.962 E/        ( 3247): Can`t find the press sensor!
02-22 03:48:03.010 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:48:03.188 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:04.010 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:04.074 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:48:04.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:05.074 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:05.142 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:48:05.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:06.142 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:06.142 D/        ( 3247): sendrolon press sensor init
02-22 03:48:06.142 E/        ( 3247): Can`t find the press sensor!
02-22 03:48:06.182 E/        ( 3247): couldn't find 'isl29023 light sensor' input device
02-22 03:48:06.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:07.182 E/        ( 3247): retrying to open(isl29023 light sensor)
02-22 03:48:07.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:07.214 E/        ( 3247): couldn't find 'isl29023 light sensor' input device
02-22 03:48:08.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:08.214 E/        ( 3247): retrying to open(isl29023 light sensor)
02-22 03:48:08.254 E/        ( 3247): couldn't find 'isl29023 light sensor' input device
02-22 03:48:09.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:09.254 E/        ( 3247): retrying to open(isl29023 light sensor)
02-22 03:48:09.254 E//vendor/bin/hw/android.hardware.sensors@1.0-service( 3247): HAL specifies version 1.4, but does not implement inject_sensor_data()
02-22 03:48:09.254 E//vendor/bin/hw/android.hardware.sensors@1.0-service( 3247): HAL specifies version 1.4, but does not implement set_operation_mode()
02-22 03:48:09.255 I/ServiceManagement( 3247): Removing namespace from process name android.hardware.sensors@1.0-service to sensors@1.0-service.
02-22 03:48:09.255 I/android.hardware.sensors@1.0-service( 3247): Registration complete for android.hardware.sensors@1.0::ISensors/default.
02-22 03:48:09.256 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleAccelerometer/enable" (No such file or directory).
02-22 03:48:09.256 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleMagnetometer/enable" (No such file or directory).
02-22 03:48:09.256 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleGyroscope/enable" (No such file or directory).
02-22 03:48:09.256 D/        ( 3247): FSLSensorsHub sensor waht = 1 , enable = 0
02-22 03:48:09.256 D/        ( 3247): FSLSensorsHub sensor waht = 2 , enable = 0
02-22 03:48:09.257 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleAccelerometer/enable" (No such file or directory).
02-22 03:48:09.257 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleMagnetometer/enable" (No such file or directory).
02-22 03:48:09.257 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleGyroscope/enable" (No such file or directory).
02-22 03:48:09.257 D/        ( 3247): FSLSensorsHub sensor waht = 4 , enable = 0
02-22 03:48:09.258 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleAccelerometer/enable" (No such file or directory).
02-22 03:48:09.258 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleMagnetometer/enable" (No such file or directory).
02-22 03:48:09.258 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleGyroscope/enable" (No such file or directory).
02-22 03:48:09.258 D/        ( 3247): FSLSensorsHub sensor waht = 3 , enable = 0
02-22 03:48:09.258 D/        ( 3247): FSLSensorsHub sensor waht = 5 , enable = 0
02-22 03:48:09.258 D/        ( 3247): PressSensor mEnabled 0, Temperature mEnabled 0
02-22 03:48:09.259 D/        ( 3247): PressSensor mEnabled 0, Temperature mEnabled 0
02-22 03:48:09.266 D/SensorService( 3407): nuSensorService thread starting...
02-22 03:48:09.267 D/SensorService( 3407): new thread SensorEventAckReceiver
02-22 03:48:09.267 D/SystemServerTimingAsync( 3407): StartSensorService took to complete: 9084ms
02-22 03:48:09.267 D/SystemServerInitThreadPool( 3407): Finished executing StartSensorService
02-22 03:48:09.270 I/WindowManager( 3407): No existing display settings /data/system/display_settings.xml; starting empty
02-22 03:48:09.281 D/SystemServerTiming( 3407): StartWindowManagerService took to complete: 8909ms
02-22 03:48:09.281 I/SystemServer( 3407): SetWindowManagerService
02-22 03:48:09.299 D/SystemServerTiming( 3407): SetWindowManagerService took to complete: 19ms
02-22 03:48:09.299 I/SystemServer( 3407): WindowManagerServiceOnInitReady
02-22 03:48:09.315 D/SystemServerTiming( 3407): WindowManagerServiceOnInitReady took to complete: 16ms
02-22 03:48:09.315 D/SystemServerInitThreadPool( 3407): Started executing StartHidlServices
02-22 03:48:09.316 I/SystemServer( 3407): StartVrManagerService
02-22 03:48:09.316 I/SystemServiceManager( 3407): Starting com.android.server.vr.VrManagerService
02-22 03:48:09.317 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.vr@1.0::IVr/default in either framework or device manifest.
02-22 03:48:09.317 W/VrManagerService( 3407): init_native: Could not open IVr interface
02-22 03:48:09.317 D/SystemServerTimingAsync( 3407): StartHidlServices took to complete: 2ms
02-22 03:48:09.317 D/SystemServerInitThreadPool( 3407): Finished executing StartHidlServices
02-22 03:48:09.317 D/SystemServerTiming( 3407): StartVrManagerService took to complete: 2ms
02-22 03:48:09.317 I/SystemServer( 3407): StartInputManager
02-22 03:48:09.318 I/InputManager( 3407): Starting input manager
02-22 03:48:09.320 D/SystemServerTiming( 3407): StartInputManager took to complete: 2ms
02-22 03:48:09.320 I/SystemServer( 3407): DisplayManagerWindowManagerAndInputReady
02-22 03:48:09.320 D/SystemServerTiming( 3407): DisplayManagerWindowManagerAndInputReady took to complete: 0ms
02-22 03:48:09.320 I/SystemServer( 3407): StartBluetoothService
02-22 03:48:09.320 I/SystemServiceManager( 3407): Starting com.android.server.BluetoothService
02-22 03:48:09.321 D/BluetoothManagerService( 3407): Loading stored name and address
02-22 03:48:09.322 D/BluetoothManagerService( 3407): Stored bluetooth Name=iMX8,Address=null
02-22 03:48:09.322 D/BluetoothManagerService( 3407): Bluetooth persisted state: 0
02-22 03:48:09.322 D/BluetoothManagerService( 3407): Detected SystemUiUid: 10012
02-22 03:48:09.322 D/SystemServerTiming( 3407): StartBluetoothService took to complete: 2ms
02-22 03:48:09.322 I/SystemServer( 3407): IpConnectivityMetrics
02-22 03:48:09.322 I/SystemServiceManager( 3407): Starting com.android.server.connectivity.IpConnectivityMetrics
02-22 03:48:09.323 D/SystemServerTiming( 3407): IpConnectivityMetrics took to complete: 1ms
02-22 03:48:09.323 I/SystemServer( 3407): NetworkWatchlistService
02-22 03:48:09.323 I/SystemServiceManager( 3407): Starting com.android.server.net.watchlist.NetworkWatchlistService$Lifecycle
02-22 03:48:09.324 D/EventHub( 3407): No input device configuration file found for device 'sc-powerkey'.
02-22 03:48:09.327 I/WatchlistSettings( 3407): Reload watchlist settings done
02-22 03:48:09.328 I/WatchlistLoggingHandler( 3407): No need to aggregate record yet.
02-22 03:48:09.328 I/WatchlistLoggingHandler( 3407): Milliseconds spent on tryAggregateRecords(): 0
02-22 03:48:09.328 D/SystemServerTiming( 3407): NetworkWatchlistService took to complete: 5ms
02-22 03:48:09.328 I/SystemServer( 3407): PinnerService
02-22 03:48:09.328 I/SystemServiceManager( 3407): Starting com.android.server.PinnerService
02-22 03:48:09.332 W/EventHub( 3407): Unable to disable kernel key repeat for /dev/input/event0: Function not implemented
02-22 03:48:09.332 I/EventHub( 3407): wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
02-22 03:48:09.332 I/EventHub( 3407): New device: id=1, fd=114, path='/dev/input/event0', name='sc-powerkey', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/Generic.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false,
02-22 03:48:09.332 D/SystemServerTiming( 3407): PinnerService took to complete: 4ms
02-22 03:48:09.332 I/SystemServer( 3407): StartInputMethodManagerLifecycle
02-22 03:48:09.332 I/SystemServiceManager( 3407): Starting com.android.server.InputMethodManagerService$Lifecycle
02-22 03:48:09.337 I/InputReader( 3407): Device added: id=-1, name='Virtual', sources=0x00000301
02-22 03:48:09.337 I/InputReader( 3407): Device added: id=1, name='sc-powerkey', sources=0x00000101
02-22 03:48:09.338 D/SystemServerTiming( 3407): StartInputMethodManagerLifecycle took to complete: 6ms
02-22 03:48:09.338 I/SystemServer( 3407): StartAccessibilityManagerService
02-22 03:48:09.342 D/SystemServerTiming( 3407): StartAccessibilityManagerService took to complete: 4ms
02-22 03:48:09.342 I/SystemServer( 3407): MakeDisplayReady
02-22 03:48:09.344 I/ActivityManager( 3407): Config changes=20005df8 {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h811dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1080) mWindowingMode=fullscreen mActivityType=undefined} s.2}
02-22 03:48:09.350 I/ActivityManager( 3407): Override config changes=60007dfc {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h811dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1080) mWindowingMode=fullscreen mActivityType=undefined} s.2} for displayId=0
02-22 03:48:09.358 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:09.358 I/ActivityManager( 3407): Config changes=20000400 {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.3}
02-22 03:48:09.363 I/ActivityManager( 3407): Override config changes=20000400 {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.3} for displayId=0
02-22 03:48:09.372 D/SystemServerTiming( 3407): MakeDisplayReady took to complete: 29ms
02-22 03:48:09.373 I/SystemServer( 3407): StartStorageManagerService
02-22 03:48:09.373 I/SystemServiceManager( 3407): Starting com.android.server.StorageManagerService$Lifecycle
02-22 03:48:09.379 D/SystemServerTiming( 3407): StartStorageManagerService took to complete: 6ms
02-22 03:48:09.379 I/SystemServer( 3407): StartStorageStatsService
02-22 03:48:09.379 I/SystemServiceManager( 3407): Starting com.android.server.usage.StorageStatsService$Lifecycle
02-22 03:48:09.380 D/StorageManagerService( 3407): Thinking about init, mSystemReady=false, mDaemonConnected=true
02-22 03:48:09.380 D/StorageManagerService( 3407): Thinking about reset, mSystemReady=false, mDaemonConnected=true
02-22 03:48:09.358 I/chatty  ( 3407): uid=1000(system) InputReader identical 1 line
02-22 03:48:09.373 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:09.381 D/installd( 3263): Found quota mount /dev/block/by-name/userdata at /data
02-22 03:48:09.384 D/SystemServerTiming( 3407): StartStorageStatsService took to complete: 5ms
02-22 03:48:09.384 I/SystemServer( 3407): StartUiModeManager
02-22 03:48:09.384 I/SystemServiceManager( 3407): Starting com.android.server.UiModeManagerService
02-22 03:48:09.386 D/SystemServerInitThreadPool( 3407): Started executing UiModeManager.onStart
02-22 03:48:09.386 I/ActivityManager( 3407): Config changes=200 {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.4}
02-22 03:48:09.389 D/SystemServerTiming( 3407): StartUiModeManager took to complete: 5ms
02-22 03:48:09.389 I/SystemServer( 3407): UpdatePackagesIfNeeded
02-22 03:48:09.389 D/SystemServerTiming( 3407): UpdatePackagesIfNeeded took to complete: 0ms
02-22 03:48:09.389 I/SystemServer( 3407): PerformFstrimIfNeeded
02-22 03:48:09.390 D/SystemServerTiming( 3407): PerformFstrimIfNeeded took to complete: 1ms
02-22 03:48:09.390 I/SystemServer( 3407): StartLockSettingsService
02-22 03:48:09.390 I/SystemServiceManager( 3407): Starting com.android.server.locksettings.LockSettingsService$Lifecycle
02-22 03:48:09.400 I/ActivityManager( 3407): Override config changes=200 {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.4} for displayId=0
02-22 03:48:09.404 D/SystemServerInitThreadPool( 3407): Finished executing UiModeManager.onStart
02-22 03:48:09.407 D/SystemServerTiming( 3407): StartLockSettingsService took to complete: 17ms
02-22 03:48:09.407 I/SystemServer( 3407): StartPersistentDataBlock
02-22 03:48:09.407 I/SystemServiceManager( 3407): Starting com.android.server.PersistentDataBlockService
02-22 03:48:09.408 D/SystemServerTiming( 3407): StartPersistentDataBlock took to complete: 0ms
02-22 03:48:09.408 I/SystemServer( 3407): StartOemLockService
02-22 03:48:09.408 D/SystemServerInitThreadPool( 3407): Started executing PersistentDataBlockService.onStart
02-22 03:48:09.408 I/SystemServiceManager( 3407): Starting com.android.server.oemlock.OemLockService
02-22 03:48:09.382 D/installd( 3263): Found quota mount /dev/block/by-name/userdata at /data
02-22 03:48:09.408 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.oemlock@1.0::IOemLock/default in either framework or device manifest.
02-22 03:48:09.409 E/PersistentDataBlockService( 3407): not able to find package
02-22 03:48:09.409 E/PersistentDataBlockService( 3407): android.content.pm.PackageManager$NameNotFoundException:
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at android.app.ApplicationPackageManager.getPackageUidAsUser(ApplicationPackageManager.java:299)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.server.PersistentDataBlockService.getAllowedUid(PersistentDataBlockService.java:113)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.server.PersistentDataBlockService.lambda$onStart$0(PersistentDataBlockService.java:126)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.server.-$$Lambda$PersistentDataBlockService$EZl9OYaT2eNL7kfSr2nKUBjxidk.run(Unknown Source:2)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.server.SystemServerInitThreadPool.lambda$submit$0(SystemServerInitThreadPool.java:64)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.server.-$$Lambda$SystemServerInitThreadPool$7wfLGkZF7FvYZv7xj3ghvuiJJGk.run(Unknown Source:4)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:458)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.internal.util.ConcurrentUtils$1$1.run(ConcurrentUtils.java:62)
02-22 03:48:09.409 I/OemLock ( 3407): OemLock HAL not present on device
02-22 03:48:09.409 I/OemLock ( 3407): Using persistent data block based lock
02-22 03:48:09.410 D/SystemServerTiming( 3407): StartOemLockService took to complete: 3ms
02-22 03:48:09.410 I/SystemServer( 3407): StartDeviceIdleController
02-22 03:48:09.410 I/SystemServiceManager( 3407): Starting com.android.server.DeviceIdleController
02-22 03:48:09.413 D/SystemServerTiming( 3407): StartDeviceIdleController took to complete: 3ms
02-22 03:48:09.413 I/SystemServer( 3407): StartDevicePolicyManager
02-22 03:48:09.413 I/SystemServiceManager( 3407): Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
02-22 03:48:09.418 D/SystemServerTiming( 3407): StartDevicePolicyManager took to complete: 5ms
02-22 03:48:09.418 I/SystemServer( 3407): StartStatusBarManagerService
02-22 03:48:09.419 D/SystemServerTiming( 3407): StartStatusBarManagerService took to complete: 1ms
02-22 03:48:09.419 I/SystemServer( 3407): StartClipboardService
02-22 03:48:09.419 I/SystemServiceManager( 3407): Starting com.android.server.clipboard.ClipboardService
02-22 03:48:09.420 D/SystemServerTiming( 3407): StartClipboardService took to complete: 1ms
02-22 03:48:09.420 I/SystemServer( 3407): StartNetworkManagementService
02-22 03:48:09.422 I/NetworkManagement( 3407): onDaemonConnected()
02-22 03:48:09.423 D/SystemServerTiming( 3407): StartNetworkManagementService took to complete: 3ms
02-22 03:48:09.423 I/SystemServer( 3407): StartIpSecService
02-22 03:48:09.425 D/SystemServerTiming( 3407): StartIpSecService took to complete: 2ms
02-22 03:48:09.425 I/SystemServer( 3407): StartTextServicesManager
02-22 03:48:09.425 I/SystemServiceManager( 3407): Starting com.android.server.TextServicesManagerService$Lifecycle
02-22 03:48:09.427 D/SystemServerTiming( 3407): StartTextServicesManager took to complete: 1ms
02-22 03:48:09.427 I/SystemServer( 3407): StartTextClassificationManagerService
02-22 03:48:09.427 I/SystemServiceManager( 3407): Starting com.android.server.textclassifier.TextClassificationManagerService$Lifecycle
02-22 03:48:09.428 D/SystemServerTiming( 3407): StartTextClassificationManagerService took to complete: 1ms
02-22 03:48:09.428 I/SystemServer( 3407): StartNetworkScoreService
02-22 03:48:09.428 I/SystemServiceManager( 3407): Starting com.android.server.NetworkScoreService$Lifecycle
02-22 03:48:09.429 I/NetworkScoreService( 3407): Registering network_score
02-22 03:48:09.430 D/SystemServerInitThreadPool( 3407): Finished executing PersistentDataBlockService.onStart
02-22 03:48:09.430 D/SystemServerTiming( 3407): StartNetworkScoreService took to complete: 3ms
02-22 03:48:09.430 I/SystemServer( 3407): StartNetworkStatsService
02-22 03:48:09.433 D/SystemServerTiming( 3407): StartNetworkStatsService took to complete: 2ms
02-22 03:48:09.433 I/SystemServer( 3407): StartNetworkPolicyManagerService
02-22 03:48:09.436 D/SystemServerTiming( 3407): StartNetworkPolicyManagerService took to complete: 4ms
02-22 03:48:09.436 I/SystemServer( 3407): StartWifi
02-22 03:48:09.439 I/SystemServiceManager( 3407): Starting com.android.server.wifi.WifiService
02-22 03:48:09.512 D/WifiApConfigStore( 3407): 2G band allowed channels are:1,6,11
02-22 03:48:09.519 I/WifiScoringParams( 3407): rssi2=-85:-85:-73:-60,rssi5=-82:-82:-70:-57,pps=0:1:100,horizon=15,nud=8,expid=0
02-22 03:48:09.545 D/WifiStateMachine( 3407): EnableConnectedMacRandomization Setting changed to false
02-22 03:48:09.545 E/WifiStateMachine( 3407): getWifiLinkLayerStats called without an interface
02-22 03:48:09.546 D/WifiStateMachinePrime( 3407): Starting Wifi in WifiDisabledState
02-22 03:48:09.546 D/WifiStateMachinePrime( 3407): Entering WifiDisabledState
02-22 03:48:09.546 D/ActiveModeManager( 3407): sending scan available broadcast: false
02-22 03:48:09.547 D/WifiOpenNetworkNotifier( 3407): Settings toggle enabled=true
02-22 03:48:09.547 D/WifiCarrierNetworkNotifier( 3407): Settings toggle enabled=true
02-22 03:48:09.548 D/WakeupController( 3407): WifiWake enabled
02-22 03:48:09.549 D/WifiController( 3407): isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false, isLocationModeActive = true
02-22 03:48:09.551 E/SupplicantStaIfaceHal( 3407): Can't call setDebugParams, ISupplicant is null
02-22 03:48:09.551 W/WifiDiags( 3407): no ring buffers found
02-22 03:48:09.551 W/WifiDiags( 3407): Failed to start packet fate monitoring
02-22 03:48:09.552 I/WifiService( 3407): Registering wifi
02-22 03:48:09.552 D/SystemServerTiming( 3407): StartWifi took to complete: 116ms
02-22 03:48:09.552 I/SystemServer( 3407): StartWifiScanning
02-22 03:48:09.553 I/SystemServiceManager( 3407): Starting com.android.server.wifi.scanner.WifiScanningService
02-22 03:48:09.553 I/WifiScanningService( 3407): Creating wifiscanner
02-22 03:48:09.554 I/WifiScanningService( 3407): Publishing wifiscanner
02-22 03:48:09.555 D/SystemServerTiming( 3407): StartWifiScanning took to complete: 3ms
02-22 03:48:09.555 I/SystemServer( 3407): StartWifiP2P
02-22 03:48:09.555 I/SystemServiceManager( 3407): Starting com.android.server.wifi.p2p.WifiP2pService
02-22 03:48:09.561 W/HalDevMgr( 3407): isWifiStarted called but mWifi is null!?
02-22 03:48:09.561 I/WifiP2pService( 3407): Registering wifip2p
02-22 03:48:09.562 D/SystemServerTiming( 3407): StartWifiP2P took to complete: 7ms
02-22 03:48:09.562 I/SystemServer( 3407): StartEthernet
02-22 03:48:09.563 I/SystemServiceManager( 3407): Starting com.android.server.ethernet.EthernetService
02-22 03:48:09.563 I/EthernetService( 3407): Registering service ethernet
02-22 03:48:09.564 D/SystemServerTiming( 3407): StartEthernet took to complete: 1ms
02-22 03:48:09.564 I/SystemServer( 3407): StartConnectivityService
02-22 03:48:09.565 D/ConnectivityService( 3407): ConnectivityService starting up
02-22 03:48:09.567 D/ConnectivityService( 3407): wifiOnly=true
02-22 03:48:09.567 E/ConnectivityService( 3407): Ignoring protectedNetwork 10
02-22 03:48:09.567 E/ConnectivityService( 3407): Ignoring protectedNetwork 11
02-22 03:48:09.567 E/ConnectivityService( 3407): Ignoring protectedNetwork 12
02-22 03:48:09.567 E/ConnectivityService( 3407): Ignoring protectedNetwork 14
02-22 03:48:09.567 E/ConnectivityService( 3407): Ignoring protectedNetwork 15
02-22 03:48:09.575 D/SystemServerTiming( 3407): StartConnectivityService took to complete: 12ms
02-22 03:48:09.575 I/SystemServer( 3407): StartNsdService
02-22 03:48:09.576 D/NsdService( 3407): Network service discovery is enabled
02-22 03:48:09.577 D/SystemServerTiming( 3407): StartNsdService took to complete: 2ms
02-22 03:48:09.578 I/SystemServer( 3407): StartSystemUpdateManagerService
02-22 03:48:09.578 I/SystemUpdateManagerService( 3407): No existing info file /data/system/system-update-info.xml
02-22 03:48:09.578 D/SystemServerTiming( 3407): StartSystemUpdateManagerService took to complete: 1ms
02-22 03:48:09.578 I/SystemServer( 3407): StartUpdateLockService
02-22 03:48:09.579 D/SystemServerTiming( 3407): StartUpdateLockService took to complete: 1ms
02-22 03:48:09.580 I/SystemServer( 3407): StartNotificationManager
02-22 03:48:09.580 I/SystemServiceManager( 3407): Starting com.android.server.notification.NotificationManagerService
02-22 03:48:09.584 D/ConditionProviders.SCP( 3407): new ScheduleConditionProvider()
02-22 03:48:09.594 I/NotificationListeners( 3407): Read notification listener permissions from xml
02-22 03:48:09.595 I/NotificationAssistants( 3407): Read notification assistant permissions from xml
02-22 03:48:09.595 I/ConditionProviders( 3407): Read condition provider permissions from xml
02-22 03:48:09.598 D/SystemServerTiming( 3407): StartNotificationManager took to complete: 19ms
02-22 03:48:09.598 I/SystemServer( 3407): StartDeviceMonitor
02-22 03:48:09.598 I/SystemServiceManager( 3407): Starting com.android.server.storage.DeviceStorageMonitorService
02-22 03:48:09.600 D/SystemServerTiming( 3407): StartDeviceMonitor took to complete: 2ms
02-22 03:48:09.600 I/SystemServer( 3407): StartLocationManagerService
02-22 03:48:09.601 D/SystemServerTiming( 3407): StartLocationManagerService took to complete: 0ms
02-22 03:48:09.601 I/SystemServer( 3407): StartCountryDetectorService
02-22 03:48:09.601 D/SystemServerTiming( 3407): StartCountryDetectorService took to complete: 1ms
02-22 03:48:09.601 I/SystemServer( 3407): StartSearchManagerService
02-22 03:48:09.601 I/SystemServiceManager( 3407): Starting com.android.server.search.SearchManagerService$Lifecycle
02-22 03:48:09.602 D/SystemServerTiming( 3407): StartSearchManagerService took to complete: 1ms
02-22 03:48:09.603 I/SystemServer( 3407): StartWallpaperManagerService
02-22 03:48:09.603 I/SystemServiceManager( 3407): Starting com.android.server.wallpaper.WallpaperManagerService$Lifecycle
02-22 03:48:09.604 D/SystemServerTiming( 3407): StartWallpaperManagerService took to complete: 1ms
02-22 03:48:09.604 I/SystemServer( 3407): StartAudioService
02-22 03:48:09.604 I/SystemServiceManager( 3407): Starting com.android.server.audio.AudioService$Lifecycle
02-22 03:48:09.606 W/TelecomManager( 3407): Telecom Service not found.
02-22 03:48:09.608 D/PermissionCache( 3252): checking android.permission.MODIFY_AUDIO_ROUTING for uid=1000 => granted (704 us)
02-22 03:48:09.608 D/PermissionCache( 3252): checking android.permission.MODIFY_AUDIO_SETTINGS for uid=1000 => granted (754 us)
02-22 03:48:09.609 W/AudioFlinger( 3252): no wake lock to update, system not ready yet
02-22 03:48:09.610 W/DeviceHAL( 3231): Error from HAL Device in function set_mic_mute: Function not implemented
02-22 03:48:09.620 D/AudioFlinger( 3252): isLowRamDevice:false totalMemory:5996650496 mClientSharedHeapSize:33554432
02-22 03:48:09.621 D/SystemServerTiming( 3407): StartAudioService took to complete: 18ms
02-22 03:48:09.621 I/SystemServer( 3407): StartDockObserver
02-22 03:48:09.621 I/SystemServiceManager( 3407): Starting com.android.server.DockObserver
02-22 03:48:09.622 W/DockObserver( 3407): This kernel does not have dock station support
02-22 03:48:09.623 D/SystemServerTiming( 3407): StartDockObserver took to complete: 2ms
02-22 03:48:09.623 I/SystemServer( 3407): StartWiredAccessoryManager
02-22 03:48:09.624 W/WiredAccessoryManager( 3407): This kernel does not have wired headset support
02-22 03:48:09.624 W/WiredAccessoryManager( 3407): This kernel does not have usb audio support
02-22 03:48:09.624 W/WiredAccessoryManager( 3407): This kernel does not have HDMI audio support
02-22 03:48:09.624 D/SystemServerTiming( 3407): StartWiredAccessoryManager took to complete: 1ms
02-22 03:48:09.624 I/SystemServer( 3407): StartUsbService
02-22 03:48:09.624 I/SystemServiceManager( 3407): Starting com.android.server.usb.UsbService$Lifecycle
02-22 03:48:09.625 E/UsbDeviceManager( 3407): failed to write to /sys/class/android_usb/android0/f_rndis/ethaddr
02-22 03:48:09.628 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.usb.gadget@1.0::IUsbGadget
02-22 03:48:09.649 W/StorageManagerService( 3407): No primary storage defined yet; hacking together a stub
02-22 03:48:09.650 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
02-22 03:48:09.651 I/UsbDeviceManager( 3407): Usb gadget hal service started android.hardware.usb.gadget@1.0::IUsbGadget default
02-22 03:48:09.651 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.usb.gadget@1.0::IUsbGadget
02-22 03:48:09.653 E/UsbDeviceManager( 3407): prcessing MSG_GET_CURRENT_USB_FUNCTIONS
02-22 03:48:09.653 E/UsbDeviceManager( 3407): updating mCurrentFunctions
02-22 03:48:09.653 E/UsbDeviceManager( 3407): mCurrentFunctions:0applied:1
02-22 03:48:09.653 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.usb.gadget@1.0::IUsbGadget
02-22 03:48:09.659 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
02-22 03:48:09.660 I/UsbPortManager( 3407): Usb hal service started android.hardware.usb@1.0::IUsb default
02-22 03:48:09.660 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.usb@1.0::IUsb
02-22 03:48:09.661 I/android.hardware.usb@1.1-service.imx( 3248): registering callback
02-22 03:48:09.662 E/android.hardware.usb@1.1-service.imx( 3248): creating thread
02-22 03:48:09.662 I/android.hardware.usb@1.1-service.imx( 3248): port0
02-22 03:48:09.662 I/android.hardware.usb@1.1-service.imx( 3248): connected:1 canChangeMode:1 canChagedata:0 canChangePower:0
02-22 03:48:09.663 D/SystemServerTiming( 3407): StartUsbService took to complete: 38ms
02-22 03:48:09.663 I/SystemServer( 3407): StartSerialService
02-22 03:48:09.663 D/SystemServerTiming( 3407): StartSerialService took to complete: 1ms
02-22 03:48:09.663 I/SystemServer( 3407): StartHardwarePropertiesManagerService
02-22 03:48:09.664 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.thermal@1.0::IThermal/default in either framework or device manifest.
