I am currently working on a project to install and boot the Automotive Android OS that I got from NXP on a Toradex Apalis iMX8 board. I plan to use the Toradex Easy Installer (Tezi) for this process, and I would appreciate your guidance on the specific steps required to successfully boot the Android Automotive OS using Tezi.
Could you please provide any advice, documentation, or tips regarding:
1. The necessary files (e.g., bootloader, kernel, system image) required for the booting process.
2. Any configurations that need to be customized before booting.
3. Steps to start booting using Tezi.
Your help will be greatly appreciated.
Thank you in advance for your help!
Hello Hubanys,
If you prefer to use the UUU (Universal Update Utility) tool for booting Android Automotive OS on a Toradex Apalis iMX8 board, here’s a step-by-step guide:
Jaimin
Hello Jaimin
I'm planning to use toradex easy installer (TEZI), and I'd really appreciate your guidance on the specific steps needed to successfully boot. Are you able to help me?
what should I do?
We use UUU tool to flash images in our EVK boards.
I suggest you refer to Toradex to get the corresponding documentation for Toradex Easy Installer and bring-up process.
Best regards.
Can you give me a guide on how to flash android automotive using UUU tool?
and what images are used?
I suggest you take a look in our Android Automotive Quick Start Guide. In section 3.3 Flashing board images.
Best regards.
What files and directories are required to boot using UUU?
You need bootloader and root file system.
We use uuu_imx_android_flash.sh/bat to flash it.
Best regards.
do you know any other way for android automotive os to boot on toradex apalis i.mx8 other than using toradex easy installer?
Can you give me a guide on how to flash android automotive using UUU tools?
