C++ - LWIP+FreeRTOS - Unable to create more threads
1,176 次查看
GanesanGuru
Hi fellas,
I've created a sample c++ project - with lwip+freeRTOS - for two threads. It works fine as shown below:
When I tried to add 3rd thread - the build was successful - yet the none of the threads are being scheduled.image.png
To be very specific, the 3rd task creation itself failed. Hence, I think scheduler is not even called. Why it happens so?
The threads are as follows,
void delay(){
    volatile static int i,j;
    for (i=0;i<10000;i++)
        for (j=0;j<10000;j++);
void ledOn(void){
	GPIO_WritePinOutput(GPIO1,9,0);
    PRINTF("LED turned on\r\n");
void ledOFF(void){
	GPIO_WritePinOutput(GPIO1,9,1);
    PRINTF("LED turned off\r\n");
static void BLINKY(void * arg){
while(1){
	ledOn();
	delay();
	ledOFF();
	delay();
	taskYIELD();
static void SERIALL(void * arg){
   while(1){
	PRINTF("inside Serial loop");
	delay();
    PRINTF(".");
	delay();
    PRINTF(".\r\n");
	taskYIELD();
static void testIoT(void * arg){
   while(1){
	PRINTF("inside iot loop");
	delay();
    PRINTF(".");
	delay();
    PRINTF(".\r\n");
	taskYIELD();
标记 (4)
1,131 次查看
Omar_Anguiano
Hello
I hope you are well.
Is the same issue present if you increase the stack size for the task? Which status is returning sys_thread_new()?
Omar
1,132 次查看
Omar_Anguiano
Hello
Omar
