Building an image of "imx-yocto-L4.14.98-2.0.0_ga" got an error: cec-compliance.cpp: No such file or directory
yamazaki
Hello:
I'm trying to build an image of "imx-yocto-L4.14.98-2.0.0_ga" in ubuntu16.04.
I set up Yocto Project according to the User's Guide.
I build with the following settings:
$ DISTRO=fsl-imx-xwayland MACHINE=imx8mmevk source fsl-setup-release.sh -b build-xwayland
$ bitbake fsl-image-qt5-validation-imx
then started build, and got this error. Ill put the whole log now:
Loading cache: 100% |############################################| Time: 0:00:01
Loaded 3483 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
NOTE: Multiple providers are available for runtime ptpd (ptpd, ptpd-qoriq)
Consider defining a PREFERRED_RPROVIDER entry to match ptpd
NOTE: Multiple providers are available for runtime ptpd-dev (ptpd, ptpd-qoriq)
Consider defining a PREFERRED_RPROVIDER entry to match ptpd-dev
Build Configuration:
BB_VERSION = "1.38.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-16.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mmevk"
DISTRO = "fsl-imx-xwayland"
DISTRO_VERSION = "4.14-sumo"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
meta
meta-poky = "HEAD:c9bd4984f8f471ca2c43052714f4413ba99cf171"
meta-oe
meta-multimedia = "HEAD:8760facba1bceb299b3613b8955621ddaa3d4c3f"
meta-freescale = "HEAD:27ca94f8a4336790ba117b4298566f6820e7e74c"
meta-freescale-3rdparty = "HEAD:82037216280a39957fb4272581637abec734ad50"
meta-freescale-distro = "HEAD:f7e2216e93aff14ac32728a13637a48df436b7f4"
meta-bsp
meta-sdk = "HEAD:8eeb420fad668b733ab95b460895e1c337c66b25"
meta-browser = "HEAD:75640e14e325479c076b6272b646be7a239c18aa"
meta-gnome
meta-networking
meta-python
meta-filesystems = "HEAD:8760facba1bceb299b3613b8955621ddaa3d4c3f"
meta-qt5 = "HEAD:d4e7f73d04e8448d326b6f89908701e304e37d65"
Initialising tasks: 100% |#######################################| Time: 0:00:11
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: v4l-utils-1.12.3-r0 do_compile: oe_runmake failed
ERROR: v4l-utils-1.12.3-r0 do_compile: Function failed: do_compile (log file is located at /data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/temp/log.do_compile.15082)
ERROR: Logfile of failure stored in: /data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/temp/log.do_compile.15082
Log data follows:
| DEBUG: SITE files ['endian-little', 'bit-64', 'arm-common', 'arm-64', 'common-linux', 'common-glibc', 'aarch64-linux', 'common']
| DEBUG: Executing shell function do_compile
| NOTE: make -j 1
| make all-recursive
| make[1]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build'
| Making all in v4l-utils-po
| make[2]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/v4l-utils-po'
| make[2]: Nothing to be done for 'all'.
| make[2]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/v4l-utils-po'
| Making all in libdvbv5-po
| make[2]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/libdvbv5-po'
| make[2]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/libdvbv5-po'
| Making all in lib
| make[2]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib'
| Making all in libv4lconvert
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libv4lconvert'
| make[3]: Nothing to be done for 'all'.
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libv4lconvert'
| Making all in libv4l2
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libv4l2'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libv4l2'
| Making all in libv4l1
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libv4l1'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libv4l1'
| Making all in libv4l2rds
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libv4l2rds'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libv4l2rds'
| Making all in libv4l-mplane
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libv4l-mplane'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libv4l-mplane'
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libdvbv5'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib/libdvbv5'
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib'
| make[3]: Nothing to be done for 'all-am'.
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib'
| make[2]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/lib'
| Making all in utils
| make[2]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils'
| Making all in libv4l2util
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/libv4l2util'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/libv4l2util'
| Making all in libmedia_dev
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/libmedia_dev'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/libmedia_dev'
| Making all in decode_tm6000
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/decode_tm6000'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/decode_tm6000'
| Making all in ivtv-ctl
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/ivtv-ctl'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/ivtv-ctl'
| Making all in ir-ctl
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/ir-ctl'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/ir-ctl'
| Making all in cx18-ctl
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/cx18-ctl'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/cx18-ctl'
| Making all in keytable
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/keytable'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/keytable'
| Making all in media-ctl
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/media-ctl'
| make all-am
| make[4]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/media-ctl'
| make[4]: Nothing to be done for 'all-am'.
