Anyone konw whether i.MX6DualLite CPU support AMP mode? As dual Cortex-A9 core inside, I guess the answer should be YES; but I never found any document describe this clearly. We want to run Linux+RTOS on this chip.
Solved! Go to Solution.
Correct,
some details regarding AMP on ARM Cortex A9 MPCore may be found below.
Correct,
