Manual page 44 there is two different values for the reference clock RTC OSC = 32.768 kHz and 32.678 kHz? Is this a mistake or they are referring to two different clocks?
Thank you,
Tarek
Solved! Go to Solution.
1)Is this a mistake or they are referring to two different clocks?
-- Yes, this is a mistake, the 32.678 kHz should be a typo.
TIC
TIC
