Burning fuses
Burning fuses
1,953 次查看
yanz
what is a simplest and easiest way to burn fuses on Windows to the following configuration - "boot from fuses with external QSPI flash". Is any sample code/reference there (including burning application)?
1,950 次查看
jay_heng
If it is i.MX RT, you can try MCUBootUtility tool
https://github.com/NXPmicro/mcu-boot-utility
1,951 次查看
jay_heng
1,529 次查看
yanz
Thank you very much.
How can I burn fuses using your tool without connect to flashloader first (there are no SW6 related GPIOs on custom board)? Is it possible?
1,948 次查看
yanz
Thank you very much!