02-22 03:48:09.664 E/HardwarePropertiesManagerService-JNI( 3407): Unable to get Thermal service.
02-22 03:48:09.664 D/SystemServerTiming( 3407): StartHardwarePropertiesManagerService took to complete: 1ms
02-22 03:48:09.664 I/SystemServer( 3407): StartTwilightService
02-22 03:48:09.664 I/SystemServiceManager( 3407): Starting com.android.server.twilight.TwilightService
02-22 03:48:09.665 D/SystemServerTiming( 3407): StartTwilightService took to complete: 0ms
02-22 03:48:09.665 I/SystemServer( 3407): StartJobScheduler
02-22 03:48:09.665 I/SystemServiceManager( 3407): Starting com.android.server.job.JobSchedulerService
02-22 03:48:09.672 D/JobStore( 3407): Start tag: job-info
02-22 03:48:09.674 I/JobStore( 3407): Read 2 jobs
02-22 03:48:09.679 D/SystemServerTiming( 3407): StartJobScheduler took to complete: 15ms
02-22 03:48:09.680 I/SystemServer( 3407): StartSoundTrigger
02-22 03:48:09.680 I/SystemServiceManager( 3407): Starting com.android.server.soundtrigger.SoundTriggerService
02-22 03:48:09.680 D/SystemServerTiming( 3407): StartSoundTrigger took to complete: 1ms
02-22 03:48:09.680 I/SystemServer( 3407): StartTrustManager
02-22 03:48:09.680 I/SystemServiceManager( 3407): Starting com.android.server.trust.TrustManagerService
02-22 03:48:09.681 D/SystemServerTiming( 3407): StartTrustManager took to complete: 1ms
02-22 03:48:09.681 I/SystemServer( 3407): StartBackupManager
02-22 03:48:09.681 I/SystemServiceManager( 3407): Starting com.android.server.backup.BackupManagerService$Lifecycle
02-22 03:48:09.682 D/SystemServerTiming( 3407): StartBackupManager took to complete: 1ms
02-22 03:48:09.682 I/SystemServer( 3407): StartAppWidgerService
02-22 03:48:09.682 I/SystemServiceManager( 3407): Starting com.android.server.appwidget.AppWidgetService
02-22 03:48:09.683 D/OpenGLRenderer( 3407): Skia GL Pipeline
02-22 03:48:09.684 D/SystemServerTiming( 3407): StartAppWidgerService took to complete: 2ms
02-22 03:48:09.685 I/SystemServer( 3407): StartVoiceRecognitionManager
02-22 03:48:09.685 I/SystemServiceManager( 3407): Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
02-22 03:48:09.685 D/SystemServerTiming( 3407): StartVoiceRecognitionManager took to complete: 1ms
02-22 03:48:09.685 I/SystemServer( 3407): StartGestureLauncher
02-22 03:48:09.685 I/SystemServiceManager( 3407): Starting com.android.server.GestureLauncherService
02-22 03:48:09.685 D/SystemServerTiming( 3407): StartGestureLauncher took to complete: 0ms
02-22 03:48:09.686 I/SystemServer( 3407): StartSensorNotification
02-22 03:48:09.686 I/SystemServiceManager( 3407): Starting com.android.server.SensorNotificationService
02-22 03:48:09.686 D/SystemServerTiming( 3407): StartSensorNotification took to complete: 0ms
02-22 03:48:09.686 I/SystemServer( 3407): StartContextHubSystemService
02-22 03:48:09.686 I/SystemServiceManager( 3407): Starting com.android.server.ContextHubSystemService
02-22 03:48:09.686 D/SystemServerTiming( 3407): StartContextHubSystemService took to complete: 1ms
02-22 03:48:09.686 D/SystemServerInitThreadPool( 3407): Started executing Init ContextHubSystemService
02-22 03:48:09.686 I/SystemServer( 3407): StartDiskStatsService
02-22 03:48:09.687 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.contexthub@1.0::IContexthub/default in either framework or device manifest.
02-22 03:48:09.687 I/ContextHubService( 3407): Context Hub HAL service not found
02-22 03:48:09.687 D/SystemServerInitThreadPool( 3407): Finished executing Init ContextHubSystemService
02-22 03:48:09.688 D/SystemServerTiming( 3407): StartDiskStatsService took to complete: 2ms
02-22 03:48:09.688 I/SystemServer( 3407): StartNetworkTimeUpdateService
02-22 03:48:09.689 D/SystemServerTiming( 3407): StartNetworkTimeUpdateService took to complete: 1ms
02-22 03:48:09.689 I/SystemServer( 3407): StartCommonTimeManagementService
02-22 03:48:09.690 D/SystemServerTiming( 3407): StartCommonTimeManagementService took to complete: 0ms
02-22 03:48:09.690 I/SystemServer( 3407): CertBlacklister
02-22 03:48:09.691 D/SystemServerTiming( 3407): CertBlacklister took to complete: 0ms
02-22 03:48:09.691 I/SystemServer( 3407): StartEmergencyAffordanceService
02-22 03:48:09.691 I/SystemServiceManager( 3407): Starting com.android.server.emergency.EmergencyAffordanceService
02-22 03:48:09.691 D/SystemServerTiming( 3407): StartEmergencyAffordanceService took to complete: 1ms
02-22 03:48:09.691 I/SystemServer( 3407): StartDreamManager
02-22 03:48:09.691 I/SystemServiceManager( 3407): Starting com.android.server.dreams.DreamManagerService
02-22 03:48:09.692 D/SystemServerTiming( 3407): StartDreamManager took to complete: 1ms
02-22 03:48:09.692 I/SystemServer( 3407): AddGraphicsStatsService
02-22 03:48:09.694 D/SystemServerTiming( 3407): AddGraphicsStatsService took to complete: 1ms
02-22 03:48:09.695 I/SystemServer( 3407): StartPrintManager
02-22 03:48:09.695 I/SystemServiceManager( 3407): Starting com.android.server.print.PrintManagerService
02-22 03:48:09.696 D/SystemServerTiming( 3407): StartPrintManager took to complete: 2ms
02-22 03:48:09.697 I/SystemServer( 3407): StartCompanionDeviceManager
02-22 03:48:09.697 I/SystemServiceManager( 3407): Starting com.android.server.companion.CompanionDeviceManagerService
02-22 03:48:09.698 D/SystemServerTiming( 3407): StartCompanionDeviceManager took to complete: 2ms
02-22 03:48:09.698 I/SystemServer( 3407): StartRestrictionManager
02-22 03:48:09.698 I/SystemServiceManager( 3407): Starting com.android.server.restrictions.RestrictionsManagerService
02-22 03:48:09.699 D/SystemServerTiming( 3407): StartRestrictionManager took to complete: 0ms
02-22 03:48:09.699 I/SystemServer( 3407): StartMediaSessionService
02-22 03:48:09.699 I/SystemServiceManager( 3407): Starting com.android.server.media.MediaSessionService
02-22 03:48:09.701 D/SystemServerTiming( 3407): StartMediaSessionService took to complete: 2ms
02-22 03:48:09.701 I/SystemServer( 3407): StartMediaUpdateService
02-22 03:48:09.701 I/SystemServiceManager( 3407): Starting com.android.server.media.MediaUpdateService
02-22 03:48:09.702 D/SystemServerTiming( 3407): StartMediaUpdateService took to complete: 1ms
02-22 03:48:09.702 I/SystemServer( 3407): StartMediaResourceMonitor
02-22 03:48:09.703 I/SystemServiceManager( 3407): Starting com.android.server.media.MediaResourceMonitorService
02-22 03:48:09.703 D/SystemServerTiming( 3407): StartMediaResourceMonitor took to complete: 1ms
02-22 03:48:09.703 I/SystemServer( 3407): StartMediaRouterService
02-22 03:48:09.704 D/SystemServerTiming( 3407): StartMediaRouterService took to complete: 1ms
02-22 03:48:09.704 I/SystemServer( 3407): StartBackgroundDexOptService
02-22 03:48:09.704 W/BackgroundDexOptService( 3407): SysProp pm.dexopt.downgrade_after_inactive_days not set
02-22 03:48:09.705 D/SystemServerTiming( 3407): StartBackgroundDexOptService took to complete: 1ms
02-22 03:48:09.705 I/SystemServer( 3407): StartPruneInstantAppsJobService
02-22 03:48:09.705 D/SystemServerTiming( 3407): StartPruneInstantAppsJobService took to complete: 0ms
02-22 03:48:09.705 I/SystemServer( 3407): StartShortcutServiceLifecycle
02-22 03:48:09.706 I/SystemServiceManager( 3407): Starting com.android.server.pm.ShortcutService$Lifecycle
02-22 03:48:09.708 D/SystemServerTiming( 3407): StartShortcutServiceLifecycle took to complete: 3ms
02-22 03:48:09.708 I/SystemServer( 3407): StartLauncherAppsService
02-22 03:48:09.708 I/SystemServiceManager( 3407): Starting com.android.server.pm.LauncherAppsService
02-22 03:48:09.708 D/SystemServerTiming( 3407): StartLauncherAppsService took to complete: 0ms
02-22 03:48:09.709 I/SystemServer( 3407): StartCrossProfileAppsService
02-22 03:48:09.709 I/SystemServiceManager( 3407): Starting com.android.server.pm.CrossProfileAppsService
02-22 03:48:09.709 D/SystemServerTiming( 3407): StartCrossProfileAppsService took to complete: 1ms
02-22 03:48:09.709 I/SystemServer( 3407): StartMediaProjectionManager
02-22 03:48:09.709 I/SystemServiceManager( 3407): Starting com.android.server.media.projection.MediaProjectionManagerService
02-22 03:48:09.710 V/MediaRouter( 3407): Adding route: RouteInfo{ name=平板电脑, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:09.711 V/MediaRouter( 3407): Selecting route: RouteInfo{ name=平板电脑, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:09.712 D/SystemServerTiming( 3407): StartMediaProjectionManager took to complete: 2ms
02-22 03:48:09.712 I/SystemServer( 3407): StartSliceManagerService
02-22 03:48:09.712 I/SystemServiceManager( 3407): Starting com.android.server.slice.SliceManagerService$Lifecycle
02-22 03:48:09.714 D/SystemServerTiming( 3407): StartSliceManagerService took to complete: 2ms
02-22 03:48:09.714 I/SystemServer( 3407): StartCameraServiceProxy
02-22 03:48:09.714 I/SystemServiceManager( 3407): Starting com.android.server.camera.CameraServiceProxy
02-22 03:48:09.716 D/SystemServerTiming( 3407): StartCameraServiceProxy took to complete: 2ms
02-22 03:48:09.717 I/SystemServer( 3407): StartStatsCompanionService
02-22 03:48:09.717 I/SystemServiceManager( 3407): Starting com.android.server.stats.StatsCompanionService$Lifecycle
02-22 03:48:09.718 E/KernelUidCpuFreqTimeReader( 3407): Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
02-22 03:48:09.718 D/SystemServerTiming( 3407): StartStatsCompanionService took to complete: 2ms
02-22 03:48:09.719 I/WindowManager( 3407): SAFE MODE not enabled
02-22 03:48:09.719 I/SystemServer( 3407): StartJitCompilation
02-22 03:48:09.719 D/SystemServerTiming( 3407): StartJitCompilation took to complete: 0ms
02-22 03:48:09.719 I/SystemServer( 3407): StartMmsService
02-22 03:48:09.719 I/SystemServiceManager( 3407): Starting com.android.server.MmsServiceBroker
02-22 03:48:09.720 D/SystemServerTiming( 3407): StartMmsService took to complete: 1ms
02-22 03:48:09.720 I/SystemServer( 3407): StartAutoFillService
02-22 03:48:09.720 I/SystemServiceManager( 3407): Starting com.android.server.autofill.AutofillManagerService
02-22 03:48:09.721 I/AutofillManagerService( 3407): Setting debug to true
02-22 03:48:09.722 D/SystemServerTiming( 3407): StartAutoFillService took to complete: 2ms
02-22 03:48:09.722 I/SystemServer( 3407): MakeVibratorServiceReady
02-22 03:48:09.724 D/SystemServerTiming( 3407): MakeVibratorServiceReady took to complete: 1ms
02-22 03:48:09.724 I/SystemServer( 3407): MakeLockSettingsServiceReady
02-22 03:48:09.748 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.weaver@1.0::IWeaver/default in either framework or device manifest.
02-22 03:48:09.748 I/SyntheticPasswordManager( 3407): Device does not support weaver
02-22 03:48:09.748 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.authsecret@1.0::IAuthSecret/default in either framework or device manifest.
02-22 03:48:09.748 I/LockSettingsService( 3407): Device doesn't implement AuthSecret HAL
02-22 03:48:09.752 E/LockSettingsStorage( 3407): Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
02-22 03:48:09.752 E/LockSettingsStorage( 3407): Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.gesture.key: open failed: ENOENT (No such file or directory)
02-22 03:48:09.753 E/LockSettingsStorage( 3407): Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
02-22 03:48:09.753 D/SystemServerTiming( 3407): MakeLockSettingsServiceReady took to complete: 29ms
02-22 03:48:09.753 I/SystemServer( 3407): StartBootPhaseLockSettingsReady
02-22 03:48:09.753 I/SystemServiceManager( 3407): Starting phase 480
02-22 03:48:09.757 I/DevicePolicyManager( 3407): Set ro.device_owner property to false
02-22 03:48:09.759 D/SystemServerInitThreadPool( 3407): Started executing DevicePolicyManager
02-22 03:48:09.759 D/SystemServerInitThreadPool( 3407): Finished executing DevicePolicyManager
02-22 03:48:09.761 D/SystemServerTiming( 3407): StartBootPhaseLockSettingsReady took to complete: 8ms
02-22 03:48:09.762 I/SystemServer( 3407): StartBootPhaseSystemServicesReady
02-22 03:48:09.762 I/SystemServiceManager( 3407): Starting phase 500
02-22 03:48:09.764 D/AppStandbyController( 3407): Setting app idle enabled state
02-22 03:48:09.768 I/VrManagerService( 3407): No default vr listener service found.
02-22 03:48:09.773 I/WifiService( 3407): WifiService starting up with Wi-Fi disabled
02-22 03:48:09.776 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
02-22 03:48:09.776 D/HalDevMgr( 3407): IWifi registration notification: fqName=android.hardware.wifi@1.0::IWifi, name=default, preexisting=true
02-22 03:48:09.778 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.wifi@1.0::IWifi
02-22 03:48:09.780 D/WificondControl( 3407): tearing down interfaces in wificond
02-22 03:48:09.782 I/WifiScanningService( 3407): Starting wifiscanner
02-22 03:48:09.787 I/EthernetServiceImpl( 3407): Starting Ethernet service
02-22 03:48:09.792 D/Ethernet( 3407): Registering NetworkFactory
02-22 03:48:09.792 D/ConnectivityService( 3407): Got NetworkFactory Messenger for Ethernet
02-22 03:48:09.793 D/Ethernet( 3407): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:09.793 E/IpConfigStore( 3407): Error opening configuration file: java.io.FileNotFoundException: /data/misc/ethernet/ipconfig.txt (No such file or directory)
02-22 03:48:09.796 I/EthernetTracker( 3407): maybeTrackInterface eth0
02-22 03:48:09.799 D/CommandListener( 3219): Setting iface cfg
02-22 03:48:09.799 D/CommandListener( 3219): Trying to bring up eth0
02-22 03:48:09.800 D/PermissionCache( 3252): checking android.permission.CAPTURE_AUDIO_HOTWORD for uid=1000 => granted (100 us)
02-22 03:48:09.800 W/SoundTriggerHelper( 3407): listModules status=0, # of modules=0
02-22 03:48:09.801 D/ContextHubSystemService( 3407): onBootPhase: PHASE_SYSTEM_SERVICES_READY
02-22 03:48:09.802 D/SystemServerTiming( 3407): StartBootPhaseSystemServicesReady took to complete: 41ms
02-22 03:48:09.802 I/SystemServer( 3407): MakeWindowManagerServiceReady
02-22 03:48:09.806 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.configstore@1.0::ISurfaceFlingerConfigs
02-22 03:48:09.806 D/SystemServerTiming( 3407): MakeWindowManagerServiceReady took to complete: 4ms
02-22 03:48:09.807 I/SystemServer( 3407): MakePowerManagerServiceReady
02-22 03:48:09.816 W/KeyguardServiceDelegate( 3407): onScreenTurningOn(): no keyguard service!
02-22 03:48:09.816 W/KernelCpuProcReader( 3407): File not exist: /proc/uid_cpupower/concurrent_active_time
02-22 03:48:09.816 W/KernelCpuProcReader( 3407): File not exist: /proc/uid_cpupower/concurrent_policy_time
02-22 03:48:09.819 D/SystemServerTiming( 3407): MakePowerManagerServiceReady took to complete: 11ms
02-22 03:48:09.819 I/SystemServer( 3407): MakePackageManagerServiceReady
02-22 03:48:09.824 D/WifiStateMachinePrime( 3407): received a message in WifiDisabledState: { when=0 what=3 target=com.android.internal.util.StateMachine$SmHandler }
02-22 03:48:09.824 D/WifiStateMachinePrime( 3407): Switching from WifiDisabledState to WifiDisabled
02-22 03:48:09.824 D/WifiStateMachinePrime( 3407): Entering WifiDisabledState
02-22 03:48:09.824 D/ActiveModeManager( 3407): sending scan available broadcast: false
02-22 03:48:09.835 V/UserDataPreparer( 3407): Found /data/user_de/0 with serial number 0
02-22 03:48:09.835 V/UserDataPreparer( 3407): Found /data/user/0 with serial number 0
02-22 03:48:09.835 V/UserDataPreparer( 3407): Found /data/system_de/0 with serial number 0
02-22 03:48:09.835 V/UserDataPreparer( 3407): Found /data/system_ce/0 with serial number 0
02-22 03:48:09.835 V/UserDataPreparer( 3407): Found /data/misc_ce/0 with serial number 0
02-22 03:48:09.837 D/SystemServerTiming( 3407): MakePackageManagerServiceReady took to complete: 18ms
02-22 03:48:09.837 I/SystemServer( 3407): MakeDisplayManagerServiceReady
02-22 03:48:09.837 D/SystemServerTiming( 3407): MakeDisplayManagerServiceReady took to complete: 0ms
02-22 03:48:09.837 I/SystemServer( 3407): StartDeviceSpecificServices
02-22 03:48:09.838 D/SystemServerTiming( 3407): StartDeviceSpecificServices took to complete: 0ms
02-22 03:48:09.838 I/SystemServer( 3407): StartBootPhaseDeviceSpecificServicesReady
02-22 03:48:09.838 I/SystemServiceManager( 3407): Starting phase 520
02-22 03:48:09.839 D/SystemServerTiming( 3407): StartBootPhaseDeviceSpecificServicesReady took to complete: 1ms
02-22 03:48:09.840 W/UsageStatsService( 3407): Event reported without a package name
02-22 03:48:09.843 I/AppOps  ( 3407): Pruning old package system/com.android.server.AppOpsService$UidState@75a4c8d: new uid=-1
02-22 03:48:09.844 I/ActivityManager( 3407): System now ready
02-22 03:48:09.847 I/ActivityManager( 3407): Config changes=104 {1.0 ?mcc?mnc [zh_CN_#Hans,en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.5}
02-22 03:48:09.885 W/JHwRemoteBinder( 3407): BinderProxy is being destroyed but the application did not call unlinkToDeath to unlink all of its death recipients beforehand.  Releasing leaked death recipient: com.android.server.usb.UsbDeviceManager$UsbHandlerHal$UsbGadgetDeathRecipient
02-22 03:48:09.886 I/ActivityManager( 3407): Override config changes=104 {1.0 ?mcc?mnc [zh_CN_#Hans,en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.5} for displayId=0
02-22 03:48:09.886 W/System  ( 3407): A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks.
02-22 03:48:09.887 W/System  ( 3407): java.lang.Throwable: Explicit termination method 'close' not called
02-22 03:48:09.887 W/System  ( 3407):  at dalvik.system.CloseGuard.open(CloseGuard.java:221)
02-22 03:48:09.887 W/System  ( 3407):  at java.io.FileInputStream.<init>(FileInputStream.java:168)
02-22 03:48:09.887 W/System  ( 3407):  at com.android.internal.os.AtomicFile.openRead(AtomicFile.java:147)
02-22 03:48:09.887 W/System  ( 3407):  at com.android.server.storage.CacheQuotaStrategy.setupQuotasFromFile(CacheQuotaStrategy.java:301)
02-22 03:48:09.887 W/System  ( 3407):  at com.android.server.usage.StorageStatsService$H.handleMessage(StorageStatsService.java:508)
02-22 03:48:09.887 W/System  ( 3407):  at android.os.Handler.dispatchMessage(Handler.java:106)
02-22 03:48:09.887 W/System  ( 3407):  at android.os.Looper.loop(Looper.java:193)
02-22 03:48:09.887 W/System  ( 3407):  at android.os.HandlerThread.run(HandlerThread.java:65)
02-22 03:48:09.887 W/System  ( 3407):  at com.android.server.ServiceThread.run(ServiceThread.java:44)
02-22 03:48:09.890 I/EthernetTracker( 3407): interfaceLinkStateChanged, iface: eth0, up: false
02-22 03:48:09.897 D/EthernetTracker( 3407): Started tracking interface eth0
02-22 03:48:09.897 D/EthernetNetworkFactory( 3407): addInterface, iface: eth0, capabilities: [ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&NOT_CONGESTED Unwanted:  LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]
02-22 03:48:09.899 D/EthernetNetworkFactory( 3407): starting IpClient(eth0): mNetworkInfo=[type: Ethernet[], state: DISCONNECTED/IDLE, reason: (unspecified), extra: (none), failover: false, available: false, roaming: false]
02-22 03:48:09.903 D/CommandListener( 3219): Clearing all IP addresses on eth0
02-22 03:48:09.903 D/EthernetNetworkFactory( 3407): updateCapabilityFilter: [ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&NOT_CONGESTED Unwanted:  LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]
02-22 03:48:09.903 I/EthernetTracker( 3407): maybeTrackInterface ip6_vti0
02-22 03:48:09.904 I/EthernetTracker( 3407): maybeTrackInterface ip6tnl0
02-22 03:48:09.904 I/EthernetTracker( 3407): maybeTrackInterface ip_vti0
02-22 03:48:09.904 I/EthernetTracker( 3407): maybeTrackInterface lo
02-22 03:48:09.904 I/EthernetTracker( 3407): maybeTrackInterface sit0
02-22 03:48:09.904 D/EthernetNetworkFactory( 3407): updateInterfaceLinkState, iface: eth0, up: false
02-22 03:48:09.913 I/ActivityManager( 3407): Config changes=100 {1.0 ?mcc?mnc [zh_CN_#Hans,en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.6}
02-22 03:48:09.914 I/ActivityManager( 3407): Override config changes=100 {1.0 ?mcc?mnc [zh_CN_#Hans,en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.6} for displayId=0
02-22 03:48:09.916 I/SystemServer( 3407): Making services ready
02-22 03:48:09.916 I/SystemServer( 3407): StartActivityManagerReadyPhase
02-22 03:48:09.917 I/SystemServiceManager( 3407): Starting phase 550
02-22 03:48:09.919 D/DhcpClient( 3407): doQuit
02-22 03:48:09.920 W/ActivityManager( 3407): Too early to start/bind service in system_server: Phase=550 ComponentInfo{com.android.server.telecom/com.android.server.telecom.components.TelecomService}
02-22 03:48:09.921 W/ActivityManager( 3407): Too early to start/bind service in system_server: Phase=550 ComponentInfo{com.android.server.telecom/com.android.server.telecom.components.TelecomService}
02-22 03:48:09.949 D/BluetoothManagerService( 3407): Bluetooth boot completed
02-22 03:48:09.949 D/BluetoothManagerService( 3407): Getting adapter name and address
02-22 03:48:09.949 D/BluetoothManagerService( 3407): MESSAGE_GET_NAME_AND_ADDRESS
02-22 03:48:09.949 D/BluetoothManagerService( 3407): Binding to service to get name and address
02-22 03:48:09.952 D/DhcpClient( 3407): Receive thread started
02-22 03:48:09.952 D/DhcpClient( 3407): Receive thread stopped
02-22 03:48:09.967 I/ActivityManager( 3407): Start proc 3546:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
02-22 03:48:10.006 D/DhcpClient( 3407): onQuitting
02-22 03:48:09.960 W/main    ( 3546): type=1400 audit(0.0:2359): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:09.964 I/chatty  ( 3546): uid=1002(bluetooth) com.android.bluetooth identical 2 lines
02-22 03:48:09.964 W/main    ( 3546): type=1400 audit(0.0:2362): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:10.009 D/CommandListener( 3219): Clearing all IP addresses on eth0
02-22 03:48:10.011 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], score: 0
02-22 03:48:10.012 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], network: NetworkInterfaceState{ iface: eth0, up: false, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: DISCONNECTED/IDLE, reason: (unspecified), extra: (none), failover: false, available: false, roaming: false], networkAgent: null, ipClient: null,linkProperties: {LinkAddresses: []  Routes: [] DnsAddresses: [] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0}}
02-22 03:48:10.012 D/EthernetNetworkFactory( 3407): starting IpClient(eth0): mNetworkInfo=[type: Ethernet[], state: DISCONNECTED/IDLE, reason: (unspecified), extra: (none), failover: false, available: false, roaming: false]
02-22 03:48:10.017 D/CommandListener( 3219): Clearing all IP addresses on eth0
02-22 03:48:10.040 I/droid.bluetoot( 3546): The ClassLoaderContext is a special shared library.
