Can Android BSP build with multi-thread?
1,208 次查看
DeanHuang
I would like to build i.MX6 Android BSP with multi-thread,
make PRODUCT-sabresd_6dq-eng- -j4 2>&1 | tee build_sabresd_6dq_android.log
but some files will not be built in out/target/product/sabresd_6dq/.
ex: system.img, recovery.img  (see out.png)
These files will be built if I do not use -jN
make PRODUCT-sabresd_6dq-eng- 2>&1 | tee build_sabresd_6dq_android.log
Does I use the wrong instruction?
标签 (2)
标记 (1)
934 次查看
LeonardoSandova
Specialist I
In the case you don't specify the -JN, do you see the images? any error log on the compilation?
Leo
934 次查看
DeanHuang
Hi Leo,
If I don't specify -jN, I can see the image under out/target/product/sabresd_6dq/.
drwxrwxr-x  8 dean dean      4096 Mar 27 14:25 ./
drwxrwxr-x  3 dean dean      4096 Mar 27 10:15 ../
-rw-rw-r--     1 dean dean        14 Mar 27 14:25 android-info.txt
-rw-r--r--      1 dean dean   4263936 Mar 27 14:25 boot.img
-rw-rw-r--     1 dean dean     15908 Mar 27 10:44 clean_steps.mk
drwxrwxr-x  4 dean dean      4096 Mar 27 11:28 data/
-rw-rw-r--     1 dean dean     48870 Mar 27 14:25 installed-files.txt
-rwxr-xr-x  1 dean dean   4093120 Mar 27 10:56 kernel*
drwxrwxr-x 14 dean dean      4096 Mar 27 14:13 obj/
-rw-rw-r--  1 dean dean       353 Mar 27 10:44 previous_build_config.mk
-rw-rw-r--  1 dean dean    167791 Mar 27 14:25 ramdisk.img
-rw-rw-r--  1 dean dean    938487 Mar 27 14:25 ramdisk-recovery.img
drwxrwxr-x  3 dean dean      4096 Mar 27 14:25 recovery/
-rw-r--r--  1 dean dean   5036032 Mar 27 14:25 recovery.img
drwxrwxr-x  8 dean dean      4096 Mar 27 10:20 root/
drwxrwxr-x  5 dean dean      4096 Mar 27 14:10 symbols/
drwxrwxr-x 11 dean dean      4096 Mar 27 13:44 system/
-rw-r--r--  1 dean dean 293601280 Mar 27 14:25 system.img
-rwxr-xr-x  1 dean dean    455936 Mar 27 10:22 u-boot-6dl.bin*
-rwxr-xr-x  1 dean dean    456240 Mar 27 10:21 u-boot-6q.bin*
-rwxr-xr-x  1 dean dean    455936 Mar 27 10:22 u-boot.bin*
-rwxr-xr-x  1 dean dean   4093184 Mar 27 10:56 uImage*
-rw-r--r--  1 dean dean 134217728 Mar 27 14:25 userdata.img
