Hi everyone,
I tried to start example project rpmsg_lite_pingpong_rtos_linux_remote from SDK. First i build m33 release and flashed it. Then in a35 I used insmod imx_rpmsg_pingpong.ko, but ttyRPMSG didn't show up and m33 stucked on waiting of link. Also attached logs of cores.
What is wrong?
Solved! Go to Solution.
In picocoremx8ulp.dts I added #define SUPPORT_M33 and example statrted to work!
Hello @dzmitry
Could you please share your SDK version and your BSP version?
Also, please share the Arm GCC toolchain used to compile the .bin file.
Salas.
SDK_2_16_000_MIMX8UD5xxx08
BSP 6.1.55_2.2.0
arm-gnu-toolchain-13.2.Rel1-mingw-w64-i686-arm-none-eabi
Unfortunately I could not replicate by my side, but could you please try to append the clk_ignore_unused to the mmcargs in U-boot?
For the logs, make me think that the M33 is gating during the boot process of cortex A.
Salas.
I appended the clk_ignore_unused to the mmcargs in U-boot, but it didn't helped. What else can you suggest to detect problem?
