Bug: kernel hang when lcd resolution larger than 800x600 and HAB is enabled
yunyangsihai
Dear all:
I trying to test the Secure Boot (HAB). And HAB is ok now.
iMX6UL + BSP4.1.15_1.0.0
1. But kernel will hang when lcd resolution is 1024x768 (larger than 800x600) and HAB is enabled.
2. kernel boot up sucessfully when lcd resolution is 800x600 (only resolution is changed) and HAB is enabled.
3. kernel always boot up successfully when HAB is not enabled.
Summary as follows:
LCD resolution HAB offHAB on
800*480okok
800*600okok
1024*768okfailed (kernel hang)
1280*800okfailed (kernel hang)
log file:
<HAB-enabled-1024x768-kernel-hang.txt> : HAB is enabled and lcd resolution is 1024x768, kernel will hang.
<HAB-enabled-800x600-kernel-ok.txt> : HAB is enabled and lcd resolution is 800x600, kernel boot up successfully.
Hi Yang
unfortunately L4.1.15 is not more supported as outdated, recommended to try with
latest linux and Code Signing Tool releases described on
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
https://www.nxp.com/design/software/embedded-software/i-mx-software:IMX-SW
yunyangsihai
1. This problem can also reproduced on latest Code Signing Tool releases cst-3.3.1
2. Upgrade to the latest Linux is so heavy work, it is impossible.
yunyangsihai
Thanks.
How can I know the Release Date and Support time of every BSP-version?
We will request support by sales.
release date is provided in Release Notes document included in each BSP package on below link,
support time is 1 year from release date.
yunyangsihai
dts file is "dh180_a6g2c-wifi-bt-128m.dts" ,as attached zip.