02-22 03:48:10.069 W/SystemServiceManager( 3407): Service com.android.server.InputMethodManagerService$Lifecycle took 117 ms in onBootPhase
02-22 03:48:10.069 D/StorageManagerService( 3407): Thinking about init, mSystemReady=true, mDaemonConnected=true
02-22 03:48:10.069 D/StorageManagerService( 3407): Thinking about reset, mSystemReady=true, mDaemonConnected=true
02-22 03:48:10.070 I/ActivityManager( 3407): Force stopping com.android.providers.media appid=10006 user=-1: vold reset
02-22 03:48:10.072 I/WallpaperManagerService( 3407): No static wallpaper imagery; defaults will be shown
02-22 03:48:10.074 V/StorageManagerService( 3407): Found primary storage at VolumeInfo{emulated}:
02-22 03:48:10.074 V/StorageManagerService( 3407):     type=EMULATED diskId=null partGuid= mountFlags=0 mountUserId=-1
02-22 03:48:10.074 V/StorageManagerService( 3407):     state=UNMOUNTED
02-22 03:48:10.074 V/StorageManagerService( 3407):     fsType=null fsUuid=null fsLabel=null
02-22 03:48:10.074 V/StorageManagerService( 3407):     path=null internalPath=null
02-22 03:48:10.075 I/droid.bluetoot( 3546): The ClassLoaderContext is a special shared library.
02-22 03:48:10.079 E/BitmapFactory( 3407): Unable to decode stream: java.io.FileNotFoundException: /data/system/users/0/wallpaper_orig (No such file or directory)
02-22 03:48:10.079 W/WallpaperManagerService( 3407): Invalid wallpaper data
02-22 03:48:10.079 E/WallpaperManagerService( 3407): Unable to apply new wallpaper
02-22 03:48:10.080 D/DhcpClient( 3407): Broadcasting DHCPDISCOVER
02-22 03:48:10.080 V/vold    ( 3170): Waiting for FUSE to spin up...
02-22 03:48:10.081 D/DhcpClient( 3407): Receive thread started
02-22 03:48:10.082 D/audio_hw_primary( 3231): adev_set_parameters: enter: A2dpSuspended=false
02-22 03:48:10.082 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:10.083 I/AudioService( 3407): setBluetoothScoOnInt: false resetBluetoothSco
02-22 03:48:10.083 D/audio_hw_primary( 3231): adev_set_parameters: enter: BT_SCO=off
02-22 03:48:10.083 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:10.084 D/SystemServerTiming( 3407): StartActivityManagerReadyPhase took to complete: 168ms
02-22 03:48:10.084 I/SystemServer( 3407): StartObservingNativeCrashes
02-22 03:48:10.084 D/BluetoothManagerService( 3407): Trying to bind to profile: 1, while Bluetooth was disabled
02-22 03:48:10.084 I/android.hardware.usb@1.1-service.imx( 3248): port0
02-22 03:48:10.085 D/SystemServerTiming( 3407): StartObservingNativeCrashes took to complete: 0ms
02-22 03:48:10.085 I/android.hardware.usb@1.1-service.imx( 3248): connected:1 canChangeMode:1 canChagedata:0 canChangePower:0
02-22 03:48:10.085 I/SystemServer( 3407): StartSystemUI
02-22 03:48:10.085 D/SystemServerInitThreadPool( 3407): Started executing WebViewFactoryPreparation
02-22 03:48:10.085 I/SystemServer( 3407): WebViewFactoryPreparation
02-22 03:48:10.086 I/UsbPortManager( 3407): ClientCallback: port0
02-22 03:48:10.086 I/UsbPortManager( 3407): USB port added: port=UsbPort{id=port0, supportedModes=dual}, status=UsbPortStatus{connected=true, currentMode=ufp, currentPowerRole=sink, currentDataRole=device, supportedRoleCombinations=[source:host, sink:device]}, canChangeMode=true, canChangePowerRole=false, canChangeDataRole=false
02-22 03:48:10.086 E/BluetoothHearingAid( 3407): Could not bind to Bluetooth Hearing Aid Service with Intent { act=android.bluetooth.IBluetoothHearingAid }
02-22 03:48:10.088 I/AudioFlinger( 3252): systemReady
02-22 03:48:10.094 D/SystemServerTiming( 3407): StartSystemUI took to complete: 9ms
02-22 03:48:10.094 I/SystemServer( 3407): MakeNetworkManagementServiceReady
02-22 03:48:10.095 I/ActivityManager( 3407): Start proc 3573:com.android.inputmethod.latin/u0a63 for service com.android.inputmethod.latin/.LatinIME
02-22 03:48:10.096 D/NetworkManagement( 3407): enabling bandwidth control
02-22 03:48:10.101 W/sdcard  ( 3571): Device explicitly enabled sdcardfs
02-22 03:48:10.110 D/WebViewLibraryLoader( 3407): Setting new address space to 147551200
02-22 03:48:10.119 D/SystemServerTimingAsync( 3407): WebViewFactoryPreparation took to complete: 33ms
02-22 03:48:10.119 D/SystemServerInitThreadPool( 3407): Finished executing WebViewFactoryPreparation
02-22 03:48:10.121 E/linker  ( 3265): library "/system/lib64/extractors/.." ("/system/lib64") needed or dlopened by "/system/lib64/libstagefright.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib64", permitted_paths="/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system/product/lib64:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:10.122 W/MediaExtractorFactory( 3265): couldn't dlopen(/system/lib64/extractors/..) Permission denied
02-22 03:48:10.124 I/ActivityManager( 3407): Start proc 3583:com.android.systemui/u0a12 for service com.android.systemui/.SystemUIService
02-22 03:48:10.137 W/MediaExtractorFactory( 3265): couldn't dlopen(/system/lib64/extractors/.) Is a directory
02-22 03:48:10.153 E/MediaExtractorFactory( 3265): couldn't opendir(/vendor/lib64/extractors)
02-22 03:48:10.167 D/StagefrightPluginLoader( 3254): Failed to load library: libstagefright_ccodec.so (dlopen failed: library "libstagefright_ccodec.so" not found)
02-22 03:48:10.167 D/StagefrightPluginLoader( 3254): Handle or CreateInputSurface symbol is null
02-22 03:48:10.167 D/StagefrightPluginLoader( 3254): Handle or CreateBuilder symbol is null
02-22 03:48:10.169 V/AdapterServiceConfig( 3546): Adding HeadsetService
02-22 03:48:10.169 V/AdapterServiceConfig( 3546): Adding A2dpService
02-22 03:48:10.169 V/AdapterServiceConfig( 3546): Adding HidHostService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding HealthService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding PanService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding GattService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding BluetoothMapService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding AvrcpTargetService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding HidDeviceService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding BluetoothOppService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding BluetoothPbapService
02-22 03:48:10.177 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.178 I/OMXMaster( 3270): makeComponentInstance(OMX.google.aac.decoder) in omx@1.0-service process
02-22 03:48:10.200 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.200 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.audio_decoder.aac.sw-based) in omx@1.0-service process
02-22 03:48:10.088 W/main    ( 3573): type=1400 audit(0.0:2363): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:10.208 I/OMXPlayer( 3270): Can't open library: lib_aacplusd_wrap_arm12_elinux_android.so
02-22 03:48:10.208 I/OMXPlayer( 3270): dlopen failed: library "lib_aacplusd_wrap_arm12_elinux_android.so" not found
02-22 03:48:10.210 I/        ( 3546): [0222/034810.210154:INFO:com_android_bluetooth_btservice_AdapterService.cpp(630)] hal_util_load_bt_library loaded HAL: btinterface=0xff8dfec49430, handle=0x6fce011393bb7ac5
02-22 03:48:10.211 D/BluetoothAdapterService( 3546): onCreate()
02-22 03:48:10.217 D/AdapterState( 3546): make() - Creating AdapterState
02-22 03:48:10.219 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.219 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.audio_decoder.amrnb.sw-based) in omx@1.0-service process
02-22 03:48:10.220 I/bt_btif ( 3546): init
02-22 03:48:10.220 I/AdapterState( 3546): OFF : entered
02-22 03:48:10.220 D/AdapterProperties( 3546): Setting state to OFF
02-22 03:48:10.220 D/bt_osi_allocation_tracker( 3546): canary initialized
02-22 03:48:10.220 I/bt_osi_thread( 3546): run_thread: thread id 3620, thread name stack_manager started
02-22 03:48:10.221 I/bt_stack_manager( 3546): event_init_stack is initializing the stack
02-22 03:48:10.222 E/bt_btif_config( 3546): Config is missing adapter section
02-22 03:48:10.222 W/bt_btif_config( 3546): init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
02-22 03:48:10.223 E/bt_btif_config( 3546): Config is missing adapter section
02-22 03:48:10.223 W/bt_btif_config( 3546): init unable to load backup; attempting to transcode legacy file.
02-22 03:48:10.223 E/bt_btif_config_transcode( 3546): btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
02-22 03:48:10.223 E/bt_btif_config( 3546): init unable to transcode legacy file; creating empty config.
02-22 03:48:10.224 I/bt_osi_thread( 3546): run_thread: thread id 3623, thread name alarm_default_ca started
02-22 03:48:10.224 I/bt_osi_thread( 3546): run_thread: thread id 3624, thread name alarm_dispatcher started
02-22 03:48:10.226 I/bt_btif_core( 3546): btif_init_bluetooth entered
02-22 03:48:10.227 I/bt_stack_config( 3546): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
02-22 03:48:10.229 I/bt_osi_thread( 3546): run_thread: thread id 3626, thread name bt_jni_workqueue started
02-22 03:48:10.229 I/bt_btif_core( 3546): btif_init_bluetooth finished
02-22 03:48:10.229 I/bt_stack_manager( 3546): event_init_stack finished
02-22 03:48:10.229 I/bt_osi_wakelock( 3546): wakelock_set_os_callouts set to non-native
02-22 03:48:10.229 I/bt_btif ( 3546): get_profile_interface: id = socket
02-22 03:48:10.229 W/bt_btif ( 3546): do_in_jni_thread: Dropped message, message_loop not initialized yet!
02-22 03:48:10.229 I/chatty  ( 3546): uid=1002(bluetooth) com.android.bluetooth identical 1 line
02-22 03:48:10.229 I/bt_btif_core( 3546): run_message_loop entered
02-22 03:48:10.231 I/bt_btif ( 3546): get_profile_interface: id = sdp
02-22 03:48:10.233 I/BluetoothAdapterService( 3546): Phone policy enabled
02-22 03:48:10.234 I/OMXPlayer( 3270): SetRoleFormat AMR NB mode.
02-22 03:48:10.237 D/BluetoothActiveDeviceManager( 3546): start()
02-22 03:48:10.238 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.238 I/OMXMaster( 3270): makeComponentInstance(OMX.google.amrnb.decoder) in omx@1.0-service process
02-22 03:48:10.247 D/BluetoothAdapterService( 3546): setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@657a85e
02-22 03:48:10.247 D/BluetoothActiveDeviceManager( 3546): onAudioDevicesAdded
02-22 03:48:10.247 D/BluetoothActiveDeviceManager( 3546): Audio device added: MEK-MX8Q type: 2
02-22 03:48:10.247 D/BluetoothActiveDeviceManager( 3546): Audio device added: MEK-MX8Q type: 15
02-22 03:48:10.249 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.250 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.audio_decoder.amrwb.sw-based) in omx@1.0-service process
02-22 03:48:10.251 D/BluetoothAdapterService( 3546): onBind()
02-22 03:48:10.256 I/OMXPlayer( 3270): SetRoleFormat AMR WB mode.
02-22 03:48:10.259 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.260 I/OMXMaster( 3270): makeComponentInstance(OMX.google.amrwb.decoder) in omx@1.0-service process
02-22 03:48:10.264 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.265 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.audio_decoder.flac.sw-based) in omx@1.0-service process
02-22 03:48:10.274 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.275 I/OMXMaster( 3270): makeComponentInstance(OMX.google.g711.alaw.decoder) in omx@1.0-service process
02-22 03:48:10.282 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.282 I/OMXMaster( 3270): makeComponentInstance(OMX.google.g711.mlaw.decoder) in omx@1.0-service process
02-22 03:48:10.284 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.284 I/OMXMaster( 3270): makeComponentInstance(OMX.google.gsm.decoder) in omx@1.0-service process
02-22 03:48:10.286 W/ZygoteProcess( 3407): Got error connecting to zygote, retrying. msg= Connection refused
02-22 03:48:10.290 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.290 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.audio_decoder.mp3.sw-based) in omx@1.0-service process
02-22 03:48:10.296 I/WebViewZygoteInit( 3651): Starting WebViewZygoteInit
02-22 03:48:10.296 I/WebViewZygoteInit( 3651): --zygote-socket=com.android.internal.os.WebViewZygoteInit/f0642249-e0a6-4656-94b7-17a7125c2826
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: returned from zygote!
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: done updating battery stats
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 184ms so far, now at startProcess: building log message
02-22 03:48:10.301 I/ActivityManager( 3407): Start proc 3666:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewLibraryLoader$RelroFileCreator] for
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 184ms so far, now at startProcess: starting to update pids map
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 184ms so far, now at startProcess: done updating pids map
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: asking zygote to start proc
02-22 03:48:10.304 W/WebViewLoader-( 3666): Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
02-22 03:48:10.304 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.304 I/OMXMaster( 3270): makeComponentInstance(OMX.google.mp3.decoder) in omx@1.0-service process
02-22 03:48:10.313 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.313 I/OMXMaster( 3270): makeComponentInstance(OMX.google.opus.decoder) in omx@1.0-service process
02-22 03:48:10.316 W/ActivityManager( 3407): Slow operation: 198ms so far, now at startProcess: returned from zygote!
02-22 03:48:10.317 W/ActivityManager( 3407): Slow operation: 198ms so far, now at startProcess: done updating battery stats
02-22 03:48:10.317 W/ActivityManager( 3407): Slow operation: 198ms so far, now at startProcess: building log message
02-22 03:48:10.317 I/ActivityManager( 3407): Start proc 3681:WebViewLoader-arm64-v8a/1037 [android.webkit.WebViewLibraryLoader$RelroFileCreator] for
02-22 03:48:10.317 W/ActivityManager( 3407): Slow operation: 198ms so far, now at startProcess: starting to update pids map
02-22 03:48:10.317 W/ActivityManager( 3407): Slow operation: 198ms so far, now at startProcess: done updating pids map
02-22 03:48:10.321 V/WebViewLibraryLoader( 3666): RelroFileCreator (64bit = false), lib: /system/app/webview/webview.apk!/lib/armeabi-v7a/libwebviewchromium.so
02-22 03:48:10.326 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.326 I/OMXMaster( 3270): makeComponentInstance(OMX.google.raw.decoder) in omx@1.0-service process
02-22 03:48:10.344 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.345 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.359 V/WebViewLibraryLoader( 3681): RelroFileCreator (64bit = true), lib: /system/app/webview/webview.apk!/lib/arm64-v8a/libwebviewchromium.so
02-22 03:48:10.362 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.363 I/OMXMaster( 3270): makeComponentInstance(OMX.google.aac.encoder) in omx@1.0-service process
02-22 03:48:10.376 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.376 I/OMXMaster( 3270): makeComponentInstance(OMX.google.amrnb.encoder) in omx@1.0-service process
02-22 03:48:10.435 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.435 I/OMXMaster( 3270): makeComponentInstance(OMX.google.amrwb.encoder) in omx@1.0-service process
02-22 03:48:10.438 I/WebViewLoader-( 3666): System.exit called, status: 0
02-22 03:48:10.438 I/AndroidRuntime( 3666): VM exiting with result code 0, cleanup skipped.
02-22 03:48:10.448 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.448 I/OMXMaster( 3270): makeComponentInstance(OMX.google.flac.encoder) in omx@1.0-service process
02-22 03:48:10.454 I/ActivityManager( 3407): Process WebViewLoader-armeabi-v7a (pid 3666) has died: psvc PER
02-22 03:48:10.455 W/libprocessgroup( 3407): kill(-3666, 9) failed: No such process
02-22 03:48:10.459 I/Zygote  ( 3221): Process 3666 exited cleanly (0)
02-22 03:48:10.468 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.468 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.avc.v3.hw-based) in omx@1.0-service process
02-22 03:48:10.501 W/libprocessgroup( 3407): kill(-3666, 9) failed: No such process
02-22 03:48:10.501 I/libprocessgroup( 3407): Successfully killed process cgroup uid 1037 pid 3666 in 46ms
02-22 03:48:10.533 I/WebViewLoader-( 3681): System.exit called, status: 0
02-22 03:48:10.533 I/AndroidRuntime( 3681): VM exiting with result code 0, cleanup skipped.
02-22 03:48:10.540 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.540 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.541 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.541 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.avc.v3.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.541 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.avc.v3.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.543 I/ActivityManager( 3407): Process WebViewLoader-arm64-v8a (pid 3681) has died: psvc PER
02-22 03:48:10.543 I/Zygote  ( 3220): Process 3681 exited cleanly (0)
02-22 03:48:10.543 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.544 I/OMXMaster( 3270): makeComponentInstance(OMX.google.h264.decoder) in omx@1.0-service process
02-22 03:48:10.544 W/libprocessgroup( 3407): kill(-3681, 9) failed: No such process
02-22 03:48:10.544 I/libprocessgroup( 3407): Successfully killed process cgroup uid 1037 pid 3681 in 0ms
02-22 03:48:10.549 E/OMXNodeInstance( 3270): getExtensionIndex(0xef92c600:google.h264.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.549 E/OMXNodeInstance( 3270): getExtensionIndex(0xef92c600:google.h264.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.551 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.551 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.h263.hw-based) in omx@1.0-service process
02-22 03:48:10.553 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.553 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.554 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.554 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.h263.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.554 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.h263.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.556 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.556 I/OMXMaster( 3270): makeComponentInstance(OMX.google.h263.decoder) in omx@1.0-service process
02-22 03:48:10.560 E/OMXNodeInstance( 3270): getExtensionIndex(0xef92c720:google.h263.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.560 E/OMXNodeInstance( 3270): getExtensionIndex(0xef92c720:google.h263.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.562 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.562 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.hevc.hw-based) in omx@1.0-service process
02-22 03:48:10.564 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.564 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.565 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.565 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.hevc.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.565 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.hevc.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.567 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.567 I/OMXMaster( 3270): makeComponentInstance(OMX.google.hevc.decoder) in omx@1.0-service process
02-22 03:48:10.575 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27d80:google.hevc.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.575 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27d80:google.hevc.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.579 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.579 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.mjpeg.hw-based) in omx@1.0-service process
02-22 03:48:10.582 E/OMXNodeInstance( 3270): getParameter(0xef947f04:Freescale.std._decoder.mjpeg.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.582 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.583 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.583 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.583 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.mjpeg.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.583 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.mjpeg.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.586 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.586 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg2.hw-based) in omx@1.0-service process
02-22 03:48:10.588 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.588 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.588 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.589 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.mpeg2.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.589 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.mpeg2.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.592 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.592 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg4.hw-based) in omx@1.0-service process
02-22 03:48:10.593 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.594 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.594 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.594 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.mpeg4.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.594 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.mpeg4.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.597 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.597 I/OMXMaster( 3270): makeComponentInstance(OMX.google.mpeg4.decoder) in omx@1.0-service process
02-22 03:48:10.598 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27e40:google.mpeg4.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.599 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27e40:google.mpeg4.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.599 W/NetworkManagement( 3407): setDataSaverMode(): already false
02-22 03:48:10.600 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.601 D/SystemServerTiming( 3407): MakeNetworkManagementServiceReady took to complete: 506ms
02-22 03:48:10.601 I/SystemServer( 3407): MakeIpSecServiceReady
02-22 03:48:10.601 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.sorenson.sw-based) in omx@1.0-service process
02-22 03:48:10.602 D/IpSecService( 3407): IpSecService is ready
02-22 03:48:10.602 D/SystemServerTiming( 3407): MakeIpSecServiceReady took to complete: 2ms
02-22 03:48:10.602 I/SystemServer( 3407): MakeNetworkStatsServiceReady
02-22 03:48:10.603 E/BatteryExternalStatsWorker( 3407): no controller energy info supplied for wifi
02-22 03:48:10.603 E/BatteryExternalStatsWorker( 3407): no controller energy info supplied for telephony
02-22 03:48:10.610 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:10.612 E/OMXNodeInstance( 3270): getParameter(0xef947f04:Freescale.std._decoder.sorenson.sw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.614 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.614 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.sorenson.sw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.614 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.sorenson.sw-based] component does not support metadata mode; using fallback
02-22 03:48:10.614 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.sorenson.sw-based, OMX.google.android.index.prepareForAdaptivePlayback(0x7f00003d): Output:1 en=1 max=1280x720) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.616 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.616 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.vp8.hw-based) in omx@1.0-service process
02-22 03:48:10.616 W/NetworkPolicy( 3407): setRestrictBackgroundUL: already false
02-22 03:48:10.619 I/putmethod.lati( 3573): The ClassLoaderContext is a special shared library.
02-22 03:48:10.621 D/SystemServerTiming( 3407): MakeNetworkStatsServiceReady took to complete: 19ms
02-22 03:48:10.622 I/SystemServer( 3407): MakeConnectivityServiceReady
02-22 03:48:10.622 E/OMXNodeInstance( 3270): getParameter(0xef947f04:Freescale.std._decoder.vp8.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.622 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.622 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.622 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:10.623 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.623 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.vp8.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.623 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.vp8.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.625 D/Ethernet( 3407): got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:10.626 D/PermissionMonitor( 3407): Monitoring
02-22 03:48:10.627 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.627 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vp8.decoder) in omx@1.0-service process
02-22 03:48:10.632 I/ndroid.systemu( 3583): The ClassLoaderContext is a special shared library.
02-22 03:48:10.635 D/PermissionMonitor( 3407): Users: 1, Apps: 72
02-22 03:48:10.640 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27ea0:google.vp8.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.640 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27ea0:google.vp8.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.641 D/SystemServerTiming( 3407): MakeConnectivityServiceReady took to complete: 20ms
02-22 03:48:10.641 I/SystemServer( 3407): MakeNetworkPolicyServiceReady
02-22 03:48:10.642 D/SystemServerTiming( 3407): MakeNetworkPolicyServiceReady took to complete: 0ms
02-22 03:48:10.642 I/SystemServer( 3407): StartWatchdog
02-22 03:48:10.642 D/SystemServerTiming( 3407): StartWatchdog took to complete: 1ms
02-22 03:48:10.642 I/SystemServer( 3407): PhaseThirdPartyAppsCanStart
02-22 03:48:10.642 I/SystemServiceManager( 3407): Starting phase 600
02-22 03:48:10.643 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.643 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vp9.decoder) in omx@1.0-service process
02-22 03:48:10.645 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27ea0:google.vp9.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.645 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27ea0:google.vp9.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.645 E/LightsService( 3407): Light requested not available on this device. 4
02-22 03:48:10.647 V/WallpaperManagerService( 3407): bindWallpaperComponentLocked: componentName=ComponentInfo{com.android.systemui/com.android.systemui.ImageWallpaper}
02-22 03:48:10.651 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.651 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_encoder.avc.hw-based) in omx@1.0-service process
02-22 03:48:10.656 I/putmethod.lati( 3573): The ClassLoaderContext is a special shared library.
02-22 03:48:10.660 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:10.666 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:10.668 W/OMXUtils( 3254): do not know color format 0x6 = 6
02-22 03:48:10.668 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:10.669 W/OMXUtils( 3254): do not know color format 0x7f000789 = 2130708361
02-22 03:48:10.674 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.674 I/OMXMaster( 3270): makeComponentInstance(OMX.google.h264.encoder) in omx@1.0-service process
02-22 03:48:10.680 I/StatsCompanionService( 3407): Told statsd that StatsCompanionService is alive.
02-22 03:48:10.680 D/SystemServerTiming( 3407): PhaseThirdPartyAppsCanStart took to complete: 38ms
02-22 03:48:10.680 I/SystemServer( 3407): MakeLocationServiceReady
02-22 03:48:10.683 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.gnss@1.1::IGnss/default in either framework or device manifest.
02-22 03:48:10.683 D/GnssLocationProvider( 3407): gnssHal 1.1 was null, trying 1.0
02-22 03:48:10.684 W/OMXUtils( 3254): do not know color format 0x7f000789 = 2130708361
02-22 03:48:10.684 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.gnss@1.0::IGnss/default in either framework or device manifest.
02-22 03:48:10.685 W/LocationManagerService( 3407): no network location provider found
02-22 03:48:10.687 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.687 I/OMXMaster( 3270): makeComponentInstance(OMX.google.h263.encoder) in omx@1.0-service process
02-22 03:48:10.691 E/LocationManagerService( 3407): no geocoder provider found
02-22 03:48:10.691 I/SoftMPEG4Encoder( 3270): Construct SoftMPEG4Encoder
02-22 03:48:10.693 W/OMXUtils( 3254): do not know color format 0x7f000789 = 2130708361
02-22 03:48:10.693 E/OMXNodeInstance( 3270): getConfig(0xefd27ea0:google.h263.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
02-22 03:48:10.695 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.695 I/OMXMaster( 3270): makeComponentInstance(OMX.google.mpeg4.encoder) in omx@1.0-service process
02-22 03:48:10.695 I/SoftMPEG4Encoder( 3270): Construct SoftMPEG4Encoder
02-22 03:48:10.696 W/OMXUtils( 3254): do not know color format 0x7f000789 = 2130708361
02-22 03:48:10.697 E/OMXNodeInstance( 3270): getConfig(0xefd27ea0:google.mpeg4.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
02-22 03:48:10.699 D/LocationManagerService( 3407): Unable to bind FLP Geofence proxy.
02-22 03:48:10.699 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.699 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vp8.encoder) in omx@1.0-service process
02-22 03:48:10.700 E/ActivityRecognitionHardware( 3407): activity_recognition HAL is deprecated. class_init is effectively a no-op
02-22 03:48:10.700 E/ActivityRecognitionHardware( 3407): activity_recognition HAL is deprecated. is_supported is effectively a no-op
02-22 03:48:10.700 D/LocationManagerService( 3407): Hardware Activity-Recognition not supported.
02-22 03:48:10.701 E/ActivityRecognitionProxy( 3407): ServiceWatcher could not start.
02-22 03:48:10.701 D/LocationManagerService( 3407): Unable to bind ActivityRecognitionProxy.
