what is a simplest and easiest way to burn fuses on Windows to the following configuration - "boot from fuses with external QSPI flash". Is any sample code/reference there (including burning application)?
解決済! 解決策の投稿を見る。
If it is i.MX RT, you can try MCUBootUtility tool
Thank you very much.
How can I burn fuses using your tool without connect to flashloader first (there are no SW6 related GPIOs on custom board)? Is it possible?
Thank you very much!
