Can't apply gamma correction to /dev/fb2
989 次查看
mirkoardinghi1
I need to change the GAMMA value (with the ioctl MXCFB_SET_GAMMA) to framebuffer /dev/fb2
I developed a simple program with whom I can successfully change the gamma value to /dev/fb0 but when I try with /dev/fb2 I obtain the following error:
Ioctl MXCFB_SET_GAMMA fail!
I'm using a imx6duallite with linux yocto (krogoth version)
Any help?
标签 (3)
732 次查看
Hi Mirko
for gamma correction examples one can look at
ipu-examples release notes - v0.1
also one can try unblank fb2 like
echo 0 > /sys/class/graphics/fb2/blank
732 次查看
mirkoardinghi1
Hi Igor,
I tested the ipu-examples but the problem remains. In this test (in mx6/framebuffer/example1/) has been tested only the gamma for /dev/fb0, if I change /dev/fb0 with /dev/fb2 I obtain the same failure:
Thanks in advance.
Mirko