02-22 03:48:10.704 D/SystemServerTiming( 3407): MakeLocationServiceReady took to complete: 24ms
02-22 03:48:10.704 I/SystemServer( 3407): MakeCountryDetectionServiceReady
02-22 03:48:10.704 D/SystemServerTiming( 3407): MakeCountryDetectionServiceReady took to complete: 0ms
02-22 03:48:10.704 I/SystemServer( 3407): MakeNetworkTimeUpdateReady
02-22 03:48:10.707 D/ConnectivityService( 3407): requestNetwork for uid/pid:1000/3407 NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ]
02-22 03:48:10.707 D/SystemServerTiming( 3407): MakeNetworkTimeUpdateReady took to complete: 3ms
02-22 03:48:10.707 I/SystemServer( 3407): MakeCommonTimeManagementServiceReady
02-22 03:48:10.708 I/CommonTimeManagementService( 3407): No common time service detected on this platform.  Common time services will be unavailable.
02-22 03:48:10.708 D/SystemServerTiming( 3407): MakeCommonTimeManagementServiceReady took to complete: 0ms
02-22 03:48:10.708 I/SystemServer( 3407): MakeInputManagerServiceReady
02-22 03:48:10.709 D/Ethernet( 3407): got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ] with score 0
02-22 03:48:10.709 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ], score: 0
02-22 03:48:10.709 D/SystemServerTiming( 3407): MakeInputManagerServiceReady took to complete: 2ms
02-22 03:48:10.710 I/SystemServer( 3407): MakeTelephonyRegistryReady
02-22 03:48:10.710 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ], network: NetworkInterfaceState{ iface: eth0, up: false, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: CONNECTING/OBTAINING_IPADDR, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: false, roaming: false], networkAgent: null, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {LinkAddresses: []  Routes: [] DnsAddresses: [] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0}}
02-22 03:48:10.710 W/OMXUtils( 3254): do not know color format 0x7f000789 = 2130708361
02-22 03:48:10.710 D/SystemServerTiming( 3407): MakeTelephonyRegistryReady took to complete: 1ms
02-22 03:48:10.710 I/SystemServer( 3407): MakeMediaRouterServiceReady
02-22 03:48:10.710 E/OMXNodeInstance( 3270): getConfig(0xefd27ea0:google.vp8.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
02-22 03:48:10.711 D/SystemServerTiming( 3407): MakeMediaRouterServiceReady took to complete: 1ms
02-22 03:48:10.711 I/SystemServer( 3407): MakeMmsServiceReady
02-22 03:48:10.711 I/MmsServiceBroker( 3407): Delay connecting to MmsService until an API is called
02-22 03:48:10.711 D/SystemServerTiming( 3407): MakeMmsServiceReady took to complete: 0ms
02-22 03:48:10.711 I/SystemServer( 3407): IncidentDaemonReady
02-22 03:48:10.713 D/SystemServerTiming( 3407): IncidentDaemonReady took to complete: 1ms
02-22 03:48:10.713 I/SystemServiceManager( 3407): Calling onStartUser u0
02-22 03:48:10.715 W/VoiceInteractionManagerService( 3407): no available voice interaction services found for user 0
02-22 03:48:10.715 W/VoiceInteractionManagerService( 3407): no available voice recognition services found for user 0
02-22 03:48:10.715 D/MediaCodecList( 3254): ignored a null builder
02-22 03:48:10.716 W/AlarmManager( 3583): Unrecognized alarm listener com.android.systemui.keyguard.-$$Lambda$KeyguardSliceProvider$IhzByd8TsqFuOrSyuGurVskyPLo@48b149d
02-22 03:48:10.719 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.719 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.720 I/ActivityManager( 3407): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.settings/.FallbackHome} from uid 0
02-22 03:48:10.721 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.723 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.725 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000020
02-22 03:48:10.733 I/LatinIME( 3573): Hardware accelerated drawing: true
02-22 03:48:10.738 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.754 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 9 lines
02-22 03:48:10.754 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.779 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.779 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.780 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.782 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.787 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 5 lines
02-22 03:48:10.790 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.790 I/system_server( 3407): Background concurrent copying GC freed 44817(2MB) AllocSpace objects, 26(680KB) LOS objects, 42% free, 5MB/9MB, paused 116us total 142.767ms
02-22 03:48:10.791 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.817 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.818 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.819 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.821 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.822 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 1 line
02-22 03:48:10.822 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.823 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000010
02-22 03:48:10.823 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.825 I/ActivityManager( 3407): Loaded persisted task ids for user 0
02-22 03:48:10.826 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 3 lines
02-22 03:48:10.827 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.853 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.853 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.855 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.858 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.862 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 6 lines
02-22 03:48:10.862 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.886 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.886 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.888 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.890 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.893 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 6 lines
02-22 03:48:10.893 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.915 W/system_server( 3407): Framework Matrix: Ignore file /system/etc/vintf/manifest.xml:
02-22 03:48:10.918 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.918 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.920 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.922 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.962 D/SystemServerTiming( 3407): ActivityManagerStartApps took to complete: 250ms
02-22 03:48:10.962 D/SystemServerTiming( 3407): PhaseActivityManagerReady took to complete: 1123ms
02-22 03:48:10.933 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 10 lines
02-22 03:48:10.934 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.963 W/system_server( 3407): Long monitor contention with owner main (3407) at void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable, android.util.TimingsTraceLog)(ActivityManagerService.java:15319) waiters=0 in java.lang.String com.android.server.am.ActivityManagerService.checkContentProviderAccess(java.lang.String, int) for 246ms
02-22 03:48:10.963 D/SystemServerInitThreadPool( 3407): Shutdown successful
02-22 03:48:10.964 D/SystemServerTiming( 3407): StartServices took to complete: 11440ms
02-22 03:48:10.964 W/ActivityManager( 3407): Slow operation: 247ms so far, now at startProcess: asking zygote to start proc
02-22 03:48:10.965 W/Looper  ( 3407): Slow delivery took 10752ms main h=android.os.Handler c=com.android.server.-$$Lambda$BatteryService$2x73lvpB0jctMSVP4qb9sHAqRPw@d0c6531 m=0
02-22 03:48:10.967 W/Looper  ( 3407): Slow dispatch took 250ms android.ui h=com.android.server.am.ActivityManagerService$UiHandler c=null m=53
02-22 03:48:10.975 W/InputAttributes( 3573): No editor info for this field. Bug?
02-22 03:48:10.977 W/ActivityManager( 3407): Slow operation: 260ms so far, now at startProcess: returned from zygote!
02-22 03:48:10.977 W/ActivityManager( 3407): Slow operation: 260ms so far, now at startProcess: done updating battery stats
02-22 03:48:10.978 W/ActivityManager( 3407): Slow operation: 260ms so far, now at startProcess: building log message
02-22 03:48:10.978 I/ActivityManager( 3407): Start proc 3826:com.android.phone/1001 for added application com.android.phone
02-22 03:48:10.978 W/ActivityManager( 3407): Slow operation: 260ms so far, now at startProcess: starting to update pids map
02-22 03:48:10.978 W/ActivityManager( 3407): Slow operation: 260ms so far, now at startProcess: done updating pids map
02-22 03:48:10.978 W/ActivityManager( 3407): Slow operation: 136ms so far, now at startProcess: asking zygote to start proc
02-22 03:48:11.002 W/ActivityManager( 3407): Slow operation: 160ms so far, now at startProcess: returned from zygote!
02-22 03:48:11.006 I/LatinIME:LogUtils( 3573): Dictionary info: dictionary = UserHistoryDictionary.en_US ; version = 1582254574 ; date = 1582803303
02-22 03:48:11.007 I/LatinIME:LogUtils( 3573): Dictionary info: dictionary = userunigram.en_US ; version = 1582343291 ; date = ?
02-22 03:48:10.976 W/main    ( 3826): type=1400 audit(0.0:2383): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:11.025 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: done updating battery stats
02-22 03:48:11.025 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: building log message
02-22 03:48:11.025 I/ActivityManager( 3407): Start proc 3841:com.android.settings/1000 for activity com.android.settings/.FallbackHome
02-22 03:48:11.025 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: starting to update pids map
02-22 03:48:11.025 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: done updating pids map
02-22 03:48:11.026 E/ActivityThread( 3573): Failed to find provider info for user_dictionary
02-22 03:48:11.036 D/ConditionProviders.SCP( 3407): onConnected
02-22 03:48:11.037 D/ConditionProviders( 3407): Subscribing to condition://android/event?userId=-10000&calendar=&reply=1 with ComponentInfo{android/com.android.server.notification.EventConditionProvider}
02-22 03:48:11.037 D/ConditionProviders( 3407): Subscribing to condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider}
02-22 03:48:10.976 I/chatty  ( 3826): uid=1001(radio) com.android.phone identical 2 lines
02-22 03:48:10.976 W/main    ( 3826): type=1400 audit(0.0:2386): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:11.047 V/SystemUIService( 3583): Starting SystemUI services for user 0.
02-22 03:48:11.047 V/MediaExtractorUpdateService( 3265): loadPlugins /vendor/app/ExtractorPkg/ExtractorPkg.apk
02-22 03:48:11.049 E/linker  ( 3265): library "/system/lib64/extractors/.." ("/system/lib64") needed or dlopened by "/system/lib64/libstagefright.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib64", permitted_paths="/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system/product/lib64:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:11.049 W/MediaExtractorFactory( 3265): couldn't dlopen(/system/lib64/extractors/..) Success
02-22 03:48:11.050 W/MediaExtractorFactory( 3265): couldn't dlopen(/system/lib64/extractors/.) Is a directory
02-22 03:48:11.054 I/m.android.phon( 3826): The ClassLoaderContext is a special shared library.
02-22 03:48:11.053 E/MediaExtractorFactory( 3265): couldn't opendir(/vendor/lib64/extractors)
02-22 03:48:11.063 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.Dependency took to complete: 15ms
02-22 03:48:11.070 I/ndroid.setting( 3841): The ClassLoaderContext is a special shared library.
02-22 03:48:10.996 W/main    ( 3841): type=1400 audit(0.0:2387): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:11.082 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.util.NotificationChannels took to complete: 19ms
02-22 03:48:11.084 I/WifiScanningService( 3407): wifi driver unloaded
02-22 03:48:11.086 V/SettingsProvider( 3407): Notifying for 0: content://settings/secure/location_providers_allowed
02-22 03:48:11.086 V/SettingsProvider( 3407): Notifying for 0: content://settings/global/location_global_kill_switch
02-22 03:48:11.088 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.statusbar.CommandQueue$CommandQueueStart took to complete: 6ms
02-22 03:48:11.093 D/UsbDeviceManager( 3407): push notification:正在通过 USB 为此设备充电
02-22 03:48:11.087 I/WifiScanningService( 3407): wifi driver unloaded
02-22 03:48:11.095 V/MediaRouter( 3583): Adding route: RouteInfo{ name=平板电脑, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:11.098 V/MediaRouter( 3583): Selecting route: RouteInfo{ name=平板电脑, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:11.107 I/ndroid.setting( 3841): The ClassLoaderContext is a special shared library.
02-22 03:48:11.109 I/LatinIME:LogUtils( 3573): Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
02-22 03:48:11.123 I/m.android.phon( 3826): The ClassLoaderContext is a special shared library.
02-22 03:48:11.134 W/SoundPool( 3583): Use of stream types is deprecated for operations other than volume control
02-22 03:48:11.134 W/SoundPool( 3583): See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
02-22 03:48:11.139 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.keyguard.KeyguardViewMediator took to complete: 50ms
02-22 03:48:11.148 D/OpenGLRenderer( 3583): Skia GL Pipeline
02-22 03:48:11.153 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:11.170 I/OMXClient( 3583): IOmx service obtained
02-22 03:48:11.170 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:11.173 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:11.176 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.191 W/ActivityManager( 3407): Unable to start service Intent { act=android.intent.action.QUICKSTEP_SERVICE pkg=com.android.launcher3 } U=0: not found
02-22 03:48:11.183 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 6 lines
02-22 03:48:11.184 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.192 W/OverviewProxyService( 3583): Failed to connect on attempt 1 will try again in 5000ms
02-22 03:48:11.192 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.193 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 2 lines
02-22 03:48:11.193 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.199 I/m.android.phon( 3826): The ClassLoaderContext is a special shared library.
02-22 03:48:11.203 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:48:11.227 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:11.228 W/Looper  ( 3407): Slow dispatch took 135ms main h=android.app.ActivityThread$H c=null m=114
02-22 03:48:11.235 I/OMXClient( 3583): IOmx service obtained
02-22 03:48:11.236 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:11.237 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:11.239 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.241 D/BluetoothManagerService( 3407): Trying to bind to profile: 1, while Bluetooth was disabled
02-22 03:48:11.245 I/Telecom ( 3407): BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
02-22 03:48:11.248 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.recents.Recents took to complete: 108ms
02-22 03:48:11.249 I/Telecom ( 3407): SystemStateProvider: Registering car mode receiver: android.content.IntentFilter@48e0917: TS.init@AAA
02-22 03:48:11.243 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 6 lines
02-22 03:48:11.243 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.251 D/OpenGLRenderer( 3841): Skia GL Pipeline
02-22 03:48:11.251 I/vol.Events( 3583): writeEvent collection_started
02-22 03:48:11.257 D/TelephonyProvider( 3826): dbh.onOpen: ok, queried table=siminfo
02-22 03:48:11.258 D/TelephonyProvider( 3826): dbh.onOpen: ok, queried table=carriers
02-22 03:48:11.258 I/Telecom ( 3407): Logging.Events: Non-call EVENT: AUDIO_ROUTE, Entering state QuiescentSpeakerRoute
02-22 03:48:11.259 I/Telecom ( 3407): BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
02-22 03:48:11.260 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.262 I/vol.Events( 3583): writeEvent external_ringer_mode_changed normal
02-22 03:48:11.262 I/vol.Events( 3583): writeEvent internal_ringer_mode_changed normal
02-22 03:48:11.265 I/Telecom ( 3407): CallAudioModeStateMachine: Message received: null.: TS.init->CAMSM.pM_1@AAA
02-22 03:48:11.269 I/Telecom ( 3407): MissedCallNotifierImpl: reloadFromDatabase: Boot not yet complete -- call log db may not be available. Deferring loading until boot complete for user 0: TS.init@AAA
02-22 03:48:11.271 D/BluetoothManagerService( 3407): Trying to bind to profile: 1, while Bluetooth was disabled
02-22 03:48:11.275 I/Telecom ( 3407): Class: TelecomSystem.INSTANCE being set
02-22 03:48:11.275 W/ContextImpl( 3407): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 android.content.ContextWrapper.startService:664 com.android.server.telecom.components.TelecomService.initializeTelecomSystem:197 com.android.server.telecom.components.TelecomService.onBind:67 android.app.ActivityThread.handleBindService:3597
02-22 03:48:11.277 W/ContextImpl( 3407): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 com.android.server.content.SyncManager$14.run:756 android.os.Handler.handleCallback:873 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:193
02-22 03:48:11.277 D/CarrierIdProvider( 3826): onCreate
02-22 03:48:11.279 D/installd( 3263): Found quota mount /dev/block/by-name/userdata at /data
02-22 03:48:11.280 D/installd( 3263): Found storage mount /data/media at /mnt/runtime/default/emulated
02-22 03:48:11.280 D/BluetoothManagerService( 3407): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
02-22 03:48:11.281 V/SettingsProvider( 3407): Notifying for 0: content://settings/global/boot_count
02-22 03:48:11.282 D/BluetoothManagerService( 3407): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
02-22 03:48:11.282 D/BluetoothManagerService( 3407): MESSAGE_GET_NAME_AND_ADDRESS
02-22 03:48:11.286 D/CarrierIdProvider( 3826): update database from pb file
02-22 03:48:11.286 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.288 D/BluetoothManagerService( 3407): unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@8d1f71d mBinding = false mUnbinding = false
02-22 03:48:11.287 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.290 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:48:11.290 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.294 D/BluetoothAdapterService( 3546): onUnbind() - calling cleanup
02-22 03:48:11.294 D/BluetoothAdapterService( 3546): cleanup()
02-22 03:48:11.297 W/BluetoothSdpJni( 3546): Cleaning up Bluetooth SDP Interface...
02-22 03:48:11.298 W/BluetoothSdpJni( 3546): Cleaning up Bluetooth SDP object
02-22 03:48:11.298 D/BluetoothAdapterService( 3546): cleanup() - Cleaning up adapter native
02-22 03:48:11.298 I/bt_stack_manager( 3546): event_clean_up_stack is cleaning up the stack
02-22 03:48:11.298 I/bt_btif_core( 3546): btif_cleanup_bluetooth entered
02-22 03:48:11.298 E/bt_btif ( 3546): do_in_bta_thread: MessageLooper not initialized
02-22 03:48:11.298 E/BluetoothServiceJni( 3546): Callback: 'callback_thread_event' is not called on the correct thread
02-22 03:48:11.298 I/bt_btif_queue( 3546): btif_queue_release
02-22 03:48:11.298 I/bt_btif_core( 3546): run_message_loop finished
02-22 03:48:11.298 W/bt_osi_thread( 3546): run_thread: thread id 3626, thread name bt_jni_workqueue exited
02-22 03:48:11.298 I/Zygote  ( 3407): Process: zygote socket ABSTRACT/com.android.internal.os.WebViewZygoteInit/f0642249-e0a6-4656-94b7-17a7125c2826 opened, supported ABIS: arm64-v8a,armeabi-v7a,armeabi
02-22 03:48:11.298 D/WebViewZygote( 3407): Preloading package /system/app/webview/webview.apk /system/app/webview/lib/arm:/system/app/webview/webview.apk!/lib/armeabi-v7a
02-22 03:48:11.299 I/bt_core_module( 3546): module_clean_up Cleaning up module "stack_config_module"
02-22 03:48:11.299 I/bt_core_module( 3546): module_clean_up Cleanup of module "stack_config_module" completed
02-22 03:48:11.299 I/bt_core_module( 3546): module_clean_up Cleaning up module "interop_module"
02-22 03:48:11.299 I/bt_core_module( 3546): module_clean_up Cleanup of module "interop_module" completed
02-22 03:48:11.299 I/bt_btif_core( 3546): btif_cleanup_bluetooth finished
02-22 03:48:11.299 I/bt_core_module( 3546): module_clean_up Cleaning up module "btif_config_module"
02-22 03:48:11.299 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:48:11.313 I/Zygote  ( 3407): Process: zygote socket ABSTRACT/com.android.internal.os.WebViewZygoteInit/f0642249-e0a6-4656-94b7-17a7125c2826 opened, supported ABIS: arm64-v8a,armeabi-v7a,armeabi
02-22 03:48:11.315 E/CarrierIdProvider( 3826): read carrier list from ota pb failure: java.io.FileNotFoundException: /data/misc/carrierid/carrier_list.pb (No such file or directory)
02-22 03:48:11.315 D/CarrierIdProvider( 3826): latest version: 4 need update: false
02-22 03:48:11.318 I/bt_core_module( 3546): module_clean_up Cleanup of module "btif_config_module" completed
02-22 03:48:11.318 I/bt_core_module( 3546): module_clean_up Cleaning up module "bt_utils_module"
02-22 03:48:11.318 I/bt_core_module( 3546): module_clean_up Cleanup of module "bt_utils_module" completed
02-22 03:48:11.318 I/bt_core_module( 3546): module_clean_up Cleaning up module "osi_module"
02-22 03:48:11.318 D/CarrierProvider( 3826): onCreate
02-22 03:48:11.318 D/bt_osi_alarm( 3546): callback_dispatch Callback thread exited
02-22 03:48:11.318 W/bt_osi_thread( 3546): run_thread: thread id 3624, thread name alarm_dispatcher exited
02-22 03:48:11.319 W/bt_osi_thread( 3546): run_thread: thread id 3623, thread name alarm_default_ca exited
02-22 03:48:11.320 I/bt_core_module( 3546): module_clean_up Cleanup of module "osi_module" completed
02-22 03:48:11.320 I/bt_stack_manager( 3546): event_clean_up_stack finished
02-22 03:48:11.320 I/BluetoothServiceJni( 3546): cleanupNative: return from cleanup
02-22 03:48:11.321 D/BluetoothActiveDeviceManager( 3546): cleanup()
02-22 03:48:11.324 D/BluetoothAdapterService( 3546): onDestroy()
02-22 03:48:11.325 I/WebViewZygoteInit( 3651): Beginning package preload
02-22 03:48:11.326 I/BluetoothAdapterService( 3546): Force exit to cleanup internal state in Bluetooth stack
02-22 03:48:11.327 I/ConfigStore( 3841): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:48:11.327 I/ConfigStore( 3841): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:48:11.327 I/OpenGLRenderer( 3841): Initialized EGL, version 1.4
02-22 03:48:11.327 D/OpenGLRenderer( 3841): Swap behavior 2
02-22 03:48:11.332 I/droid.bluetoot( 3546): System.exit called, status: 0
02-22 03:48:11.332 I/AndroidRuntime( 3546): VM exiting with result code 0, cleanup skipped.
02-22 03:48:11.335 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:11.339 I/ImsResolver( 3826): ImsResolver initialized with static binding.
02-22 03:48:11.343 I/ImsResolver( 3826): Initializing cache and binding.
02-22 03:48:11.345 V/WiredAccessoryManager( 3407): init()
02-22 03:48:11.346 V/WiredAccessoryManager( 3407): state_cable  16
02-22 03:48:11.347 V/WiredAccessoryManager( 3407): newName=extcon0 newState=16 headsetState=16 prev headsetState=0
02-22 03:48:11.347 I/OMXClient( 3583): IOmx service obtained
02-22 03:48:11.347 I/WiredAccessoryManager( 3407): MSG_NEW_DEVICE_STATE
02-22 03:48:11.347 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:11.349 E/OMXNodeInstance( 3270): getConfig(0xefd28080:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:11.355 I/webview_zygote( 3651): The ClassLoaderContext is a special shared library.
02-22 03:48:11.357 I/display ( 3841): open gpu gralloc module!
02-22 03:48:11.360 W/WiredAccessoryManager( 3407): /sys/class/extcon/extcon1/state not found while attempting to determine initial switch state
02-22 03:48:11.360 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.361 V/WiredAccessoryManager( 3407): state_cable  16
02-22 03:48:11.362 V/WiredAccessoryManager( 3407): newName=extcon2 newState=16 headsetState=16 prev headsetState=16
02-22 03:48:11.361 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 2 lines
02-22 03:48:11.362 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.362 E/WiredAccessoryManager( 3407): No state change.
02-22 03:48:11.363 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.385 D/AccessibilityManagerService( 3407): Ignoring non-encryption-aware service ComponentInfo{com.sigma_rt.totalcontrol/com.sigma_rt.totalcontrol.ap.service.TCAccessibilityService}
02-22 03:48:11.387 V/NotificationListeners( 3407): enabling notification listener for 0: ComponentInfo{com.android.launcher3/com.android.launcher3.notification.NotificationListener}
02-22 03:48:11.387 V/NotificationListeners( 3407): binding: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
02-22 03:48:11.387 W/ActivityManager( 3407): Unable to start service Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener } U=0: not found
02-22 03:48:11.387 W/NotificationListeners( 3407): Unable to bind notification listener service: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
02-22 03:48:11.387 V/NotificationAssistants( 3407): enabling notification assistant for 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
02-22 03:48:11.388 V/NotificationAssistants( 3407): binding: Intent { act=android.service.notification.NotificationAssistantService cmp=android.ext.services/.notification.Assistant (has extras) }
02-22 03:48:11.374 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 6 lines
02-22 03:48:11.375 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.399 W/DeviceHAL( 3231): Error from HAL Device in function set_mic_mute: Function not implemented
02-22 03:48:11.407 I/ActivityManager( 3407): Start proc 3917:android.ext.services/u0a28 for service android.ext.services/.notification.Assistant
02-22 03:48:11.414 D/ConditionProviders.SCP( 3407): onSubscribe condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true
02-22 03:48:11.415 D/ConditionProviders.SCP( 3407): setRegistered true
02-22 03:48:11.420 D/ConditionProviders.SCP( 3407): evaluateSubscriptionLocked cal=ScheduleCalendar[mDays={1, 2, 3, 4, 5, 6, 7}, mSchedule=ScheduleInfo{days=[1, 2, 3, 4, 5, 6, 7], startHour=22, startMinute=0, endHour=7, endMinute=0, exitAtAlarm=true, nextAlarm=Thu Jan 01 00:00:00 GMT 1970 (0)}], now=Sat Feb 22 03:48:11 GMT 2020 (1582343291415), nextUserAlarmTime=Thu Jan 01 00:00:00 GMT 1970 (0)
02-22 03:48:11.421 D/ConditionProviders.SCP( 3407): notifyCondition condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true STATE_TRUE reason=meetsSchedule
02-22 03:48:11.424 D/ConditionProviders.SCP( 3407): Scheduling evaluate for Sat Feb 22 07:00:00 GMT 2020 (1582354800000), in +3h11m48s585ms, now=Sat Feb 22 03:48:11 GMT 2020 (1582343291415)
02-22 03:48:11.427 I/ActivityManager( 3407): Displayed com.android.settings/.FallbackHome: +574ms
02-22 03:48:11.427 W/KeyguardServiceDelegate( 3407): onScreenTurningOn(): no keyguard service!
02-22 03:48:11.427 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:11.432 E/ActivityThread( 3407): Failed to find provider info for com.android.calendar
02-22 03:48:11.435 I/Telecom ( 3407): WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAE
02-22 03:48:11.436 I/WebViewZygoteInit( 3651): Package preload done
02-22 03:48:11.443 D/MediaSessionService( 3407): Global priority session is changed from null to com.android.server.telecom/HeadsetMediaButton (userId=0)
02-22 03:48:11.447 I/system_server( 3407): Background concurrent copying GC freed 53242(3MB) AllocSpace objects, 16(440KB) LOS objects, 42% free, 5MB/10MB, paused 337us total 172.379ms
02-22 03:48:11.449 I/SyncManager( 3407): Got SyncJobService instance.
