Building u-boot on IMXAndroid BSP M6.0 failed (AUG REV: M6.0.1_1.0.0, 04/2016 Sec 31)
jke
I'm trying to follow the Android_User's_Guide Rev. M6.0.1_1.0.0, 04/2016 to make a build.
In Section 3.1 Where it instructs how to build u-boot, I found that there's no bootloader folder under ~/myandroid/bootable.
When looking into the ~/myandroid/.repo/manifest.xml , it seems there's only bootale/recovery but no bootable/bootloader .
Can someone suggest the proper steps to clone the u-boot git repository?
Thank you
deepika_t
Can you try repo sync once ?
