CPU1: failed to come online
11,318件の閲覧回数
Chenyi_Luo
I meet a problem during the imx8qxp processor start up, the CPU1,2,3 fail to come online.
I use the imx-yocto-L5.4.24_2.1.0 version.
Is the problem related to the configuration of scfw?
11,122件の閲覧回数
Dhruvit
Hi @Chenyi_Luo ,
BL32_BASE value can be calculated as below for i.MX8QXP:
BL32_BASE = DRAM_BASE - 0x02000000 + DDR_SIZE
For 1 GB DRAM BL32_BASE can be configured to 0xBE000000.
Please change the value of BL32_BASE and TEE_LOAD_ADDR to 0xBE000000.
Please make sure that you have updated the DDR configuration in SCFW using i.MX 8/8X Family DDR Tools.
Thanks & Regards,
Dhruvit Vasavada
6 返答(返信)
11,230件の閲覧回数
Dhruvit
Hi @Chenyi_Luo,
From the boot logs, it is found that you are using 1 GB DRAM.
1. Please make sure that you have followed the steps mentioned in 5.7 Adding OP-TEE support for a new board of i.MX Porting Guide and have set the correct value for CFG_DDR_SIZE.
2. Please consider the below change in /plat/imx/imx8qx/platform.mk in imx-atf  ( As existing value 0xfe000000 will overwrite 1 GB limit (0xC0000000))
      ifeq (${PLAT},imx8dx)
      BL32_BASE ?= 0x96000000
      else
     endif
3. Also make a similar change at /iMX8QX/soc.mak at imx-boot as below:
       ifeq ($(SOC),iMX8DX)
       TEE_LOAD_ADDR ?= 0x96000000
       else ifeq ($(SOC),iMX8QX)
       endif
Thanks & Regards,
Dhruvit.
11,225件の閲覧回数
Chenyi_Luo
Hello @Dhruvit ,
Yes, we are using 1GB DDR now.
According to your reply, I adjusted the configuration of the memory size:
1.imx-atf/plat/imx/imx8qx/platform.mk
else
endif
2.imx-mkimage/iMX8QX/soc.mak
endif
3.optee-os/core/arch/arm/plat-imx/conf.mk
 ifneq (,$(filter $(PLATFORM_FLAVOR),mx8qxpmek mx8qmmek))
 CFG_DDR_SIZE ?= 0x40000000
 CFG_UART_BASE ?= UART0_BASE
 endif
In addition, we also have some configuration about memory before:
4.uboot/include/configs/imx8qxp_mek.h
#ifdef CONFIG_TARGET_IMX8DX_MEK
#define PHYS_SDRAM_1_SIZE       0x40000000  /* 1 GB */
#define PHYS_SDRAM_2_SIZE       0x00000000  /* 0 GB */
#else
    #if 0
    #define PHYS_SDRAM_1_SIZE       0x80000000  /* 2 GB */
    /* LPDDR4 board total DDR is 3GB */
    #define PHYS_SDRAM_2_SIZE       0x40000000  /* 1 GB */
    #else
    /* total DDR is 1GB */
    #endif
#endif
The above four changes are all of our changes to the memory size.
If there is only the fourth change point, then CPU startup will be abnormal(CPU1: failed to come online).
But if all four change points take effect, the download will be abnormal.
It will stack at "SDPV: jump", as the 图片.png shows.
The uuu script is emmc.uuu.txt.
Why is this? Is it because we set it up incorrectly?
Thank you.
タグ(1)
11,123件の閲覧回数
Dhruvit
Hi @Chenyi_Luo ,
Thanks & Regards,
Dhruvit Vasavada
10,313件の閲覧回数
Chenyi_Luo
We change the size of memory to 0xBE000000.
Now CPU can start normally.
Thank you.
10,300件の閲覧回数
Dhruvit
Hi @Chenyi_Luo
Can I mark this case to close state?
Thanks & Regards
Dhruvit Vasavada
10,292件の閲覧回数
Chenyi_Luo
Sure.
Thank you.