02-22 03:48:11.450 V/WiredAccessoryManager( 3407): headsetName:  connected
02-22 03:48:11.452 D/AutofillManagerService( 3407): Autofill restriction did not change for user 0
02-22 03:48:11.453 D/audio_hw_primary( 3231): adev_set_parameters: enter: connect=1024
02-22 03:48:11.453 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:11.454 D/audio_hw_primary( 3231): out_set_parameters: enter: kvpairs: routing=0
02-22 03:48:11.454 D/audio_hw_primary( 3231): out_set_parameters: exit: code(0)
02-22 03:48:11.462 I/FusedLocation( 3407): engine started (com.android.location.fused)
02-22 03:48:11.462 W/Looper  ( 3407): Drained
02-22 03:48:11.462 V/MediaRouter( 3407): Audio routes updated: AudioRoutesInfo{ type=HDMI }, a2dp=false
02-22 03:48:11.463 V/MediaRouter( 3407): Selecting route: RouteInfo{ name=HDMI, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:11.471 I/Telecom ( 3407): WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAI
02-22 03:48:11.482 I/vol.Events( 3583): writeEvent level_changed STREAM_VOICE_CALL 4
02-22 03:48:11.483 I/vol.Events( 3583): writeEvent level_changed STREAM_SYSTEM 5
02-22 03:48:11.485 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.volume.VolumeUI took to complete: 236ms
02-22 03:48:11.487 I/ActivityManager( 3407): Process com.android.bluetooth (pid 3546) has died: fore SVC
02-22 03:48:11.488 W/libprocessgroup( 3407): kill(-3546, 9) failed: No such process
02-22 03:48:11.488 I/libprocessgroup( 3407): Successfully killed process cgroup uid 1002 pid 3546 in 0ms
02-22 03:48:11.488 I/Zygote  ( 3220): Process 3546 exited cleanly (0)
02-22 03:48:11.488 I/vol.Events( 3583): writeEvent level_changed STREAM_MUSIC 5
02-22 03:48:11.492 D/NotificationSQLiteLog( 3407): Pruned event entries: 0
02-22 03:48:11.494 I/vol.Events( 3583): writeEvent level_changed STREAM_RING 5
02-22 03:48:11.497 I/vol.Events( 3583): writeEvent level_changed STREAM_ALARM 6
02-22 03:48:11.500 I/vol.Events( 3583): writeEvent level_changed STREAM_BLUETOOTH_SCO 7
02-22 03:48:11.501 I/DefaultPermGrantPolicy( 3407): Revoking permissions from disabled data services for user:0
02-22 03:48:11.502 I/DefaultPermGrantPolicy( 3407): Granting permissions to enabled data services for user:0
02-22 03:48:11.506 I/vol.Events( 3583): writeEvent zen_mode_config_changed [disallowAlarms=false disallowMedia=false disallowSystem=true disallowRinger=false]
02-22 03:48:11.509 I/id.ext.service( 3917): The ClassLoaderContext is a special shared library.
02-22 03:48:11.531 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.stackdivider.Divider took to complete: 46ms
02-22 03:48:11.535 D/ExtAssistant( 3917): File doesn't exist or isn't readable yet
02-22 03:48:11.556 I/WifiService( 3407): getWifiServiceMessenger uid=10012
02-22 03:48:11.560 D/ConnectivityService( 3407): requestNetwork for uid/pid:10012/3583 NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ]
02-22 03:48:11.561 D/Ethernet( 3407): got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ] with score 0
02-22 03:48:11.561 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ], score: 0
02-22 03:48:11.561 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ], network: NetworkInterfaceState{ iface: eth0, up: false, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: CONNECTING/OBTAINING_IPADDR, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: false, roaming: false], networkAgent: null, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {LinkAddresses: []  Routes: [] DnsAddresses: [] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0}}
02-22 03:48:11.579 D/PhoneSwitcherNetworkRequstListener( 3826): Registering NetworkFactory
02-22 03:48:11.579 D/ConnectivityService( 3407): Got NetworkFactory Messenger for PhoneSwitcherNetworkRequstListener
02-22 03:48:11.586 D/ConnectivityService( 3407): Got NetworkFactory Messenger for TelephonyNetworkFactory[0]
02-22 03:48:11.597 E/ActivityThread( 3826): Failed to find provider info for com.android.contacts
02-22 03:48:11.597 W/CallerInfoCache( 3826): cursor is null
02-22 03:48:11.611 D/CarrierConfigLoader( 3826): CarrierConfigLoader has started
02-22 03:48:11.615 D/BluetoothManagerService( 3407): Trying to bind to profile: 1, while Bluetooth was disabled
02-22 03:48:11.626 W/WallpaperManagerService( 3407): Cannot extract colors because wallpaper could not be read.
02-22 03:48:11.626 W/WallpaperManagerService( 3407): Cannot get theme colors because WallpaperColors is null.
02-22 03:48:11.627 W/WallpaperManagerService( 3407): Cannot extract colors because wallpaper could not be read.
02-22 03:48:11.627 W/WallpaperManagerService( 3407): Cannot get theme colors because WallpaperColors is null.
02-22 03:48:11.630 I/TelecomFramework( 3826): TtyManager: updateUiTtyMode -1 -> 0
02-22 03:48:11.635 D/StatusBar( 3583): disable<e i a s b h r c s > disable2<q i n >
02-22 03:48:11.636 D/ImsResolver( 3826): maybeAddedImsService, packageName: null
02-22 03:48:11.636 I/ImsResolver( 3826): Adding newly added ImsService to cache: ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
02-22 03:48:11.636 I/StatusBarManagerService( 3407): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@a9aec5d
02-22 03:48:11.638 I/ImsResolver( 3826): Binding ImsService: ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver} with features: [{s=0, f=0}, {s=0, f=1}]
02-22 03:48:11.638 I/ImsServiceController( 3826): Granting Runtime permissions to:ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
02-22 03:48:11.638 I/DefaultPermGrantPolicy( 3407): Granting permissions to enabled ImsServices for user:0
02-22 03:48:11.638 I/ImsServiceController( 3826): Binding ImsService:ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
02-22 03:48:11.650 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:11.651 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:11.651 D/ServiceStateProvider( 3826): subId=-2
02-22 03:48:11.656 I/WifiService( 3407): WifiService trying to set country code to
02-22 03:48:11.656 I/WifiService( 3407): setCountryCode uid=1001
02-22 03:48:11.661 D/PhoneSwitcherNetworkRequstListener( 3826): got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ] with score 0
02-22 03:48:11.661 D/PhoneSwitcherNetworkRequstListener( 3826): got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:11.661 D/PhoneSwitcherNetworkRequstListener( 3826): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:11.661 D/PhoneSwitcherNetworkRequstListener( 3826): got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ] with score 0
02-22 03:48:11.662 D/TelephonyDebugService( 3826): TelephonyDebugService()
02-22 03:48:11.664 D/CarrierConfigLoader( 3826): mHandler: 12 phoneId: 0
02-22 03:48:11.669 E/PhoneInterfaceManager( 3826): [PhoneIntfMgr] getIccId: No UICC
02-22 03:48:11.676 D/OpenGLRenderer( 3826): Skia GL Pipeline
02-22 03:48:11.680 W/Telecom ( 3407): : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAY
02-22 03:48:11.680 I/TelecomFramework( 3826): AccountEntry: Registered phoneAccount: [[ ] PhoneAccount: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, ***, UserHandle{0} Capabilities: CallProvider MultiUser PlaceEmerg SimSub  Audio Routes: BESW Schemes: tel voicemail  Extras: Bundle[{android.telecom.extra.SUPPORTS_VIDEO_CALLING_FALLBACK=true}] GroupId: ***] with handle: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, ***, UserHandle{0}
02-22 03:48:11.681 I/TelecomFramework( 3826): PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.GsmCdmaPhone) {d1d24d0}
02-22 03:48:11.687 I/TelecomFramework( 3826): PstnPhoneCapabilitiesNotifier: handleVideoCapabilitesChanged. Video capability - false
02-22 03:48:11.689 E/PhoneInterfaceManager( 3826): [PhoneIntfMgr] getIccId: No UICC
02-22 03:48:11.697 W/Telecom ( 3407): : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAk
02-22 03:48:11.714 D/incidentd( 3262): Start uploading backlogs in /data/misc/incidents/
02-22 03:48:11.720 D/incidentd( 3262): Successfully uploaded 0 files to Dropbox.
02-22 03:48:11.793 I/CameraManagerGlobal( 3583): Connecting to camera service
02-22 03:48:11.921 D/NotificationEntryMgr( 3583): heads up is enabled
02-22 03:48:12.001 D/BluetoothHidDevice( 3583): Bound to HID Device Service
02-22 03:48:12.001 D/LocalBluetoothProfileManager( 3583): Adding local MAP profile
02-22 03:48:12.002 D/BluetoothMap( 3583): Create BluetoothMap proxy object
02-22 03:48:12.003 D/LocalBluetoothProfileManager( 3583): Adding local PBAP profile
02-22 03:48:12.006 D/LocalBluetoothProfileManager( 3583): LocalBluetoothProfileManager construction complete
02-22 03:48:12.021 V/WifiManager( 3583): registerSoftApCallback: callback=com.android.systemui.statusbar.policy.HotspotControllerImpl@bc141b5, handler=Handler (android.os.Handler) {a4c504a}
02-22 03:48:12.023 V/WifiManager( 3583): SoftApCallbackProxy: onStateChanged: state=11, failureReason=0
02-22 03:48:12.023 V/WifiManager( 3583): SoftApCallbackProxy: onNumClientsChanged: numClients=0
02-22 03:48:12.031 D/OpenGLRenderer( 3583): profile bars disabled
02-22 03:48:12.032 D/OpenGLRenderer( 3583): ambientRatio = 1.50
02-22 03:48:12.045 D/StatusBar( 3583): disable<e i a s b h r c s > disable2<q i n >
02-22 03:48:12.063 V/WifiManager( 3583): registerSoftApCallback: callback=com.android.systemui.statusbar.policy.HotspotControllerImpl@bc141b5, handler=Handler (android.os.Handler) {a4c504a}
02-22 03:48:12.064 V/WifiManager( 3583): SoftApCallbackProxy: onStateChanged: state=11, failureReason=0
02-22 03:48:12.064 V/WifiManager( 3583): SoftApCallbackProxy: onNumClientsChanged: numClients=0
02-22 03:48:12.073 I/SecurityController( 3583): could not bind to KeyChainService
02-22 03:48:12.120 E/ActivityThread( 3583): Failed to find provider info for com.android.contacts
02-22 03:48:12.128 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.SystemBars took to complete: 597ms
02-22 03:48:12.134 D/StorageNotification( 3583): Notifying about private volume: VolumeInfo{private}:
02-22 03:48:12.134 D/StorageNotification( 3583):     type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1
02-22 03:48:12.134 D/StorageNotification( 3583):     state=MOUNTED
02-22 03:48:12.134 D/StorageNotification( 3583):     fsType=null fsUuid=null fsLabel=null
02-22 03:48:12.134 D/StorageNotification( 3583):     path=/data internalPath=null
02-22 03:48:12.137 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.usb.StorageNotification took to complete: 8ms
02-22 03:48:12.147 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.power.PowerUI took to complete: 10ms
02-22 03:48:12.149 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.media.RingtonePlayer took to complete: 3ms
02-22 03:48:12.150 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.keyboard.KeyboardUI took to complete: 1ms
02-22 03:48:12.167 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.pip.PipUI took to complete: 17ms
02-22 03:48:12.169 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.shortcut.ShortcutKeyDispatcher took to complete: 2ms
02-22 03:48:12.169 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.VendorServices took to complete: 0ms
02-22 03:48:12.171 V/GarbageMonitor( 3583): Now tracking processes: 3583
02-22 03:48:12.171 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.util.leak.GarbageMonitor$Service took to complete: 2ms
02-22 03:48:12.173 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.LatencyTester took to complete: 1ms
02-22 03:48:12.176 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.globalactions.GlobalActionsComponent took to complete: 3ms
02-22 03:48:12.183 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.ScreenDecorations took to complete: 7ms
02-22 03:48:12.185 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.fingerprint.FingerprintDialogImpl took to complete: 1ms
02-22 03:48:12.187 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.SliceBroadcastRelayHandler took to complete: 1ms
02-22 03:48:12.187 D/SystemUIBootTiming( 3583): StartServices took to complete: 1138ms
02-22 03:48:12.199 W/AlarmManager( 3583): Unrecognized alarm listener com.android.systemui.keyguard.-$$Lambda$KeyguardSliceProvider$IhzByd8TsqFuOrSyuGurVskyPLo@48b149d
02-22 03:48:12.203 V/MediaRouter( 3583): Audio routes updated: AudioRoutesInfo{ type=HDMI }, a2dp=false
02-22 03:48:12.203 V/MediaRouter( 3583): Selecting route: RouteInfo{ name=HDMI, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:12.205 E/ndroid.systemu( 3583): Invalid ID 0x00000000.
02-22 03:48:12.205 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@5aaae80
02-22 03:48:12.208 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@5aaae80
02-22 03:48:12.210 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@557885f
02-22 03:48:12.211 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@557885f
02-22 03:48:12.213 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@c70570a
02-22 03:48:12.214 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@c70570a
02-22 03:48:12.214 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@2164b7b
02-22 03:48:12.215 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@2164b7b
02-22 03:48:12.216 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@a9fcd98
02-22 03:48:12.216 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@23f09f1
02-22 03:48:12.217 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@23f09f1
02-22 03:48:12.217 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@b44d9d6
02-22 03:48:12.219 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@b44d9d6
02-22 03:48:12.220 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@c29542d
02-22 03:48:12.221 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@c29542d
02-22 03:48:12.221 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@d0cbd62
02-22 03:48:12.222 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@becaef3
02-22 03:48:12.223 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@becaef3
02-22 03:48:12.224 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@406b7b0
02-22 03:48:12.225 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@4f40629
02-22 03:48:12.226 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@4f40629
02-22 03:48:12.228 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@e179edc
02-22 03:48:12.229 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@c9ddbe5
02-22 03:48:12.230 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@4f40629
02-22 03:48:12.231 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@5496ba
02-22 03:48:12.232 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@7cd096b
02-22 03:48:12.233 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@eedccc8
02-22 03:48:12.235 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@eedccc8
02-22 03:48:12.237 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@a555161
02-22 03:48:12.238 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@7cd096b
02-22 03:48:12.239 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@7256486
02-22 03:48:12.240 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@530d147
02-22 03:48:12.241 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@976ed74
02-22 03:48:12.242 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@fb4a29d
02-22 03:48:12.243 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@530d147
02-22 03:48:12.243 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@be34312
02-22 03:48:12.243 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@1f3ae3
02-22 03:48:12.244 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@1f3ae3
02-22 03:48:12.244 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@fcf6ce0
02-22 03:48:12.245 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@3bdcb99
02-22 03:48:12.245 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@1f3ae3
02-22 03:48:12.245 I/chatty  ( 3583): uid=10012(com.android.systemui) identical 54 lines
02-22 03:48:12.245 E/ndroid.systemu( 3583): Invalid ID 0x00000000.
02-22 03:48:12.256 I/Choreographer( 3583): Skipped 43 frames!  The application may be doing too much work on its main thread.
02-22 03:48:12.269 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:12.272 D/DhcpClient( 3407): Broadcasting DHCPDISCOVER
02-22 03:48:12.289 D/ViewRootImpl[StatusBar]( 3583): changeCanvasOpacity: opaque=true
02-22 03:48:12.303 I/ConfigStore( 3583): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:48:12.303 I/ConfigStore( 3583): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:48:12.304 I/OpenGLRenderer( 3583): Initialized EGL, version 1.4
02-22 03:48:12.304 D/OpenGLRenderer( 3583): Swap behavior 2
02-22 03:48:12.317 E/ActivityThread( 3583): Failed to find provider info for com.android.contacts
02-22 03:48:12.322 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:12.328 I/display ( 3583): open gpu gralloc module!
02-22 03:48:12.351 E/ActivityThread( 3583): Failed to find provider info for com.android.contacts
02-22 03:48:12.435 D/WifiService( 3407): New client listening to asynchronous messages
02-22 03:48:12.809 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:12.816 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:12.980 I/EthernetTracker( 3407): interfaceLinkStateChanged, iface: eth0, up: true
02-22 03:48:12.981 D/EthernetNetworkFactory( 3407): updateInterfaceLinkState, iface: eth0, up: true
02-22 03:48:12.982 D/DhcpClient( 3407): doQuit
02-22 03:48:13.007 D/DhcpClient( 3407): onQuitting
02-22 03:48:13.009 D/CommandListener( 3219): Clearing all IP addresses on eth0
02-22 03:48:13.011 D/EthernetNetworkFactory( 3407): starting IpClient(eth0): mNetworkInfo=[type: Ethernet[], state: DISCONNECTED/IDLE, reason: (unspecified), extra: (none), failover: false, available: false, roaming: false]
02-22 03:48:13.016 D/CommandListener( 3219): Clearing all IP addresses on eth0
02-22 03:48:13.028 W/WindowManager( 3407): App freeze timeout expired.
02-22 03:48:13.030 D/DhcpClient( 3407): Receive thread stopped
02-22 03:48:13.055 D/DhcpClient( 3407): Receive thread started
02-22 03:48:13.057 D/DhcpClient( 3407): Broadcasting DHCPDISCOVER
02-22 03:48:13.086 D/audio_hw_primary( 3231): adev_set_parameters: enter: A2dpSuspended=false
02-22 03:48:13.086 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:13.087 I/AudioService( 3407): setBluetoothScoOnInt: false resetBluetoothSco
02-22 03:48:13.087 D/audio_hw_primary( 3231): adev_set_parameters: enter: BT_SCO=off
02-22 03:48:13.087 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:13.162 I/ImageWallpaper( 3583): Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
02-22 03:48:13.204 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:13.218 I/Choreographer( 3583): Skipped 56 frames!  The application may be doing too much work on its main thread.
02-22 03:48:13.231 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:13.273 I/OpenGLRenderer( 3583): Davey! duration=1000ms; Flags=0, IntendedVsync=28328968658, Vsync=29262301954, OldestInputEvent=9223372036854775807, NewestInputEvent=0, HandleInputStart=29275853750, AnimationStart=29275879375, PerformTraversalsStart=29276725875, DrawStart=29298806500, SyncQueued=29316589625, SyncStart=29318134750, IssueDrawCommandsStart=29318255750, SwapBuffers=29328866875, FrameCompleted=29331460000, DequeueBufferDuration=733000, QueueBufferDuration=220000,
02-22 03:48:13.387 I/OpenGLRenderer( 3583): Davey! duration=1113ms; Flags=0, IntendedVsync=28328968658, Vsync=29262301954, OldestInputEvent=9223372036854775807, NewestInputEvent=0, HandleInputStart=29275853750, AnimationStart=29275879375, PerformTraversalsStart=29276725875, DrawStart=29408859000, SyncQueued=29411503750, SyncStart=29413656750, IssueDrawCommandsStart=29413806125, SwapBuffers=29443649875, FrameCompleted=29445108250, DequeueBufferDuration=449000, QueueBufferDuration=167000,
02-22 03:48:13.394 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleAccelerometer/poll_delay" (No such file or directory).
02-22 03:48:13.395 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleAccelerometer/enable" (No such file or directory).
02-22 03:48:13.395 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleMagnetometer/enable" (No such file or directory).
02-22 03:48:13.395 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleGyroscope/enable" (No such file or directory).
02-22 03:48:13.395 D/        ( 3247): FSLSensorsHub sensor waht = 1 , enable = 1
02-22 03:48:13.493 I/ImageWallpaper( 3583): Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
02-22 03:48:13.533 I/chatty  ( 3583): uid=10012(com.android.systemui) identical 3 lines
02-22 03:48:13.548 I/ImageWallpaper( 3583): Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
02-22 03:48:13.561 W/StatusBar/NavBarView( 3583): *** Invalid layout in navigation bar (sizeChanged this=1920x64 cur=1898x64)
02-22 03:48:13.630 I/WindowManager( 3407): ******* TELLING SURFACE FLINGER WE ARE BOOTED!
02-22 03:48:13.630 I/SurfaceFlinger( 3250): Boot is finished (16377 ms)
02-22 03:48:13.632 I/ImageWallpaper( 3583): Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
02-22 03:48:13.639 I/SystemServiceManager( 3407): Starting phase 1000
02-22 03:48:13.656 D/ActivityManager( 3407): Finishing user boot 0
02-22 03:48:13.657 I/ActivityManager( 3407): User 0 state changed from BOOTING to RUNNING_LOCKED
02-22 03:48:13.659 D/vold    ( 3170): e4crypt_unlock_user_key 0 serial=0 token_present=0
02-22 03:48:13.666 D/vold    ( 3170): Skipping non-key ..
02-22 03:48:13.666 D/vold    ( 3170): Trying user CE key /data/misc/vold/user_keys/ce/0/current
02-22 03:48:13.672 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.keymaster@4.0::IKeymasterDevice/default in either framework or device manifest.
02-22 03:48:13.685 I/vold    ( 3170): List of Keymaster HALs found:
02-22 03:48:13.686 I/vold    ( 3170): Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:48:13.687 I/vold    ( 3170): Using SoftwareKeymasterDevice from Google for encryption.  Security level: SOFTWARE, HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:48:13.690 D/vold    ( 3170): Successfully retrieved key
02-22 03:48:13.691 D/vold    ( 3170): Added key 980530730 (ext4:d0b2240490369ad2) to keyring 625017044 in process 3170
02-22 03:48:13.691 D/vold    ( 3170): Added key 177620527 (f2fs:d0b2240490369ad2) to keyring 625017044 in process 3170
02-22 03:48:13.691 D/vold    ( 3170): Added key 1027625186 (fscrypt:d0b2240490369ad2) to keyring 625017044 in process 3170
02-22 03:48:13.692 D/vold    ( 3170): Installed ce key for user 0
02-22 03:48:13.692 D/ActivityManager( 3407): Started unlocking user 0
02-22 03:48:13.692 D/ActivityManager( 3407): Unlocking user 0 progress 0
02-22 03:48:13.692 D/ActivityManager( 3407): Unlocking user 0 progress 5
02-22 03:48:13.695 D/vold    ( 3170): e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 2
02-22 03:48:13.695 D/vold    ( 3170): Preparing: /data/system_ce/0
02-22 03:48:13.695 D/vold    ( 3170): Preparing: /data/misc_ce/0
02-22 03:48:13.695 D/vold    ( 3170): Preparing: /data/vendor_ce/0
02-22 03:48:13.699 D/vold    ( 3170): Preparing: /data/media/0
02-22 03:48:13.699 D/vold    ( 3170): Preparing: /data/data
02-22 03:48:13.701 D/WifiConfigStore( 3407): Reading from stores completed in 2 ms.
02-22 03:48:13.709 I/vold    ( 3170): Found policy d0b2240490369ad2 at /data/system_ce/0 which matches expected value
02-22 03:48:13.710 W/WifiConfigManager( 3407): No stored networks found.
02-22 03:48:13.712 D/WIFI    ( 3407): Registering NetworkFactory
02-22 03:48:13.712 D/WIFI_UT ( 3407): Registering NetworkFactory
02-22 03:48:13.714 D/ConnectivityService( 3407): Got NetworkFactory Messenger for WIFI
02-22 03:48:13.714 D/ConnectivityService( 3407): Got NetworkFactory Messenger for WIFI_UT
02-22 03:48:13.714 D/WIFI    ( 3407): got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ] with score 0
02-22 03:48:13.714 D/WIFI    ( 3407): got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:13.714 D/WIFI    ( 3407): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:13.714 D/WIFI    ( 3407): got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ] with score 0
02-22 03:48:13.715 D/WIFI_UT ( 3407): got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ] with score 0
02-22 03:48:13.715 D/WIFI_UT ( 3407): got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:13.715 D/WIFI_UT ( 3407): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:13.715 D/WIFI_UT ( 3407): got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ] with score 0
02-22 03:48:13.721 I/ActivityManager( 3407): Start proc 4010:com.android.deskclock/u0a45 for broadcast com.android.deskclock/.AlarmInitReceiver
02-22 03:48:13.743 I/vold    ( 3170): Found policy d0b2240490369ad2 at /data/misc_ce/0 which matches expected value
02-22 03:48:13.759 I/vold    ( 3170): Policy for /data/vendor_ce/0 set to d0b2240490369ad2 modes 1/4
02-22 03:48:13.760 I/vold    ( 3170): Found policy d0b2240490369ad2 at /data/media/0 which matches expected value
02-22 03:48:13.760 I/vold    ( 3170): Found policy d0b2240490369ad2 at /data/data which matches expected value
02-22 03:48:13.760 V/vold    ( 3170): Starting restorecon of /data/system_ce/0
02-22 03:48:13.760 I/bootstat( 4009): Service started: /system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l
02-22 03:48:13.692 W/Binder:3170_3( 3170): type=1400 audit(0.0:2396): avc: denied { dac_read_search } for capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
02-22 03:48:13.696 I/chatty  ( 3170): uid=0(root) Binder:3170_2 identical 3 lines
02-22 03:48:13.696 W/Binder:3170_3( 3170): type=1400 audit(0.0:2400): avc: denied { dac_read_search } for capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
02-22 03:48:13.804 E/droid.deskcloc( 4010): Failed to send DDMS packet REAQ to debugger (-1 of 20): Broken pipe
02-22 03:48:13.823 I/bootstat( 4009): Battery level at startup 85%
02-22 03:48:13.823 I/bootstat( 4009): Canonical boot reason: reboot
02-22 03:48:13.833 E/bootstat( 4009): Failed to read /data/misc/bootstat/post_decrypt_time_elapsed: No such file or directory
02-22 03:48:13.833 E/bootstat( 4009): Failed to parse boot time record: /data/misc/bootstat/post_decrypt_time_elapsed
02-22 03:48:13.834 V/vold    ( 3170): Finished restorecon of /data/system_ce/0
02-22 03:48:13.834 V/vold    ( 3170): Starting restorecon of /data/misc_ce/0
02-22 03:48:13.851 I/droid.deskcloc( 4010): The ClassLoaderContext is a special shared library.
02-22 03:48:13.879 V/vold    ( 3170): Finished restorecon of /data/misc_ce/0
02-22 03:48:13.879 V/vold    ( 3170): /system/bin/vold_prepare_subdirs
02-22 03:48:13.879 V/vold    ( 3170):     prepare
02-22 03:48:13.879 V/vold    ( 3170):     0
02-22 03:48:13.879 V/vold    ( 3170):     2
02-22 03:48:13.897 I/droid.deskcloc( 4010): The ClassLoaderContext is a special shared library.
