Boot from SATA ISSUES
1,087 次查看
Chicago1984
I was able to blow the fuse and see that the boot device is now SATA, but now I’m getting a “Card
did not respond to voltage select!” and “MMC init failed” error.  I wonder if there is something in
the code that is still wanting to grab code from the SD card.
Is there an easy way to blow the fuse in the Manufacturing Tool?  I tried to set it up, but being new
to it I was getting no ware slowly.
Image attached.
834 次查看
tonyzheng
It seems that you board is not the official reference board powered by Freescale.
Can you tell me where your kernel and rootfs, in SATA or SD card?
As with SadreSD board, booting from the SATA is supported through changing u-boot configs.
834 次查看
tonyzheng
If your kernel and rootfs reside in the SATA SSD, you don't need to detect SD Card.
For more information, you can refer to:
https://community.freescale.com/message/318957#318957
