CHIP_SELECT and CHANNEL_SELECT
KeshavaGN
Hi all,
A doubt. Sorry if this seems to be silly..
While developing a device driver (SPI), i came across two terms (in codes from two different resources): CHIP_SELECT and CHANNEL_SELECT.
My question is, in general, there chip select and channel select both are same? or different? If different, please explain about channel select...
Thanks...
With regards,
Keshava G N
LinWang
LinWang
KeshavaGN
Thank you LinWang, for clarification...
KeshavaGN