02-22 03:48:13.915 I/vold_prepare_subdirs( 3170): SELinux: Loaded file_contexts
02-22 03:48:13.920 D/vold_prepare_subdirs( 4034): Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_ce/0/vold
02-22 03:48:13.926 D/vold_prepare_subdirs( 4034): Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_ce/0/storaged
02-22 03:48:13.929 V/UserDataPreparer( 3407): Found /data/user/0 with serial number 0
02-22 03:48:13.929 V/UserDataPreparer( 3407): Found /data/system_ce/0 with serial number 0
02-22 03:48:13.930 D/UserDataPreparer( 3407): Setting property: sys.user.0.ce_available=true
02-22 03:48:13.931 V/PackageManager( 3407): reconcileAppsData for null u0 0x2 migrateAppData=false
02-22 03:48:13.968 W/cutils  ( 3263): Expected path /data/data/com.sigma_rt.totalcontrol with mode 751 but found 777
02-22 03:48:13.979 I/AlarmClock( 4010): AlarmInitReceiver android.intent.action.LOCKED_BOOT_COMPLETED
02-22 03:48:13.988 I/AlarmClock( 4010): Fixing alarm instances
02-22 03:48:14.063 V/AlarmClock( 4010): AlarmInitReceiver finished
02-22 03:48:14.091 I/android.os.Debug( 3407): using rollup pss collection
02-22 03:48:14.133 V/PackageManager( 3407): reconcileAppsData finished 90 packages
02-22 03:48:14.133 I/ActivityManager( 3407): User 0 state changed from RUNNING_LOCKED to RUNNING_UNLOCKING
02-22 03:48:14.133 D/ActivityManager( 3407): Unlocking user 0 progress 20
02-22 03:48:14.133 W/Looper  ( 3407): Slow dispatch took 439ms android.fg h=android.os.Handler c=com.android.server.am.-$$Lambda$UserController$o6oQFjGYYIfx-I94cSakTLPLt6s@68e80e6 m=0
02-22 03:48:14.133 W/Looper  ( 3407): Slow delivery took 435ms android.fg h=com.android.server.AppStateTracker$MyHandler c=null m=14
02-22 03:48:14.133 I/SystemServiceManager( 3407): Calling onUnlockUser u0
02-22 03:48:14.134 D/BluetoothManagerService( 3407): User 0 unlocked
02-22 03:48:14.134 D/BluetoothManagerService( 3407): MESSAGE_USER_UNLOCKED
02-22 03:48:14.134 D/StorageManagerService( 3407): onUnlockUser 0
02-22 03:48:14.135 D/vold    ( 3170): Linking /storage/emulated/0 to /mnt/user/0/primary
02-22 03:48:14.150 W/Looper  ( 3407): Drained
02-22 03:48:14.150 D/StorageManagerService( 3407): Volume emulated broadcasting mounted to UserHandle{0}
02-22 03:48:14.163 D/WifiConfigStore( 3407): Reading from user store completed in 1 ms.
02-22 03:48:14.163 W/VoiceInteractionManagerService( 3407): no available voice interaction services found for user 0
02-22 03:48:14.164 W/VoiceInteractionManagerService( 3407): no available voice recognition services found for user 0
02-22 03:48:14.164 V/BackupManagerService( 3407): Starting with transport android/com.android.internal.backup.LocalTransport
02-22 03:48:14.164 D/WakeupConfigStoreData( 3407): WifiWake user data has been read
02-22 03:48:14.165 D/AutofillManagerServiceImpl( 3407): Reset component for user 0 ()
02-22 03:48:14.166 D/AutofillManagerServiceImpl( 3407): Reset component for user 0 ()
02-22 03:48:14.166 D/AutofillUI( 3407): destroySaveUiUiThread(): already destroyed
02-22 03:48:14.166 D/FieldClassificationStrategy( 3407): reset(): service is not bound. Do nothing.
02-22 03:48:14.166 I/ActivityManager( 3407): User 0 state changed from RUNNING_UNLOCKING to RUNNING_UNLOCKED
02-22 03:48:14.166 I/ActivityManager( 3407): Loading recents for user 0 into memory.
02-22 03:48:14.166 D/SystemServerTiming( 3407): SystemUserUnlock took to complete: 474ms
02-22 03:48:14.187 I/SELinux ( 3407): SELinux: Loaded file_contexts
02-22 03:48:14.190 E/BackupPasswordManager( 3407): Unable to read backup pw version
02-22 03:48:14.190 E/BackupPasswordManager( 3407): Unable to read saved backup pw hash
02-22 03:48:14.193 I/InputAttributes( 3573): InputType.TYPE_NULL is specified
02-22 03:48:14.198 D/WifiConfigStore( 3407): Writing to stores completed in 33 ms.
02-22 03:48:14.199 V/BackupManagerService( 3407): No ancestral data
02-22 03:48:14.205 I/ActivityManager( 3407): Start proc 4047:com.android.se/1068 for added application com.android.se
02-22 03:48:14.214 I/BackupManagerService( 3407): Package com.neolix.nexlioflowpdu not installed; dropping from full backup
02-22 03:48:14.220 I/BackupManagerService( 3407): Unlocking system user; mService=com.android.server.backup.BackupManagerService@8e89704
02-22 03:48:14.222 I/BackupManagerService( 3407): Backup enabled => false
02-22 03:48:14.233 V/BackupManagerConstants( 3407): getKeyValueBackupIntervalMilliseconds(...) returns 14400000
02-22 03:48:14.233 V/BackupManagerConstants( 3407): getKeyValueBackupFuzzMilliseconds(...) returns 600000
02-22 03:48:14.233 V/BackupManagerConstants( 3407): getKeyValueBackupRequiredNetworkType(...) returns 1
02-22 03:48:14.234 V/BackupManagerConstants( 3407): getKeyValueBackupRequireCharging(...) returns true
02-22 03:48:14.234 V/KeyValueBackupJob( 3407): Scheduling k/v pass in 247 minutes
02-22 03:48:14.286 I/com.android.se( 4047): The ClassLoaderContext is a special shared library.
02-22 03:48:14.317 I/SecureElementService( 4047): main onCreate
02-22 03:48:14.323 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.secure_element@1.0::ISecureElement/eSE1 in either framework or device manifest.
02-22 03:48:14.324 I/SecureElementService( 4047): No HAL implementation for eSE1
02-22 03:48:14.325 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.secure_element@1.0::ISecureElement/SIM1 in either framework or device manifest.
02-22 03:48:14.327 I/SecureElementService( 4047): No HAL implementation for SIM1
02-22 03:48:14.351 I/AppWidgetServiceImpl( 3407): Processing of handleUserUnlocked u0 took 168 ms
02-22 03:48:14.351 I/ActivityManager( 3407): Sending BOOT_COMPLETE user #0
02-22 03:48:14.352 I/system_server( 3407): Background concurrent copying GC freed 58775(3MB) AllocSpace objects, 45(1284KB) LOS objects, 42% free, 6MB/10MB, paused 273us total 117.268ms
02-22 03:48:14.364 D/FallbackHome( 3841): User unlocked and real home found; let's go!
02-22 03:48:14.365 D/CarrierSvcBindHelper( 3826): Received android.intent.action.USER_UNLOCKED
02-22 03:48:14.366 E/PhoneInterfaceManager( 3826): [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC
02-22 03:48:14.366 D/CarrierSvcBindHelper( 3826): No carrier app for: 0
02-22 03:48:14.374 V/NotificationListeners( 3407): enabling notification listener for 0: ComponentInfo{com.android.launcher3/com.android.launcher3.notification.NotificationListener}
02-22 03:48:14.385 I/ActivityManager( 3407): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.launcher3/.Launcher} from uid 0
02-22 03:48:14.450 V/NotificationListeners( 3407): binding: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
02-22 03:48:14.451 W/ActivityManager( 3407): Slow operation: 94ms so far, now at startProcess: done updating battery stats
02-22 03:48:14.451 W/ActivityManager( 3407): Slow operation: 94ms so far, now at startProcess: building log message
02-22 03:48:14.451 I/ActivityManager( 3407): Start proc 4070:android.process.media/u0a6 for broadcast com.android.providers.downloads/.DownloadReceiver
02-22 03:48:14.451 W/ActivityManager( 3407): Slow operation: 94ms so far, now at startProcess: starting to update pids map
02-22 03:48:14.451 W/ActivityManager( 3407): Slow operation: 94ms so far, now at startProcess: done updating pids map
02-22 03:48:14.465 V/NotificationAssistants( 3407): disabling notification assistant for user 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
02-22 03:48:14.465 D/NotificationListeners( 3407): Removing active service ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
02-22 03:48:14.467 V/NotificationAssistants( 3407): enabling notification assistant for 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
02-22 03:48:14.467 V/NotificationAssistants( 3407): binding: Intent { act=android.service.notification.NotificationAssistantService cmp=android.ext.services/.notification.Assistant (has extras) }
02-22 03:48:14.473 I/ActivityManager( 3407): Start proc 4086:com.android.launcher3/u0a27 for activity com.android.launcher3/.Launcher
02-22 03:48:14.486 I/AccountManagerService( 3407): User 0 is unlocked - opening CE database
02-22 03:48:14.513 I/d.process.medi( 4070): The ClassLoaderContext is a special shared library.
02-22 03:48:14.539 I/SyncManager( 3407): Loaded persisted syncs: 0 periodic syncs, 0 oneshot syncs, 10 total system server jobs, JobStats: FirstLoad: 2/2/0 LastSave: -1/-1/-1
02-22 03:48:14.550 I/droid.launcher( 4086): The ClassLoaderContext is a special shared library.
02-22 03:48:14.563 I/ActivityManager( 3407): Start proc 4106:com.android.printspooler/u0a53 for service com.android.printspooler/.model.PrintSpoolerService
02-22 03:48:14.564 I/d.process.medi( 4070): The ClassLoaderContext is a special shared library.
02-22 03:48:14.630 I/id.printspoole( 4106): The ClassLoaderContext is a special shared library.
02-22 03:48:14.682 D/MediaScannerReceiver( 4070): action: android.intent.action.MEDIA_MOUNTED path: /storage/emulated/0
02-22 03:48:14.696 W/WallpaperManagerService( 3407): Cannot extract colors because wallpaper could not be read.
02-22 03:48:14.696 W/WallpaperManagerService( 3407): Cannot get theme colors because WallpaperColors is null.
02-22 03:48:14.697 V/Launcher( 4086): LauncherAppState initiated
02-22 03:48:14.701 I/ActivityManager( 3407): Start proc 4130:com.android.quicksearchbox/u0a41 for broadcast com.android.quicksearchbox/.SearchWidgetProvider
02-22 03:48:14.704 W/main    ( 4130): type=1400 audit(0.0:3637): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:14.719 I/ActivityManager( 3407): Start proc 4135:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
02-22 03:48:14.708 I/chatty  ( 4130): uid=0(root) .quicksearchbo identical 2 lines
02-22 03:48:14.708 W/main    ( 4130): type=1400 audit(0.0:3640): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:14.716 W/main    ( 4135): type=1400 audit(0.0:3641): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:14.727 D/OpenGLRenderer( 4086): Skia GL Pipeline
02-22 03:48:14.782 I/.quicksearchbo( 4130): The ClassLoaderContext is a special shared library.
02-22 03:48:14.787 I/ndroid.keychai( 4135): The ClassLoaderContext is a special shared library.
02-22 03:48:14.798 I/.quicksearchbo( 4130): The ClassLoaderContext is a special shared library.
02-22 03:48:14.904 I/RecoverySystem( 3407): No recovery log file
02-22 03:48:14.917 I/BootReceiver( 3407): Copying audit failures to DropBox
02-22 03:48:14.917 I/BootReceiver( 3407): Checking for fsck errors
02-22 03:48:14.918 I/BootReceiver( 3407): fs_stat, partition:userdata stat:0xb
02-22 03:48:14.942 I/ActivityManager( 3407): Start proc 4180:com.android.dialer/u0a31 for broadcast com.android.dialer/.app.calllog.CallLogReceiver
02-22 03:48:15.008 I/.android.diale( 4180): The ClassLoaderContext is a special shared library.
02-22 03:48:15.031 D/DhcpClient( 3407): Broadcasting DHCPDISCOVER
02-22 03:48:15.130 I/.android.diale( 4180): The ClassLoaderContext is a special shared library.
02-22 03:48:15.141 D/LoaderTask( 4086): loadWorkspace: loading default favorites
02-22 03:48:15.207 I/vol.Events( 3583): writeEvent dismiss_dialog timeout
02-22 03:48:15.221 I/ConfigStore( 4086): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:48:15.222 I/ConfigStore( 4086): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:48:15.222 I/OpenGLRenderer( 4086): Initialized EGL, version 1.4
02-22 03:48:15.223 D/OpenGLRenderer( 4086): Swap behavior 2
02-22 03:48:15.238 I/Dialer  ( 4180): DialerExecutorModule.newThread - creating low priority thread
02-22 03:48:15.250 I/display ( 4086): open gpu gralloc module!
02-22 03:48:15.253 I/Dialer  ( 4180): CallLogFramework.registerContentObservers - enter
02-22 03:48:15.258 I/Dialer  ( 4180): CallLogFramework.registerContentObservers - not registering content observers
02-22 03:48:15.264 I/Dialer  ( 4180): DialerExecutorModule.newThread - creating low priority thread
02-22 03:48:15.279 D/TouchInteractionService( 4086): Touch service connected
02-22 03:48:15.312 I/Dialer  ( 4180): DialerExecutorModule.newThread - creating low priority thread
02-22 03:48:15.315 I/Dialer  ( 4180): VisualVoicemailUpdateTask.updateNotification - enter
02-22 03:48:15.349 I/ActivityManager( 3407): Start proc 4228:android.process.acore/u0a15 for content provider com.android.providers.contacts/.CallLogProvider
02-22 03:48:15.430 I/ActivityManager( 3407): Displayed com.android.launcher3/.Launcher: +975ms
02-22 03:48:15.437 I/d.process.acor( 4228): The ClassLoaderContext is a special shared library.
02-22 03:48:15.457 E/SchedPolicy( 4086): set_timerslack_ns write failed: Operation not permitted
02-22 03:48:15.588 I/ContactsPerf( 4228): VoicemailContentProvider.onCreate start
02-22 03:48:15.604 I/ContactsPerf( 4228): VoicemailContentProvider.onCreate finish
02-22 03:48:15.667 I/d.process.acor( 4228): The ClassLoaderContext is a special shared library.
02-22 03:48:15.708 W/SurfaceFlinger( 3250): Attempting to set client state on removed layer: com.android.settings/com.android.settings.FallbackHome#0
02-22 03:48:15.708 W/SurfaceFlinger( 3250): Attempting to destroy on removed layer: com.android.settings/com.android.settings.FallbackHome#0
02-22 03:48:15.713 D/ContactsDatabaseHelper( 4228): WAL enabled for contacts2.db: true
02-22 03:48:15.716 W/SurfaceFlinger( 3250): Attempting to destroy on removed layer: AppWindowToken{5c08d4a token=Token{99c52b5 ActivityRecord{1dd6eec u0 com.android.settings/.FallbackHome t1}}}#0
02-22 03:48:15.731 I/d.process.acor( 4228): The ClassLoaderContext is a special shared library.
02-22 03:48:15.841 I/ContactLocale( 4228): AddressBook Labels [[zh_CN_#Hans,en_US]]: […, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, …, А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, …, א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, …, ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, …, ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, …, ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, …, あ, か, さ, た, な, は, ま, や, ら, わ, #, …]
02-22 03:48:15.859 D/DhcpClient( 3407): Received packet: 1e:ec:5a:75:1b:94 OFFER, ip /172.16.0.118, mask /255.255.255.0, DNS servers: /172.16.0.1 , gateways [/172.16.0.1] lease time 1800, domain lan
02-22 03:48:15.859 D/DhcpClient( 3407): Got pending lease: IP address 172.16.0.118/24 Gateway 172.16.0.1  DNS servers: [ 172.16.0.1 ] Domains lan DHCP server /172.16.0.1 Vendor info null lease 1800 seconds
02-22 03:48:15.860 D/DhcpClient( 3407): Broadcasting DHCPREQUEST ciaddr=0.0.0.0 request=172.16.0.118 serverid=172.16.0.1
02-22 03:48:15.866 D/DhcpClient( 3407): Received packet: 1e:ec:5a:75:1b:94 ACK: your new IP /172.16.0.118, netmask /255.255.255.0, gateways [/172.16.0.1] DNS servers: /172.16.0.1 , lease time 1800
02-22 03:48:15.866 D/DhcpClient( 3407): Confirmed lease: IP address 172.16.0.118/24 Gateway 172.16.0.1  DNS servers: [ 172.16.0.1 ] Domains lan DHCP server /172.16.0.1 Vendor info null lease 1800 seconds
02-22 03:48:15.867 D/CommandListener( 3219): Setting iface cfg
02-22 03:48:15.871 D/DhcpClient( 3407): Scheduling renewal in 899s
02-22 03:48:15.871 D/DhcpClient( 3407): Scheduling rebind in 1574s
02-22 03:48:15.871 D/DhcpClient( 3407): Scheduling expiry in 1799s
02-22 03:48:15.874 I/Dialer  ( 4180): VisualVoicemailUpdateTask.updateNotification - no voicemails to notify about
02-22 03:48:15.875 I/Dialer  ( 4180): VisualVoicemailNotifier.cancelAllVoicemailNotifications - enter
02-22 03:48:15.784 E/SchedPolicy( 4086): set_timerslack_ns write failed: Operation not permitted
02-22 03:48:15.880 D/ConnectivityService( 3407): registerNetworkAgent NetworkAgentInfo{ ni{[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: true, roaming: false]}  network{100}  nethandle{432902426637}  lp{{InterfaceName: eth0 LinkAddresses: [fe80::a021:d30e:d58:e446/64,172.16.0.118/24,]  Routes: [fe80::/64 -> :: eth0,172.16.0.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.0.1 eth0,] DnsAddresses: [172.16.0.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: lan MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}  nc{[ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED Unwanted:  LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]}  Score{70}  everValidated{false}  lastValidated{false}  created{false} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} clat{null} }
02-22 03:48:15.880 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] EVENT_NETWORK_INFO_CHANGED, going from null to CONNECTED
02-22 03:48:15.881 D/TcpSocketMonitor( 3219): resuming tcpinfo polling (interval=30000ms)
02-22 03:48:15.882 W/DnsManager( 3407): updatePrivateDns(100, PrivateDnsConfig{true:/[]})
02-22 03:48:15.883 D/ConnectivityService( 3407): Setting DNS servers for network 100 to [/172.16.0.1]
02-22 03:48:15.884 D/DnsManager( 3407): setDnsConfigurationForNetwork(100, [172.16.0.1], [lan], [1800, 25, 8, 64], , [172.16.0.1])
02-22 03:48:15.888 D/ConnectivityService( 3407): Adding iface eth0 to network 100
02-22 03:48:15.900 D/ContactsDatabaseHelper( 4228): WAL enabled for profile.db: false
02-22 03:48:15.902 I/Dialer  ( 4180): VoicemailNotificationJobService.scheduleJob - job canceled
02-22 03:48:15.914 I/Dialer  ( 4180): VisualVoicemailUpdateTask.scheduleTask - update successful
02-22 03:48:15.925 D/ConnectivityService( 3407): Setting DNS servers for network 100 to [/172.16.0.1]
02-22 03:48:15.925 D/DnsManager( 3407): setDnsConfigurationForNetwork(100, [172.16.0.1], [lan], [1800, 25, 8, 64], , [172.16.0.1])
02-22 03:48:15.930 W/DnsTlsSocket( 3219): SSL_connect error 5, errno=111
02-22 03:48:15.931 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.937 E/SchedPolicy( 4086): set_timerslack_ns write failed: Operation not permitted
02-22 03:48:15.943 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.944 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.946 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.953 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.954 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.956 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ], score: 70
02-22 03:48:15.958 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {135afab}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::a021:d30e:d58:e446/64,172.16.0.118/24,]  Routes: [fe80::/64 -> :: eth0,172.16.0.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.0.1 eth0,] DnsAddresses: [172.16.0.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: lan MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
02-22 03:48:15.958 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], score: 70
02-22 03:48:15.958 D/ConnectivityService( 3407): Switching to new default network: NetworkAgentInfo{ ni{[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: true, roaming: false]}  network{100}  nethandle{432902426637}  lp{{InterfaceName: eth0 LinkAddresses: [fe80::a021:d30e:d58:e446/64,172.16.0.118/24,]  Routes: [fe80::/64 -> :: eth0,172.16.0.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.0.1 eth0,] DnsAddresses: [172.16.0.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: lan MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}  nc{[ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED Unwanted:  LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]}  Score{70}  everValidated{false}  lastValidated{false}  created{true} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} clat{null} }
02-22 03:48:15.958 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {135afab}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::a021:d30e:d58:e446/64,172.16.0.118/24,]  Routes: [fe80::/64 -> :: eth0,172.16.0.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.0.1 eth0,] DnsAddresses: [172.16.0.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: lan MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
02-22 03:48:15.958 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ], score: 70
02-22 03:48:15.959 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {135afab}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::a021:d30e:d58:e446/64,172.16.0.118/24,]  Routes: [fe80::/64 -> :: eth0,172.16.0.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.0.1 eth0,] DnsAddresses: [172.16.0.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: lan MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
02-22 03:48:15.964 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 6ms OK 69.63.180.173
02-22 03:48:15.966 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 7ms OK 203.208.39.247
02-22 03:48:15.974 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.980 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=12ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:06:45 GMT], X-Android-Received-Millis=[1582343295979], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343295975]}
02-22 03:48:15.984 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.985 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.988 D/NetworkTimeUpdateService( 3407): New default network 100; checking time.
02-22 03:48:15.989 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.989 D/ConnectivityService( 3407): Sending CONNECTED broadcast for type 9 NetworkAgentInfo [Ethernet () - 100] isDefaultNetwork=true
02-22 03:48:15.994 I/chatty  ( 3407): uid=1000(system) NetworkPolicy identical 1 line
02-22 03:48:15.995 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:16.054 V/MediaProvider( 4070): pruneThumbnails
02-22 03:48:16.063 V/MediaProvider( 4070): /pruneDeadThumbnailFiles...
02-22 03:48:16.242 I/LatinIME( 3573): Timeout waiting for dictionary load
02-22 03:48:20.916 D/WifiService( 3407): boot completed do start wifi
02-22 03:48:20.916 W/Looper  ( 3407): Slow dispatch took 5001ms main h=android.app.ActivityThread$H c=android.app.-$$Lambda$LoadedApk$ReceiverDispatcher$Args$_BumDX2UKsnxLVrE6UJsJZkotuA@d01b175 m=0
02-22 03:48:20.916 W/Looper  ( 3407): Slow delivery took 5001ms main h=com.android.server.job.JobSchedulerService$JobHandler c=null m=4
02-22 03:48:20.932 I/Telecom ( 3407): DefaultDialerCache: Refreshing default dialer for user 0: now com.android.dialer: DDC.oR@AA8
02-22 03:48:20.934 I/TransportClient( 3407): LocalTransportService#0: Notifying [TransportManager.registerTransport()] transport = IBackupTransport
02-22 03:48:20.934 W/Looper  ( 3407): Drained
02-22 03:48:20.935 I/Telecom ( 3407): MissedCallNotifierImpl: reloadAfterBootComplete: user=0: TSBCR.oR@ABA
02-22 03:48:20.938 D/CarrierConfigLoader( 3826): mHandler: 13 phoneId: 0
02-22 03:48:20.942 D/BackupTransportManager( 3407): Transport android/com.android.internal.backup.LocalTransportService registered
02-22 03:48:20.942 D/BackupManagerService( 3407): Transport android/com.android.internal.backup.LocalTransport registered 6723ms after first request (delay = 3000ms)
02-22 03:48:20.948 I/BackupManagerService( 3407): Found stale backup journal, scheduling
02-22 03:48:20.958 D/SIP     ( 3826): [SipPreferences] isReceivingCallsEnabled, option not set; use default value, exception: android.provider.Settings$SettingNotFoundException: sip_receive_calls
02-22 03:48:20.973 I/chatty  ( 3407): uid=1000(system) backup identical 163 lines
02-22 03:48:20.973 I/BackupManagerService( 3407): Found stale backup journal, scheduling
02-22 03:48:20.973 I/ActivityManager( 3407): Start proc 4327:com.android.calendar/u0a62 for broadcast com.android.calendar/.alerts.AlertReceiver
02-22 03:48:20.974 I/BackupManagerService( 3407): Found stale backup journal, scheduling
02-22 03:48:21.006 D/SntpClient( 3407): request time failed: java.net.SocketTimeoutException: Poll timed out
02-22 03:48:20.968 W/main    ( 4327): type=1400 audit(0.0:3653): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:21.027 I/ndroid.calenda( 4327): The ClassLoaderContext is a special shared library.
02-22 03:48:21.043 I/ndroid.calenda( 4327): The ClassLoaderContext is a special shared library.
02-22 03:48:21.073 D/ExtensionsFactory( 4327): No custom extensions.
02-22 03:48:21.077 D/AlertReceiver( 4327): onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
02-22 03:48:20.987 I/chatty  ( 3407): uid=1000(system) backup identical 130 lines
02-22 03:48:20.987 I/BackupManagerService( 3407): Found stale backup journal, scheduling
02-22 03:48:21.096 I/ActivityManager( 3407): Start proc 4357:com.android.cellbroadcastreceiver/u0a24 for broadcast com.android.cellbroadcastreceiver/.CellBroadcastReceiver
02-22 03:48:21.108 D/AlertService( 4327): 0 Action = android.intent.action.BOOT_COMPLETED
02-22 03:48:21.112 D/AlertService( 4327): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
02-22 03:48:21.140 I/ActivityManager( 3407): Start proc 4368:com.android.providers.calendar/u0a4 for content provider com.android.providers.calendar/.CalendarProvider2
02-22 03:48:21.092 W/main    ( 4357): type=1400 audit(0.0:3657): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:21.239 I/oadcastreceive( 4357): The ClassLoaderContext is a special shared library.
02-22 03:48:21.252 I/viders.calenda( 4368): The ClassLoaderContext is a special shared library.
02-22 03:48:21.298 D/CellBroadcastReceiver( 4357): onReceive Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.cellbroadcastreceiver/.CellBroadcastReceiver (has extras) }
02-22 03:48:21.298 D/CellBroadcastReceiver( 4357): Start Cell Broadcast configuration.
02-22 03:48:21.309 D/CellBroadcastReceiver( 4357): Default interval 0 did not change.
02-22 03:48:21.324 I/ActivityManager( 3407): Start proc 4406:com.android.contacts/u0a26 for broadcast com.android.contacts/.interactions.OnBootOrUpgradeReceiver
02-22 03:48:21.328 I/CalendarProvider2( 4368): Created com.android.providers.calendar.CalendarAlarmManager@12606e0(com.android.providers.calendar.CalendarProvider2@4895d99)
02-22 03:48:21.332 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.333 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4370 to 4370 from client com.android.cellbroadcastreceiver
02-22 03:48:21.337 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
02-22 03:48:21.338 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4096 to 4096 from client com.android.cellbroadcastreceiver
02-22 03:48:21.340 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.341 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4383 to 4383 from client com.android.cellbroadcastreceiver
02-22 03:48:21.344 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.344 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4371 to 4372 from client com.android.cellbroadcastreceiver
02-22 03:48:21.349 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
02-22 03:48:21.350 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4097 to 4097 from client com.android.cellbroadcastreceiver
02-22 03:48:21.353 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.353 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4384 to 4385 from client com.android.cellbroadcastreceiver
02-22 03:48:21.358 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.358 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4373 to 4378 from client com.android.cellbroadcastreceiver
02-22 03:48:21.361 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
02-22 03:48:21.361 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4098 to 4098 from client com.android.cellbroadcastreceiver
02-22 03:48:21.365 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.365 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4386 to 4391 from client com.android.cellbroadcastreceiver
02-22 03:48:21.374 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.375 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4379 to 4379 from client com.android.cellbroadcastreceiver
02-22 03:48:21.380 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
02-22 03:48:21.381 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4099 to 4099 from client com.android.cellbroadcastreceiver
02-22 03:48:21.384 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.384 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4392 to 4392 from client com.android.cellbroadcastreceiver
02-22 03:48:21.388 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4380 to 4380 from client com.android.cellbroadcastreceiver
02-22 03:48:21.391 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove cdma broadcast subscription for MID range 4100 to 4100 from client com.android.cellbroadcastreceiver
02-22 03:48:21.393 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4393 to 4393 from client com.android.cellbroadcastreceiver
02-22 03:48:21.399 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4381 to 4381 from client com.android.cellbroadcastreceiver
02-22 03:48:21.401 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4394 to 4394 from client com.android.cellbroadcastreceiver
02-22 03:48:21.404 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4382 to 4382 from client com.android.cellbroadcastreceiver
02-22 03:48:21.407 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4395 to 4395 from client com.android.cellbroadcastreceiver
02-22 03:48:21.411 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.412 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4352 to 4354 from client com.android.cellbroadcastreceiver
02-22 03:48:21.415 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.415 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4356 to 4356 from client com.android.cellbroadcastreceiver
02-22 03:48:21.418 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4355 to 4355 from client com.android.cellbroadcastreceiver
02-22 03:48:21.435 I/ndroid.contact( 4406): The ClassLoaderContext is a special shared library.
