CUSTOM BAUD RATE FOR UART
3,561 次查看
anshulkhare
Hello All,
i am using IMX6UL Board as per my requirement I need a custom baud rate of 1.8Mbps on a serial port to talk to a device.
by default baud rate is coming as 115200 .
I understand that the UART clock speed is derived from a main clock that is used for CPU and other subsytem.  Where do I start looking to change the baud rate for the UART?
Anshul
标记 (3)
2,134 次查看
Hi Anshul
i.MX uart driver supports standard linux serial APIs, one can use for example stty :
serial port - How to set a custom baud rate on Linux? - Stack Overflow
iMX6: UART refuse to set baud rate to 1 Mbps
check dts file for uart clocking linux/arch/arm/boot/dts/imx6ul.dtsi
clocks = <&clks IMXUL_CLK_UART_SERIAL>; ..
described in Figure 18-3. Clock Tree - Part 2 i.MX6UL Reference Manual
http://www.nxp.com/docs/en/reference-manual/IMX6ULRM.pdf
