Cannot wake up from freeze with GPIO
搜索替代
1,046 次查看
geraldheinig
I have an i.MX6 custom board that is very similar to the Sabre SD running Yocto Linux 4.1.15.
Determining the available power settings for my board gives the following:
# cat /sys/power/state
freeze standby mem
I have created a device tree entry for the gpio-keys driver to wake my board up from a GPIO pin:
Pinctrl entry:
pinctrl_gpio_keys: gpio_keysgrp {
                fsl,pins = <
                                MX6QDL_PAD_GPIO_2__GPIO1_IO02                  0x1b0b0 // Alert Button
// Enable wakeup from sleep via emergency button
gpio-keys {
                compatible = "gpio-keys";
                pinctrl-names = "default";
                pinctrl-0 = <&pinctrl_gpio_keys>;
                power {
                                label = "Alert-Button";
                                gpios = <&gpio1 2 IRQ_TYPE_EDGE_RISING>;
                                interrupts = <66 IRQ_TYPE_LEVEL_HIGH 7>;
                                linux,code = <118>; /* KEY_CTRL_LEFT */
                                gpio-key,wakeup;
This works fine for the sleep modes entered using 'mem' and 'standby', ie.
# echo mem > /sys/power/state
and
# echo standby > /sys/power/state
I can wake the system up successfully with my GPIO button from these 2 states.
However, this does not work with the 'freeze' mode:
# echo freeze > /sys/power/state
// cannot wake up, need to reset board
Can anyone explain why the freeze mode doesn't work, but the others do?
标签 (2)
4 回复数
541 次查看
vinothkumars
Senior Contributor IV
Hi Gerald Heinig,
Will you please give your configuration. I am also struggling in wake up.
Thanks & Regards,
VinothS,
Vinothkumar Sekar
541 次查看
geraldheinig
Hello Vinothkumar,
I'm afraid I no longer have access to the code; the project was completed three years ago. I'm sorry I can't help.
Gerald
541 次查看
vinothkumars
Thank you Gerald Heinig for the reply.
Currently, I am working on IMX8QM with Android Automotive  - Power Management.
Just I need some info. Actually, I am trying with most of the functionality.
VinothS,
Vinothkumar Sekar
541 次查看
Carlos_Musich
Hi Gerald,
neither in the Linux Reference Manual or the PMIC Reference Manual is documented a freeze mode. So I dont think it is implemented.
Where did you find a reference to freeze mode?
Carlos