02-22 03:48:21.448 D/AlarmScheduler( 4327): No events found starting within 1 week.
02-22 03:48:21.483 I/AlarmClock( 4010): AlarmInitReceiver android.intent.action.BOOT_COMPLETED
02-22 03:48:21.491 D/ActivityManager( 3407): Raise procstate to external provider: ProcessRecord{ee30ac8 4228:android.process.acore/u0a15}
02-22 03:48:21.494 W/Binder  ( 3407): Outgoing transactions from this process must be FLAG_ONEWAY
02-22 03:48:21.494 W/Binder  ( 3407): java.lang.Throwable
02-22 03:48:21.494 W/Binder  ( 3407):  at android.os.BinderProxy.transact(Binder.java:1114)
02-22 03:48:21.494 W/Binder  ( 3407):  at android.content.ContentProviderProxy.getType(ContentProviderNative.java:451)
02-22 03:48:21.494 W/Binder  ( 3407):  at com.android.server.am.ActivityManagerService.getProviderMimeType(ActivityManagerService.java:13064)
02-22 03:48:21.494 W/Binder  ( 3407):  at android.app.IActivityManager$Stub.onTransact(IActivityManager.java:1416)
02-22 03:48:21.494 W/Binder  ( 3407):  at com.android.server.am.ActivityManagerService.onTransact(ActivityManagerService.java:3291)
02-22 03:48:21.494 W/Binder  ( 3407):  at android.os.Binder.execTransact(Binder.java:731)
02-22 03:48:21.504 I/AlarmClock( 4010): Fixing alarm instances
02-22 03:48:21.513 V/AlarmClock( 4010): AlarmInitReceiver finished
02-22 03:48:21.522 I/Dialer  ( 4180): VoicemailModule.provideVoicemailClient - providing VoicemailClientImpl
02-22 03:48:21.524 I/Dialer  ( 4180): VvmOmtpService - onBoot
02-22 03:48:21.543 I/ActivityManager( 3407): Start proc 4442:com.android.email/u0a37 for broadcast com.android.email/.service.EmailBroadcastReceiver
02-22 03:48:21.600 I/m.android.emai( 4442): The ClassLoaderContext is a special shared library.
02-22 03:48:21.672 W/ActivityManager( 3407): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
02-22 03:48:21.619 I/m.android.emai( 4442): The ClassLoaderContext is a special shared library.
02-22 03:48:21.683 D/DhcpClient( 3407): Received packet: 80:05:88:b7:35:48 OFFER, ip /172.16.0.43, mask /255.255.255.0, DNS servers: /172.16.0.1 , gateways [/172.16.0.1] lease time 1800, domain lan
02-22 03:48:21.688 D/ActivityThread( 4442): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
02-22 03:48:21.690 W/ActivityManager( 3407): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
02-22 03:48:21.765 I/SystemBroadcastReceiver( 3573): Boot has been completed
02-22 03:48:21.765 I/SystemBroadcastReceiver( 3573): toggleAppIcon() : FLAG_SYSTEM = true
02-22 03:48:21.789 I/ActivityManager( 3407): Start proc 4483:com.android.managedprovisioning/u0a9 for broadcast com.android.managedprovisioning/.preprovisioning.BootReminder
02-22 03:48:21.793 W/ActivityManager( 3407): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
02-22 03:48:21.795 W/ActivityManager( 3407): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
02-22 03:48:21.799 W/ActivityManager( 3407): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
02-22 03:48:21.818 E/gedprovisionin( 4483): Failed to send DDMS packet REAQ to debugger (-1 of 20): Broken pipe
02-22 03:48:21.820 I/chatty  ( 3407): uid=1000(system) Binder:3407_1 identical 1 line
02-22 03:48:21.822 W/ActivityManager( 3407): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
02-22 03:48:21.824 E/ActivityThread( 4442): Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@a2c753c that was originally bound here
02-22 03:48:21.824 E/ActivityThread( 4442): android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@a2c753c that was originally bound here
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.app.LoadedApk$ServiceDispatcher.<init>(LoadedApk.java:1610)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:1502)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1659)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.app.ContextImpl.bindService(ContextImpl.java:1612)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.content.ContextWrapper.bindService(ContextWrapper.java:698)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java:181)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java:224)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java:160)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java:171)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java:115)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java:305)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java:295)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java:130)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:76)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.os.Handler.dispatchMessage(Handler.java:106)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.os.Looper.loop(Looper.java:193)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.os.HandlerThread.run(HandlerThread.java:65)
02-22 03:48:21.824 W/ActivityManager( 3407): Unbind failed: could not find connection for android.os.BinderProxy@c30ac5e
02-22 03:48:21.839 I/Email   ( 4442): Observing account changes for notifications
02-22 03:48:21.854 W/ActivityManager( 3407): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
02-22 03:48:21.881 I/gedprovisionin( 4483): The ClassLoaderContext is a special shared library.
02-22 03:48:21.932 I/ActivityManager( 3407): Start proc 4510:com.android.onetimeinitializer/u0a19 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
02-22 03:48:21.986 I/timeinitialize( 4510): The ClassLoaderContext is a special shared library.
02-22 03:48:22.007 V/OneTimeInitializerReceiver( 4510): OneTimeInitializerReceiver.onReceive
02-22 03:48:22.028 I/ActivityManager( 3407): Start proc 4529:com.android.packageinstaller/u0a32 for broadcast com.android.packageinstaller/.TemporaryFileManager
02-22 03:48:22.024 W/main    ( 4529): type=1400 audit(0.0:3681): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:22.130 I/ackageinstalle( 4529): The ClassLoaderContext is a special shared library.
02-22 03:48:22.169 I/VvmSimStateTracker( 3826): android.intent.action.BOOT_COMPLETED
02-22 03:48:22.358 I/ActivityManager( 3407): Start proc 4547:com.android.traceur/u0a58 for broadcast com.android.traceur/.Receiver
02-22 03:48:22.352 W/main    ( 4547): type=1400 audit(0.0:3685): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:22.420 I/android.traceu( 4547): The ClassLoaderContext is a special shared library.
02-22 03:48:22.517 I/ActivityManager( 3407): Start proc 4564:com.sigma_rt.totalcontrol/u0a66 for broadcast com.sigma_rt.totalcontrol/.activity.bc.BroadcastBootReceiver
02-22 03:48:22.438 I/android.traceu( 4547): The ClassLoaderContext is a special shared library.
02-22 03:48:22.579 I/rt.totalcontro( 4564): The ClassLoaderContext is a special shared library.
02-22 03:48:22.622 D/===MaApplication===( 4564): ApApplication run onCreate()
02-22 03:48:22.624 I/===MaApplication===( 4564): Will write content:ANDROID-MEK-MX8Q
02-22 03:48:22.628 I/===MaApplication===( 4564): Will write content:appcation package name /data/data/com.sigma_rt.totalcontrol
02-22 03:48:22.630 I/===MaApplication===( 4564): init UDP socket success.
02-22 03:48:22.646 I/===MaApplication===( 4564): Will write content:Version:7.6.1.31780 Version:in XML 7.6.1.31780 Version in ma.conf:7.6.1.31780
02-22 03:48:22.646 I/===MaApplication===( 4564): Chenking hasRootPermission ....
02-22 03:48:22.647 I/===MaApplication===( 4564): Chenking hasRootPermission over.
02-22 03:48:22.652 I/===CheckRootPermission===( 4564): su error :
02-22 03:48:22.652 I/===CheckRootPermission===( 4564): java.io.IOException: Cannot run program "su": error=13, Permission denied
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.ProcessBuilder.start(ProcessBuilder.java:1050)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.Runtime.exec(Runtime.java:695)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.Runtime.exec(Runtime.java:560)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at com.sigma_rt.totalcontrol.h.s.c(Unknown Source:14)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at com.sigma_rt.totalcontrol.root.MaApplication.onCreate(Unknown Source:454)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1154)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.app.ActivityThread.handleBindApplication(ActivityThread.java:5920)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.app.ActivityThread.access$1100(ActivityThread.java:200)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1656)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.os.Handler.dispatchMessage(Handler.java:106)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.os.Looper.loop(Looper.java:193)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.app.ActivityThread.main(ActivityThread.java:6718)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.reflect.Method.invoke(Native Method)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:917)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564): Caused by: java.io.IOException: error=13, Permission denied
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.UNIXProcess.forkAndExec(Native Method)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.UNIXProcess.<init>(UNIXProcess.java:133)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.ProcessImpl.start(ProcessImpl.java:132)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  ... 14 more
02-22 03:48:22.653 I/===MaApplication===( 4564): Chenking hasRootPermission excute[su]over.
02-22 03:48:22.653 I/===MaApplication===( 4564): hasRootPermission = false
02-22 03:48:22.653 I/===MaApplication===( 4564): version:76131780
02-22 03:48:22.659 I/===MaApplication===( 4564): Will write content:ApApplication onCreate() Version:7.6.1.31780  SDK:28 Run TC:true
02-22 03:48:22.661 I/BroadcastBootReceiver( 4564): android.intent.action.BOOT_COMPLETED
02-22 03:48:22.661 I/BroadcastBootReceiver( 4564): Will write content:----------Device reboot---------
02-22 03:48:22.669 W/Notification( 4564): Use of stream types is deprecated for operations other than volume control
02-22 03:48:22.669 W/Notification( 4564): See the documentation of setSound() for what to use instead with android.media.AudioAttributes to qualify your playback use case
02-22 03:48:22.674 D/OpenGLRenderer( 4564): Skia GL Pipeline
02-22 03:48:22.683 I/ActivityManager( 3407): Finished processing BOOT_COMPLETED for u0
02-22 03:48:22.684 I/===DaemonService===( 4564): onCreate()
02-22 03:48:22.685 W/Notification( 4564): Use of stream types is deprecated for operations other than volume control
02-22 03:48:22.685 W/Notification( 4564): See the documentation of setSound() for what to use instead with android.media.AudioAttributes to qualify your playback use case
02-22 03:48:22.694 I/ControlSockrtOnJava( 4564): start creating socket[11010].
02-22 03:48:22.696 I/ControlSockrtOnJava( 4564):  Begin to send msg to mobile.
02-22 03:48:22.700 I/===DaemonService===( 4564): Will write content:register[true] sms&content&phone info: smsObserver=null|| mobileagent state =0
02-22 03:48:22.700 I/===DaemonService===( 4564): Will write content:cannot regist isNotificationCheckboxSelected=  mobileagent state:0
02-22 03:48:22.704 W/audio_hw_primary( 3231): get_input_buffer_size size = 512, channel_count = 2
02-22 03:48:22.705 I/===AudioRecorderThread===( 4564): min buffer size:4096
02-22 03:48:22.709 E/System  ( 4564): Ignoring attempt to set property "java.net.preferIPv6Addresses" to value "false".
02-22 03:48:22.709 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:22.709 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:22.709 D/USBService( 4564): ===USBService onCreate()===
02-22 03:48:22.709 I/USBService( 4564): Will write content:USBService onCreate().
02-22 03:48:22.711 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:22.712 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:22.712 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:22.713 E/===APKProtocolTransmit===( 4564): send sb-cmd:275 error, the socket is null
02-22 03:48:22.713 I/===APKProtocolTransmit===( 4564): Will write content:send sb-cmd:275 error, the socket is null
02-22 03:48:22.716 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:22.716 I/===DaemonService===( 4564): public receiver :[android.intent.action.BATTERY_CHANGED]
02-22 03:48:22.716 D/===DaemonService===( 4564): publicReceiver receive action: android.intent.action.BATTERY_CHANGED
02-22 03:48:22.716 I/===DaemonService===( 4564): device dumpenergy 85
02-22 03:48:22.716 I/===BoradcastDynamic===( 4564): Receive action:android.intent.action.BATTERY_CHANGED
02-22 03:48:22.716 I/===BoradcastDynamic===( 4564): plugged:1, status:2
02-22 03:48:22.718 I/===APKProtocolTransmit===( 4564): Start send su-cmd:302 length[0]
02-22 03:48:22.718 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[302]
02-22 03:48:22.719 I/===APKProtocolTransmit===( 4564): End send sb-cmd [302]
02-22 03:48:22.719 I/===Mrcp===( 4564): sending cmd:105
02-22 03:48:22.726 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:22.793 W/System  ( 3583): ClassLoader referenced unknown path:
02-22 03:48:23.129 W/MediaScanner( 4070): Error opening directory '/oem/media/', skipping: No such file or directory.
02-22 03:48:23.129 W/MediaScanner( 4070): Error opening directory '/product/media/', skipping: No such file or directory.
02-22 03:48:23.151 V/MediaProvider( 4070): pruneThumbnails
02-22 03:48:23.161 V/MediaProvider( 4070): /pruneDeadThumbnailFiles...
02-22 03:48:24.718 I/USBService( 4564): get mobileagent state 0
02-22 03:48:25.699 I/===DaemonService===( 4564): handleMessage 0
02-22 03:48:25.712 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:25.713 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:25.713 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:25.713 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:25.713 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:25.715 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:25.716 I/USBService( 4564): handle message 13
02-22 03:48:25.716 I/USBService( 4564): Will write content:USBService start, Mobile Agnet state 0.
02-22 03:48:25.977 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTPS https://www.google.com/generate_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /69.63.180.173 (port 443) from /172.16.0.118 (port 46608) after 10000ms
02-22 03:48:27.719 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:27.720 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:27.760 W/System  ( 4564): A resource failed to call close.
02-22 03:48:28.715 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:28.715 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:28.716 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:28.716 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:28.716 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:28.717 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:28.972 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://www.google.com/gen_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /69.63.180.173 (port 80) from /172.16.0.118 (port 45670) after 10000ms
02-22 03:48:28.973 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] validation failed
02-22 03:48:29.719 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:29.977 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 3ms OK 69.63.180.173
02-22 03:48:29.977 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 2ms OK 203.208.39.247
02-22 03:48:29.983 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=5ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:06:59 GMT], X-Android-Received-Millis=[1582343309982], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343309978]}
02-22 03:48:31.716 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:31.717 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:31.717 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:31.717 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:31.717 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:31.719 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:32.018 D/DhcpClient( 3407): Received packet: 80:05:88:9e:bc:c4 OFFER, ip /172.16.0.65, mask /255.255.255.0, DNS servers: /172.16.0.1 , gateways [/172.16.0.1] lease time 1800, domain lan
02-22 03:48:32.720 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:32.721 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:34.718 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:34.719 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:34.719 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:34.719 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:34.719 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:34.721 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:34.721 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:36.119 I/ActivityManager( 3407): Waited long enough for: ServiceRecord{9188b62 u0 com.android.calendar/.alerts.InitAlarmsService}
02-22 03:48:37.660 I/ActivityManager( 3407): Waited long enough for: ServiceRecord{cf93ad1 u0 com.sigma_rt.totalcontrol/.USBService}
02-22 03:48:37.720 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:37.721 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:37.721 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:37.721 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:37.721 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:37.722 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:37.723 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:37.723 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:39.722 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:39.991 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTPS https://www.google.com/generate_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /69.63.180.173 (port 443) from /172.16.0.118 (port 46612) after 10000ms
02-22 03:48:40.722 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:40.723 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:40.723 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:40.723 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:40.723 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:40.725 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:42.150 I/system_server( 3407): Background concurrent copying GC freed 49853(2MB) AllocSpace objects, 33(1040KB) LOS objects, 42% free, 5MB/9MB, paused 167us total 132.407ms
02-22 03:48:42.723 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:42.724 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:42.989 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://www.google.com/gen_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /69.63.180.173 (port 80) from /172.16.0.118 (port 45674) after 10000ms
02-22 03:48:42.990 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] validation failed
02-22 03:48:43.724 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:43.724 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:43.725 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:43.725 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:43.725 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:43.727 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:44.723 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:45.001 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 6ms OK 203.208.43.95
02-22 03:48:45.001 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 7ms OK 31.13.84.1
02-22 03:48:45.007 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=5ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:07:14 GMT], X-Android-Received-Millis=[1582343325007], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343325002]}
02-22 03:48:46.726 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:46.726 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:46.727 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:46.727 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:46.727 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:46.729 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:47.723 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:47.724 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:47.967 I/ActivityManager( 3407): START u0 {flg=0x10000000 cmp=com.neolix.videoRecorder/.MainActivity} from uid 0
02-22 03:48:47.994 W/System  ( 3407): ClassLoader referenced unknown path:
02-22 03:48:48.017 I/ActivityManager( 3407): Start proc 4679:com.neolix.videoRecorder/u0a76 for activity com.neolix.videoRecorder/.MainActivity
02-22 03:48:48.020 I/x.videoRecorde( 4679): Late-enabling -Xcheck:jni
02-22 03:48:48.012 W/main    ( 4679): type=1400 audit(0.0:3693): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:48.075 I/display ( 3407): open gpu gralloc module!
02-22 03:48:48.181 I/ConfigStore( 3407): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:48:48.182 I/ConfigStore( 3407): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:48:48.182 I/OpenGLRenderer( 3407): Initialized EGL, version 1.4
02-22 03:48:48.182 D/OpenGLRenderer( 3407): Swap behavior 2
02-22 03:48:48.568 W/x.videoRecorde( 4679): Accessing hidden method Landroid/view/View;->computeFitSystemWindows(Landroid/graphics/Rect;Landroid/graphics/Rect;)Z (light greylist, reflection)
02-22 03:48:48.571 W/x.videoRecorde( 4679): Accessing hidden method Landroid/view/ViewGroup;->makeOptionalFitsSystemWindows()V (light greylist, reflection)
02-22 03:48:48.613 D/OpenGLRenderer( 4679): Skia GL Pipeline
02-22 03:48:48.785 D/ygl     ( 4679): getUserInfo recordTimeInterval:60000,recordVideoNumber:10
02-22 03:48:48.961 I/ConfigStore( 4679): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:48:48.961 I/ConfigStore( 4679): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:48:48.961 I/OpenGLRenderer( 4679): Initialized EGL, version 1.4
02-22 03:48:48.961 D/OpenGLRenderer( 4679): Swap behavior 2
02-22 03:48:48.978 I/display ( 4679): open gpu gralloc module!
02-22 03:48:48.986 W/ServiceManager( 3250): Permission failure: android.permission.ACCESS_SURFACE_FLINGER from uid=10076 pid=4679
02-22 03:48:48.986 D/PermissionCache( 3250): checking android.permission.ACCESS_SURFACE_FLINGER for uid=10076 => denied (1485 us)
02-22 03:48:48.989 I/SurfaceHolder( 4679): main
02-22 03:48:48.992 I/CameraService( 3260): CameraService::connect call (PID -1 "com.neolix.videoRecorder", camera ID 0) for HAL version default and Camera API version 1
02-22 03:48:48.997 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1100) created, clientPid(3260)
02-22 03:48:49.001 E/FileSource( 3254): Failed to open file '/product/media/audio/ui/camera_click.ogg'. (No such file or directory)
02-22 03:48:49.001 E/GenericSource( 3254): Failed to create data source!
02-22 03:48:49.001 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1100), (100, 1, -2147483648, -1), loop setting(0, 0)
02-22 03:48:49.001 E/MediaPlayerNative( 3260): error (1, -2147483648)
02-22 03:48:49.001 E/CameraService( 3260): Failed to load CameraService sounds: /product/media/audio/ui/camera_click.ogg
02-22 03:48:49.001 D/NuPlayerDriver( 3254): reset(0xe82a1100) at state 2
02-22 03:48:49.003 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1100), (8, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.003 D/NuPlayerDriver( 3254): notifyResetComplete(0xe82a1100)
02-22 03:48:49.005 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1180) created, clientPid(3260)
02-22 03:48:49.017 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:49.023 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1180), (1, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.025 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1400) created, clientPid(3260)
02-22 03:48:49.027 E/FileSource( 3254): Failed to open file '/product/media/audio/ui/VideoRecord.ogg'. (No such file or directory)
02-22 03:48:49.027 E/GenericSource( 3254): Failed to create data source!
02-22 03:48:49.027 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1400), (100, 1, -2147483648, -1), loop setting(0, 0)
02-22 03:48:49.027 E/MediaPlayerNative( 3260): error (1, -2147483648)
02-22 03:48:49.027 E/CameraService( 3260): Failed to load CameraService sounds: /product/media/audio/ui/VideoRecord.ogg
02-22 03:48:49.028 D/NuPlayerDriver( 3254): reset(0xe82a1400) at state 2
02-22 03:48:49.028 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1400), (8, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.028 D/NuPlayerDriver( 3254): notifyResetComplete(0xe82a1400)
02-22 03:48:49.029 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1500) created, clientPid(3260)
02-22 03:48:49.034 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:49.040 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1500), (1, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.042 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1600) created, clientPid(3260)
02-22 03:48:49.045 E/FileSource( 3254): Failed to open file '/product/media/audio/ui/VideoStop.ogg'. (No such file or directory)
02-22 03:48:49.045 E/GenericSource( 3254): Failed to create data source!
02-22 03:48:49.045 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1600), (100, 1, -2147483648, -1), loop setting(0, 0)
02-22 03:48:49.045 E/MediaPlayerNative( 3260): error (1, -2147483648)
02-22 03:48:49.045 E/CameraService( 3260): Failed to load CameraService sounds: /product/media/audio/ui/VideoStop.ogg
02-22 03:48:49.046 D/NuPlayerDriver( 3254): reset(0xe82a1600) at state 2
02-22 03:48:49.046 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1600), (8, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.046 D/NuPlayerDriver( 3254): notifyResetComplete(0xe82a1600)
02-22 03:48:49.047 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1680) created, clientPid(3260)
02-22 03:48:49.051 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:49.057 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1680), (1, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.058 I/Camera2ClientBase( 3260): Camera 0: Opened. Client: com.neolix.videoRecorder (PID 4679, UID 10076)
02-22 03:48:49.062 I/FslCameraHAL( 3233): openDev:0: Opening camera device
02-22 03:48:49.062 D/audio_hw_primary( 3231): adev_set_parameters: enter: cameraFacing=back
02-22 03:48:49.063 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:49.067 I/FslCameraHAL( 3233): constructDefaultRequestSettings:0: type=1
02-22 03:48:49.068 E/Camera2-Parameters( 3260): Error finding static metadata entry 'android.distortionCorrection.availableModes' (1b0001)
02-22 03:48:49.068 I/Camera2-Parameters( 3260): Camera 0: Disabling ZSL mode
02-22 03:48:49.068 I/Camera2-Parameters( 3260): initialize: allowZslMode: 0 slowJpegMode 0
02-22 03:48:49.068 I/FslCameraHAL( 3233): constructDefaultRequestSettings:0: type=2
02-22 03:48:49.069 I/Camera2-CallbackProcessor( 3260): libopencl-2d.so is existed!
02-22 03:48:49.069 E/linker  ( 3260): library "/vendor/lib/libopencl-2d.so" ("/vendor/lib/libopencl-2d.so") needed or dlopened by "/system/lib/libcameraservice.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib", permitted_paths="/system/lib/drm:/system/lib/extractors:/system/lib/hw:/system/product/lib:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:49.077 I/FslCameraHAL( 3233): configureStreams:0: stream_config 0xeacfd500, num 2, streams 0xec817180, mode 0
02-22 03:48:49.077 I/FslCameraHAL( 3233): config 0, type 0, res 1280x720, fmt 0x22, usage 0x900, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.077 I/FslCameraHAL( 3233): config 1, type 0, res 1280x720, fmt 0x21, usage 0x3, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.077 I/FslCameraHAL( 3233): Stream create preview stream
02-22 03:48:49.077 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp getPreviewPixelFormat
02-22 03:48:49.077 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x103, usage:0x20b02, buffers:3
02-22 03:48:49.077 I/FslCameraHAL( 3233): Stream create capture stream
02-22 03:48:49.077 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x21, usage:0x20303, buffers:2
02-22 03:48:49.080 D/Camera3-Device( 3260): Set real time priority for request queue thread (tid 4734)
02-22 03:48:49.080 I/SurfaceHolder( 4679): surfaceChanged()
02-22 03:48:49.081 D/SurfaceFlinger( 3250): duplicate layer name: changing SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#1
02-22 03:48:49.082 D/SurfaceFlinger( 3250): duplicate layer name: changing Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#1
02-22 03:48:49.088 I/SurfaceHolder( 4679): main
02-22 03:48:49.089 I/CameraService( 3260): CameraService::connect call (PID -1 "com.neolix.videoRecorder", camera ID 1) for HAL version default and Camera API version 1
02-22 03:48:49.090 I/Camera2ClientBase( 3260): Camera 1: Opened. Client: com.neolix.videoRecorder (PID 4679, UID 10076)
02-22 03:48:49.093 I/FslCameraHAL( 3233): openDev:1: Opening camera device
02-22 03:48:49.093 D/audio_hw_primary( 3231): adev_set_parameters: enter: cameraFacing=front
02-22 03:48:49.093 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:49.097 I/FslCameraHAL( 3233): constructDefaultRequestSettings:1: type=1
02-22 03:48:49.098 E/Camera2-Parameters( 3260): Error finding static metadata entry 'android.distortionCorrection.availableModes' (1b0001)
02-22 03:48:49.098 I/Camera2-Parameters( 3260): Camera 1: Disabling ZSL mode
02-22 03:48:49.098 I/Camera2-Parameters( 3260): initialize: allowZslMode: 0 slowJpegMode 0
02-22 03:48:49.098 I/FslCameraHAL( 3233): constructDefaultRequestSettings:1: type=2
02-22 03:48:49.099 I/Camera2-CallbackProcessor( 3260): libopencl-2d.so is existed!