| make[4]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/media-ctl'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/media-ctl'
| Making all in v4l2-compliance
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/v4l2-compliance'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/v4l2-compliance'
| Making all in v4l2-ctl
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/v4l2-ctl'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/v4l2-ctl'
| Making all in v4l2-dbg
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/v4l2-dbg'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/v4l2-dbg'
| Making all in v4l2-sysfs-path
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/v4l2-sysfs-path'
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/v4l2-sysfs-path'
| Making all in cec-ctl
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/cec-ctl'
| aarch64-poky-linux-g++ --sysroot=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I../../../v4l-utils-1.12.3/utils/cec-ctl -I../.. -I../../../v4l-utils-1.12.3/lib/include -Wall -Wpointer-arith -D_GNU_SOURCE -I../../../v4l-utils-1.12.3/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0=/usr/src/debug/v4l-utils/1.12.3-r0 -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot= -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot-native= -fvisibility-inlines-hidden -c -o cec-ctl.o ../../../v4l-utils-1.12.3/utils/cec-ctl/cec-ctl.cpp
| ../../aarch64-poky-linux-libtool --tag=CXX --mode=link aarch64-poky-linux-g++ --sysroot=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0=/usr/src/debug/v4l-utils/1.12.3-r0 -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot= -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot-native= -fvisibility-inlines-hidden -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread -o cec-ctl cec-ctl.o
| aarch64-poky-linux-libtool: link: aarch64-poky-linux-g++ --sysroot=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0=/usr/src/debug/v4l-utils/1.12.3-r0 -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot= -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot-native= -fvisibility-inlines-hidden -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread -o cec-ctl cec-ctl.o -pthread
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/cec-ctl'
| Making all in cec-compliance
| make[3]: Entering directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/cec-compliance'
| ../../../v4l-utils-1.12.3/utils/cec-ctl/msg2ctl.pl 2 ../../../v4l-utils-1.12.3/include/linux/cec.h ../../../v4l-utils-1.12.3/include/linux/cec-funcs.h >cec-table.h
| aarch64-poky-linux-g++ --sysroot=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I../../../v4l-utils-1.12.3/utils/cec-compliance -I../.. -I../../../v4l-utils-1.12.3/lib/include -Wall -Wpointer-arith -D_GNU_SOURCE -I../../../v4l-utils-1.12.3/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0=/usr/src/debug/v4l-utils/1.12.3-r0 -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot= -fdebug-prefix-map=/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/recipe-sysroot-native= -fvisibility-inlines-hidden -c -o cec-compliance.o cec-compliance.cpp
| aarch64-poky-linux-g++: error: cec-compliance.cpp: No such file or directory
| aarch64-poky-linux-g++: fatal error: no input files
| compilation terminated.
| Makefile:560: recipe for target 'cec-compliance.o' failed
| make[3]: *** [cec-compliance.o] Error 1
| make[3]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils/cec-compliance'
| Makefile:468: recipe for target 'all-recursive' failed
| make[2]: *** [all-recursive] Error 1
| make[2]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build/utils'
| Makefile:574: recipe for target 'all-recursive' failed
| make[1]: *** [all-recursive] Error 1
| make[1]: Leaving directory '/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/build'
| ERROR: oe_runmake failed
| Makefile:501: recipe for target 'all' failed
| make: *** [all] Error 2
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/temp/log.do_compile.15082)
ERROR: Task (/data/imx-yocto-bsp/sources/meta-openembedded/meta-oe/recipes-multimedia/v4l2apps/v4l-utils_1.12.3.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2685 tasks of which 2684 didn't need to be rerun and 1 failed.
"cec-compliance.ccp" is existed in "/data/imx-yocto-bsp/build-xwayland/tmp/work/aarch64-mx8mm-poky-linux/v4l-utils/1.12.3-r0/v4l-utils-1.12.3/utils/cec-compliance".
Can you tell me what might be wrong?
Regards.-
jimmychan
I created the steps to build the BSP. You may try this: https://community.nxp.com/docs/DOC-343758
jimmychan
yamazaki
jimmychan-san,
Thank you for answer.
This error was resolved when the installation was performed according to the procedure taught and the rebuild was performed.
It seems that the following procedure was necessary.
$ sudo apt-get install libsdl1.2-dev xterm sed cvs subversion coreutils texi2html docbook-utils python-pysqlite2 help2man make gcc g++ desktop-file-utils libgl1-mesa-dev libglu1-mesa-dev mercurial autoconf automake groff curl lzop asciidoc u-boot-tools
I had the following statement in the document that I referred to, so I thought it was not necessary to do it for a Ubuntu 16.04.
i.MX layers host packages for a Ubuntu 12.04 or 14.04 host setup are:
$ sudo apt-get install libsdl1.2-dev xterm sed cvs subversion coreutils texi2html \
docbook-utils python-pysqlite2 help2man make gcc g++ desktop-file-utils \
i.MX layers host packages for a Ubuntu 14.04 host setup only are:
$ sudo apt-get install u-boot-tools
