Can HDMI's audio be adjusted?
搜索替代
699 次查看
conteczxy
I am working on imx6q, android4.4.2, kernel 3.0.35, with hdmi display.
I found sound is output through hdmi, but when I adjust the sound to low or high in android settings-> sound volume, it doesn't take effect.
So, I want to know if it is possible to adjust sound of hdmi audio?
Thanks.
标签 (2)
标记 (1)
503 次查看
weidong_sun
Hi Xiyuan,
  I have got the following solution from my colleague and tested it!
  Two modifications were needed to adjust hdmi volume:
  1. “myandroid/hardware/libhardware_legacy/audio/AudioPolicyManagerBase.cpp”, function computeVolume()
From
    // if volume is not 0 (not muted), force media volume to max on digital output
    if (stream == AudioSystem::MUSIC &&
        index != mStreams[stream].mIndexMin &&
        (((device == AUDIO_DEVICE_OUT_AUX_DIGITAL) && (mDeviceIsHdmidongle == false)) ||
         device == AUDIO_DEVICE_OUT_DGTL_DOCK_HEADSET ||
         device == AUDIO_DEVICE_OUT_USB_ACCESSORY ||
         device == AUDIO_DEVICE_OUT_USB_DEVICE)) {
        return 1.0;
To
        (device == AUDIO_DEVICE_OUT_DGTL_DOCK_HEADSET ||
        return 1.0;
  1. “myandroid/frameworks/base/media/java/android/media/AudioService.java
From
        if (SystemProperties.get("ro.product.device").contains("hdmidongle"))
                           mFixedVolumeDevices &= ~AudioSystem.DEVICE_OUT_AUX_DIGITAL;
To
Best Regards
Weidong
503 次查看
conteczxy
Thank you very much for your fast and effective response。