02-22 03:48:49.107 E/linker  ( 3260): library "/vendor/lib/libopencl-2d.so" ("/vendor/lib/libopencl-2d.so") needed or dlopened by "/system/lib/libcameraservice.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib", permitted_paths="/system/lib/drm:/system/lib/extractors:/system/lib/hw:/system/product/lib:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:49.114 I/FslCameraHAL( 3233): configureStreams:1: stream_config 0xeabff500, num 2, streams 0xeaf0d020, mode 0
02-22 03:48:49.114 I/FslCameraHAL( 3233): config 0, type 0, res 1280x720, fmt 0x22, usage 0x900, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.114 I/FslCameraHAL( 3233): config 1, type 0, res 1280x720, fmt 0x21, usage 0x3, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.114 I/FslCameraHAL( 3233): Stream create preview stream
02-22 03:48:49.114 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp getPreviewPixelFormat
02-22 03:48:49.114 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x103, usage:0x20b02, buffers:3
02-22 03:48:49.114 I/FslCameraHAL( 3233): Stream create capture stream
02-22 03:48:49.114 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x21, usage:0x20303, buffers:2
02-22 03:48:49.115 D/Camera3-Device( 3260): Set real time priority for request queue thread (tid 4741)
02-22 03:48:49.116 I/SurfaceHolder( 4679): surfaceChanged()
02-22 03:48:49.118 D/SurfaceFlinger( 3250): duplicate layer name: changing SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#2
02-22 03:48:49.120 D/SurfaceFlinger( 3250): duplicate layer name: changing Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#2
02-22 03:48:49.132 I/display ( 3260): open gpu gralloc module!
02-22 03:48:49.139 I/SurfaceHolder( 4679): main
02-22 03:48:49.140 I/CameraService( 3260): CameraService::connect call (PID -1 "com.neolix.videoRecorder", camera ID 2) for HAL version default and Camera API version 1
02-22 03:48:49.142 I/Camera2ClientBase( 3260): Camera 2: Opened. Client: com.neolix.videoRecorder (PID 4679, UID 10076)
02-22 03:48:49.144 I/FslCameraHAL( 3233): openDev:2: Opening camera device
02-22 03:48:49.144 D/audio_hw_primary( 3231): adev_set_parameters: enter: cameraFacing=front
02-22 03:48:49.144 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:49.147 I/display ( 3233): open gpu gralloc module!
02-22 03:48:49.147 I/FslCameraHAL( 3233): constructDefaultRequestSettings:2: type=1
02-22 03:48:49.148 E/Camera2-Parameters( 3260): Error finding static metadata entry 'android.distortionCorrection.availableModes' (1b0001)
02-22 03:48:49.148 I/Camera2-Parameters( 3260): Camera 2: Disabling ZSL mode
02-22 03:48:49.148 I/Camera2-Parameters( 3260): initialize: allowZslMode: 0 slowJpegMode 0
02-22 03:48:49.148 I/FslCameraHAL( 3233): constructDefaultRequestSettings:2: type=2
02-22 03:48:49.149 I/FslCameraHAL( 3233): configure: w:1280, h:720, sensor format:0x14, stream format:0x103, fps:30, num:3
02-22 03:48:49.149 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp onDeviceConfigureLocked
02-22 03:48:49.149 I/FslCameraHAL( 3233): Width * Height 1280 x 720 format YUYV, fps: 30
02-22 03:48:49.149 I/FslCameraHAL( 3233): onDeviceStartLocked
02-22 03:48:49.149 I/Camera2-CallbackProcessor( 3260): libopencl-2d.so is existed!
02-22 03:48:49.150 I/FslCameraHAL( 3233): configure: w:1280, h:720, sensor format:0x14, stream format:0x103, fps:30, num:3
02-22 03:48:49.150 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp onDeviceConfigureLocked
02-22 03:48:49.150 I/FslCameraHAL( 3233): Width * Height 1280 x 720 format YUYV, fps: 30
02-22 03:48:49.150 I/FslCameraHAL( 3233): onDeviceStartLocked
02-22 03:48:49.150 E/linker  ( 3260): library "/vendor/lib/libopencl-2d.so" ("/vendor/lib/libopencl-2d.so") needed or dlopened by "/system/lib/libcameraservice.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib", permitted_paths="/system/lib/drm:/system/lib/extractors:/system/lib/hw:/system/product/lib:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:49.156 I/FslCameraHAL( 3233): configureStreams:2: stream_config 0xffc10fa0, num 2, streams 0xec8171a0, mode 0
02-22 03:48:49.156 I/FslCameraHAL( 3233): config 0, type 0, res 1280x720, fmt 0x22, usage 0x900, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.156 I/FslCameraHAL( 3233): config 1, type 0, res 1280x720, fmt 0x21, usage 0x3, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.156 I/FslCameraHAL( 3233): Stream create preview stream
02-22 03:48:49.156 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp getPreviewPixelFormat
02-22 03:48:49.156 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x103, usage:0x20b02, buffers:3
02-22 03:48:49.156 I/FslCameraHAL( 3233): Stream create capture stream
02-22 03:48:49.156 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x21, usage:0x20303, buffers:2
02-22 03:48:49.159 D/Camera3-Device( 3260): Set real time priority for request queue thread (tid 4750)
02-22 03:48:49.159 I/SurfaceHolder( 4679): surfaceChanged()
02-22 03:48:49.161 D/SurfaceFlinger( 3250): duplicate layer name: changing SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#3
02-22 03:48:49.173 D/SurfaceFlinger( 3250): duplicate layer name: changing Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#3
02-22 03:48:49.188 I/SurfaceHolder( 4679): main
02-22 03:48:49.189 I/CameraService( 3260): CameraService::connect call (PID -1 "com.neolix.videoRecorder", camera ID 3) for HAL version default and Camera API version 1
02-22 03:48:49.191 I/Camera2ClientBase( 3260): Camera 3: Opened. Client: com.neolix.videoRecorder (PID 4679, UID 10076)
02-22 03:48:49.193 I/FslCameraHAL( 3233): configure: w:1280, h:720, sensor format:0x14, stream format:0x103, fps:30, num:3
02-22 03:48:49.193 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp onDeviceConfigureLocked
02-22 03:48:49.193 I/FslCameraHAL( 3233): Width * Height 1280 x 720 format YUYV, fps: 30
02-22 03:48:49.193 I/FslCameraHAL( 3233): onDeviceStartLocked
02-22 03:48:49.194 I/FslCameraHAL( 3233): openDev:3: Opening camera device
02-22 03:48:49.194 D/audio_hw_primary( 3231): adev_set_parameters: enter: cameraFacing=front
02-22 03:48:49.194 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:49.197 I/FslCameraHAL( 3233): constructDefaultRequestSettings:3: type=1
02-22 03:48:49.198 E/Camera2-Parameters( 3260): Error finding static metadata entry 'android.distortionCorrection.availableModes' (1b0001)
02-22 03:48:49.198 I/Camera2-Parameters( 3260): Camera 3: Disabling ZSL mode
02-22 03:48:49.198 I/Camera2-Parameters( 3260): initialize: allowZslMode: 0 slowJpegMode 0
02-22 03:48:49.199 I/FslCameraHAL( 3233): constructDefaultRequestSettings:3: type=2
02-22 03:48:49.199 I/Camera2-CallbackProcessor( 3260): libopencl-2d.so is existed!
02-22 03:48:49.200 E/linker  ( 3260): library "/vendor/lib/libopencl-2d.so" ("/vendor/lib/libopencl-2d.so") needed or dlopened by "/system/lib/libcameraservice.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib", permitted_paths="/system/lib/drm:/system/lib/extractors:/system/lib/hw:/system/product/lib:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:49.208 I/FslCameraHAL( 3233): configureStreams:3: stream_config 0xeb07f500, num 2, streams 0xeaf0d010, mode 0
02-22 03:48:49.208 I/FslCameraHAL( 3233): config 0, type 0, res 1280x720, fmt 0x22, usage 0x900, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.208 I/FslCameraHAL( 3233): config 1, type 0, res 1280x720, fmt 0x21, usage 0x3, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.208 I/FslCameraHAL( 3233): Stream create preview stream
02-22 03:48:49.208 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp getPreviewPixelFormat
02-22 03:48:49.208 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x103, usage:0x20b02, buffers:3
02-22 03:48:49.208 I/FslCameraHAL( 3233): Stream create capture stream
02-22 03:48:49.208 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x21, usage:0x20303, buffers:2
02-22 03:48:49.210 D/Camera3-Device( 3260): Set real time priority for request queue thread (tid 4758)
02-22 03:48:49.210 I/SurfaceHolder( 4679): surfaceChanged()
02-22 03:48:49.228 I/FslCameraHAL( 3233): configure: w:1280, h:720, sensor format:0x14, stream format:0x103, fps:30, num:3
02-22 03:48:49.228 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp onDeviceConfigureLocked
02-22 03:48:49.228 I/FslCameraHAL( 3233): Width * Height 1280 x 720 format YUYV, fps: 30
02-22 03:48:49.228 I/FslCameraHAL( 3233): onDeviceStartLocked
02-22 03:48:49.380 I/ActivityManager( 3407): Displayed com.neolix.videoRecorder/.MainActivity: +1s382ms
02-22 03:48:49.542 W/SurfaceFlinger( 3250): Attempting to set client state on removed layer: Splash Screen com.neolix.videoRecorder#0
02-22 03:48:49.542 W/SurfaceFlinger( 3250): Attempting to destroy on removed layer: Splash Screen com.neolix.videoRecorder#0
02-22 03:48:49.724 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:49.728 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:49.729 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:49.729 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:49.729 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:49.729 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:49.730 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:49.976 W/FslCameraHAL( 3233): opencl g2d device is used!
02-22 03:48:49.982 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:49.998 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.014 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.033 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.091 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.192 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.357 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.426 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.827 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.025 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.092 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.154 D/InitAlarmsService( 4327): Clearing and rescheduling alarms.
02-22 03:48:51.259 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.292 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:51.328 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.391 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.459 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.491 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.522 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.624 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:51.926 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.024 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.060 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.090 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.124 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.357 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.425 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.494 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.522 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.557 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.691 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.724 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:52.725 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:52.730 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:52.730 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:52.731 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:52.731 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:52.731 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:52.733 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:52.792 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.858 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.057 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.125 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.191 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:48:53.225 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.292 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.424 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.491 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.591 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.826 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.858 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.924 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.027 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.089 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.124 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.192 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.225 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.259 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:54.291 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.693 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.725 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:54.758 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.928 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.015 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTPS https://www.google.com/generate_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 443) from /172.16.0.118 (port 58272) after 10000ms
02-22 03:48:55.062 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.391 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.489 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.526 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.624 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.692 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.732 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:55.732 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:55.733 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:55.733 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:55.733 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:55.734 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:55.893 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.923 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.957 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:56.057 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.123 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.424 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.453 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.557 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.890 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.956 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:57.056 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:57.288 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:57.725 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:57.726 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:57.726 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:57.856 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:57.890 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:57.923 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:57.991 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.007 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://www.google.com/gen_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 80) from /172.16.0.118 (port 34058) after 10000ms
02-22 03:48:58.007 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] validation failed
02-22 03:48:58.024 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.089 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:48:58.361 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.423 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.457 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.490 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.523 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.592 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:58.658 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.734 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:58.734 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:58.734 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:58.734 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:58.734 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:58.736 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:58.856 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:59.355 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 7 lines
02-22 03:48:59.390 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:59.523 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:59.723 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:59.725 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:59.957 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:59.989 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.064 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.088 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.160 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.225 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.256 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.353 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.426 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.489 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:00.522 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.589 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.955 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 3 lines
02-22 03:49:01.053 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.057 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.189 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.224 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.323 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.393 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.525 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:01.555 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.736 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:01.736 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:01.737 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:01.737 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:01.737 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:01.739 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:01.757 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.864 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:01.989 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.014 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 2ms OK 31.13.84.1
02-22 03:49:02.014 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 2ms OK 203.208.43.95
02-22 03:49:02.020 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=5ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:07:31 GMT], X-Android-Received-Millis=[1582343342019], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343342015]}
02-22 03:49:02.026 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.158 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.330 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.655 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.726 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:02.727 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:02.755 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.821 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.888 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.922 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.963 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.022 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.055 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.163 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 3 lines
02-22 03:49:03.224 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.288 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.319 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.384 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:03.421 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.551 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.595 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.754 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.786 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.821 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.055 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.088 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.123 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.154 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.221 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.356 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.389 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.517 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:04.552 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.587 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.621 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.653 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:04.687 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.727 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:04.737 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:04.737 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:04.739 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:04.739 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:04.742 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:04.745 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:04.753 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.854 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.887 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.987 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.094 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.254 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:05.319 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.386 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.453 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:05.619 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.656 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.885 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.923 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:05.953 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:06.087 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:06.119 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:06.154 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:06.421 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 3 lines
02-22 03:49:06.686 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:06.723 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.022 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:07.186 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.218 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.251 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.285 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:07.322 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.389 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.405 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.420 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.422 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.505 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 5 lines
02-22 03:49:07.522 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.529 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.538 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.689 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 9 lines
02-22 03:49:07.705 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.720 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.722 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.727 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:07.728 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:07.738 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.740 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:07.740 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:07.741 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:07.741 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:07.741 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:07.743 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:07.756 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.905 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 9 lines
02-22 03:49:07.925 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.983 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.054 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.225 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.252 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.386 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.419 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.457 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.495 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.655 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.718 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.020 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.053 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.119 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.185 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.384 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.487 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.650 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.727 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:09.854 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:10.221 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:10.320 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:10.386 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:10.744 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:10.744 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:10.745 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:10.745 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:10.745 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:10.746 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:10.752 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:10.854 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:10.984 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.183 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.285 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.452 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.652 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:11.787 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.817 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.917 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.988 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.028 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTPS https://www.google.com/generate_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 443) from /172.16.0.118 (port 58276) after 10000ms
02-22 03:49:12.084 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.284 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.451 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.485 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.517 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.685 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 3 lines
02-22 03:49:12.720 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.728 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:12.729 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:12.786 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.817 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.951 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.017 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.083 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.119 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.183 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.518 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.683 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.745 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:13.745 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:13.746 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:13.746 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:13.746 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:13.748 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:13.754 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.917 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:14.018 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.083 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.149 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:14.250 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.284 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.318 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.616 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:14.654 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.685 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.728 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:14.850 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.883 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.016 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.025 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://www.google.com/gen_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 80) from /172.16.0.118 (port 34062) after 10000ms
02-22 03:49:15.054 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.083 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.116 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.149 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.183 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.316 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.353 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.416 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.684 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.717 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.817 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.919 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:16.183 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:16.252 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:16.316 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:16.419 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:16.618 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:16.649 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:16.747 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:16.747 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:16.747 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:16.747 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:16.747 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:16.749 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:16.886 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.050 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.216 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.283 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.317 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.350 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:17.419 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.728 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:17.729 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:17.851 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.883 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.949 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.983 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.217 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.349 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.385 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.420 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.483 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.749 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.751 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.783 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.819 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.850 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.884 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.948 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.986 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.018 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.048 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.216 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.250 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.350 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.516 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.649 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:19.719 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.729 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:19.748 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:19.748 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:19.748 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:19.748 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:19.748 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:19.750 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:19.882 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.983 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.085 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.115 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.215 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:20.252 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.416 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.452 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:20.513 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.551 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.583 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.650 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.915 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.951 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.025 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] validation failed
02-22 03:49:21.010 I/ActivityManager( 3407): Killing 4130:com.android.quicksearchbox/u0a41 (adj 906): empty #17
02-22 03:49:21.011 W/libprocessgroup( 3407): kill(-4130, 9) failed: No such process
02-22 03:49:21.033 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.047 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 3 lines
02-22 03:49:21.052 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.057 W/libprocessgroup( 3407): kill(-4130, 9) failed: No such process
02-22 03:49:21.057 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.069 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 2 lines
02-22 03:49:21.071 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.076 I/Zygote  ( 3220): Process 4130 exited due to signal (9)
02-22 03:49:21.079 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.095 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 2 lines
02-22 03:49:21.099 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.102 W/libprocessgroup( 3407): kill(-4130, 9) failed: No such process
02-22 03:49:21.102 I/libprocessgroup( 3407): Successfully killed process cgroup uid 10041 pid 4130 in 91ms
02-22 03:49:21.103 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.133 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 5 lines
02-22 03:49:21.147 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.149 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.168 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.181 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.182 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.186 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.273 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 11 lines
02-22 03:49:21.276 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.279 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.281 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.540 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 31 lines
02-22 03:49:21.546 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.549 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.570 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.576 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 2 lines
02-22 03:49:21.582 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.584 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.586 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.593 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 3 lines
02-22 03:49:21.604 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.605 I/BackgroundDexOptService( 3407): Pinning optimized code {}
02-22 03:49:21.649 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.681 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.718 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.815 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.848 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.915 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.948 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.082 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.115 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.216 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.249 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.549 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 5 lines
02-22 03:49:22.582 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.681 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.683 D/DhcpClient( 3407): Received packet: 80:05:88:b7:35:48 OFFER, ip /172.16.0.43, mask /255.255.255.0, DNS servers: /172.16.0.1 , gateways [/172.16.0.1] lease time 1800, domain lan
02-22 03:49:22.714 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.729 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:22.730 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:22.749 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:22.749 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:22.750 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:22.750 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:22.750 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:22.752 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:22.817 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.880 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.918 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.984 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:23.033 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 1ms OK 31.13.84.1
02-22 03:49:23.033 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 1ms OK 203.208.43.95
02-22 03:49:23.039 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=5ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:07:52 GMT], X-Android-Received-Millis=[1582343363039], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343363034]}
02-22 03:49:23.047 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:23.682 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 6 lines
02-22 03:49:23.718 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:23.813 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:23.950 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.048 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.115 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.215 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.519 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.681 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.729 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:24.881 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.052 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.114 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.415 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 6 lines
02-22 03:49:25.481 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.578 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.584 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.614 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.684 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.715 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.750 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:25.751 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:25.751 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:25.751 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:25.751 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:25.753 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:25.814 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.914 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.982 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.023 D/SntpClient( 3407): request time failed: java.net.SocketTimeoutException: Poll timed out
02-22 03:49:26.084 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.115 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.214 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.348 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.384 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.549 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:26.581 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.713 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.749 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.781 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.818 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.882 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.980 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.015 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.082 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.115 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.149 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.215 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.248 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.282 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:27.317 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.482 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.730 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:27.730 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:27.948 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.248 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.348 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.414 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.481 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.715 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 5 lines
02-22 03:49:28.750 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.752 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:28.752 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:28.752 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:28.753 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:28.753 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:28.762 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:28.815 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.850 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.883 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.912 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.980 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:29.047 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.114 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.148 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.214 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.281 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.312 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.346 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.377 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.481 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.515 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.647 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.717 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.730 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:29.847 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.913 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.082 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.146 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.248 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.278 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.333 D/AndroidRuntime( 4787): >>>>>> START com.android.internal.os.RuntimeInit uid 0 <<<<<<
02-22 03:49:30.561 I/app_process( 4787): The ClassLoaderContext is a special shared library.
02-22 03:49:30.615 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.636 D/AndroidRuntime( 4787): Calling main entry com.android.commands.input.Input
02-22 03:49:30.637 I/Input   ( 4787): injectKeyEvent: KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=0, metaState=0, flags=0x0, repeatCount=0, eventTime=106695, downTime=106695, deviceId=-1, source=0x101 }
02-22 03:49:30.646 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.651 I/Input   ( 4787): injectKeyEvent: KeyEvent { action=ACTION_UP, keyCode=KEYCODE_BACK, scanCode=0, metaState=0, flags=0x0, repeatCount=0, eventTime=106695, downTime=106695, deviceId=-1, source=0x101 }
02-22 03:49:30.651 D/AutofillManagerService( 3407): onBackKeyPressed()
02-22 03:49:30.658 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.666 D/ygl     ( 4679): onPause camera1android.hardware.Camera@9fd9423
02-22 03:49:30.666 D/AndroidRuntime( 4787): Shutting down VM
02-22 03:49:30.666 I/FslCameraHAL( 3233): flushDev:0: Flushing camera device
02-22 03:49:30.672 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.685 I/FslCameraHAL( 3233): onFlushLocked, v4l2 memory type 1, mV4l2BufType 9
02-22 03:49:30.689 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.788 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 6 lines
02-22 03:49:30.805 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.813 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.817 I/FslCameraHAL( 3233): flushDev:0: Flushing camera device
02-22 03:49:30.817 I/FslCameraHAL( 3233): onFlushLocked, v4l2 memory type 1, mV4l2BufType 9
02-22 03:49:30.822 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.889 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 4 lines
02-22 03:49:30.905 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260): Stream 0 dequeueBuffer latency histogram (1223) samples:
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260):         5     10     15     20     25     30     35     40     45    inf (max ms)
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260):      1.14   31.81   34.51   23.79   8.59   0.00   0.08   0.00   0.00   0.08 (%)
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260): Stream 0 latency histogram for wait on max_buffers (1220) samples:
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260):        33     66     99    132    165    198    231    264    297    inf (max ms)
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260):      99.92   0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.08 (%)
02-22 03:49:30.919 I/Camera3-Device( 3260): disconnect: E
02-22 03:49:30.919 I/CameraLatencyHistogram( 3260): ProcessCaptureRequest latency histogram (1223) samples:
02-22 03:49:30.919 I/CameraLatencyHistogram( 3260):        40     80    120    160    200    240    280    320    360    inf (max ms)
02-22 03:49:30.919 I/CameraLatencyHistogram( 3260):      99.84   0.08   0.00   0.00   0.00   0.00   0.00   0.00   0.08   0.00 (%)
02-22 03:49:30.919 I/FslCameraHAL( 3233): closeDev:0: Closing camera device
02-22 03:49:30.919 I/FslCameraHAL( 3233): onDeviceStopLocked
02-22 03:49:30.919 I/Camera3-Device( 3260): disconnect: X
02-22 03:49:30.920 I/Camera3-Device( 3260): disconnect: E
02-22 03:49:30.924 I/CameraService( 3260): disconnect: Disconnected client for camera 0 for PID 4679
02-22 03:49:30.925 I/Camera2Client( 3260): Camera 0: Closed
02-22 03:49:30.925 D/ygl     ( 4679): camera1 stopPreview() release()
02-22 03:49:30.925 D/ygl     ( 4679): onPause camera2android.hardware.Camera@a2ced20
02-22 03:49:30.925 I/FslCameraHAL( 3233): flushDev:1: Flushing camera device
02-22 03:49:30.926 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.926 I/Camera2ClientBase( 3260): Closed Camera 0. Client was: com.neolix.videoRecorder (PID 4679, UID 10076)
02-22 03:49:30.938 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:31.163 W/ActivityManager( 3407): Activity pause timeout for ActivityRecord{4051270 u0 com.neolix.videoRecorder/.MainActivity t61 f}
02-22 03:49:31.172 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 14 lines
02-22 03:49:31.188 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:31.262 D/PermissionCache( 3250): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (215 us)
02-22 03:49:31.332 W/ServiceManager( 3250): Permission failure: android.permission.ACCESS_SURFACE_FLINGER from uid=10027 pid=4086
02-22 03:49:31.332 D/PermissionCache( 3250): checking android.permission.ACCESS_SURFACE_FLINGER for uid=10027 => denied (489 us)
02-22 03:49:31.753 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:31.753 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:31.753 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:31.753 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:31.753 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:31.754 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:31.776 I/ConfigStore( 3407): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:49:31.776 I/ConfigStore( 3407): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:49:31.776 I/OpenGLRenderer( 3407): Initialized EGL, version 1.4
02-22 03:49:31.776 D/OpenGLRenderer( 3407): Swap behavior 2
02-22 03:49:32.730 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:32.731 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:33.018 D/DhcpClient( 3407): Received packet: 80:05:88:9e:bc:c4 OFFER, ip /172.16.0.65, mask /255.255.255.0, DNS servers: /172.16.0.1 , gateways [/172.16.0.1] lease time 1800, domain lan
02-22 03:49:33.045 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTPS https://www.google.com/generate_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 443) from /172.16.0.118 (port 58280) after 10000ms
02-22 03:49:34.730 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:34.754 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:34.754 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:34.754 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:34.754 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:34.754 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:34.756 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:36.046 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://www.google.com/gen_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 80) from /172.16.0.118 (port 34066) after 10000ms
02-22 03:49:36.046 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] validation failed
02-22 03:49:37.731 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:37.732 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:37.755 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:37.755 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:37.756 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:37.756 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:37.756 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:37.757 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:39.731 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:40.756 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:40.756 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:40.757 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:40.757 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:40.757 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:40.758 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:41.755 W/ActivityManager( 3407): Activity destroy timeout for ActivityRecord{4051270 u0 com.neolix.videoRecorder/.MainActivity t61 f}
02-22 03:49:41.766 W/SurfaceFlinger( 3250): Attempting to destroy on removed layer: AppWindowToken{1e8066e token=Token{46729e9 ActivityRecord{4051270 u0 com.neolix.videoRecorder/.MainActivity t61}}}#0
02-22 03:49:42.731 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:42.732 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:43.757 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:43.758 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:43.758 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:43.758 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:43.758 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:43.760 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:44.732 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:46.759 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:46.759 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:46.760 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:46.760 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:46.760 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:46.761 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:47.732 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:47.733 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:49.733 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:49.761 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:49.761 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:49.761 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:49.761 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:49.761 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:49.763 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:52.066 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 2ms OK 203.208.43.95
02-22 03:49:52.066 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 3ms OK 31.13.84.1
02-22 03:49:52.073 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=5ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:08:21 GMT], X-Android-Received-Millis=[1582343392072], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343392068]}
02-22 03:49:52.733 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:52.733 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:52.762 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:52.762 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:52.762 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:52.762 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:52.762 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:52.763 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:54.734 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:55.177 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://play.googleapis.com/generate_204 Probe failed with exception java.net.SocketException: Connection reset
02-22 03:49:55.763 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:55.763 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:55.763 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:55.763 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:55.763 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:55.764 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
5 返答(返信)
3,733件の閲覧回数
diegoadrian
Unfortunately, the image sensor that you are using is not supported by our BSP. I suggest you change to the OV5640 that is the supported camera by our BSP.
Diego.
3,733件の閲覧回数
jack-cap
HI Diego Adrian Cuevas,
Our camera can open sucessfuly. but closing the second camera that has been opened would fail.Pls help to confirm the problem of multiple cameras being switched on and off at the same time on Android P. Thanks a lot.
3,733件の閲覧回数
diegoadrian
What I am trying to say. Is that the problem could be related to the driver. However, the product is still not completely released. The BSP could not work properly until the i.MX8QM is completely released. We cannot guarantee if it will work properly.
Diego.
3,733件の閲覧回数
jack-cap
hello,
How to use vpu/gpu encode video stream on imx8qm with Android P OS. pls give suggestions about vpu/gpu encode,thanks.
3,733件の閲覧回数
diegoadrian
Unfortunately, most of the information about i.MX8QM is still under revision and we cannot provide proper support of the product until is completely released. I apologize for the inconvenience this may give you.
Diego.
