Boot custom board from NAND flash
604件の閲覧回数
maheshkumarkoda
Hello Community, Hello igorpadykov
1). Could you please let me know from which U-boot version & branch you took these attached files referred in below link?
Nand boot with u-boot 2013.04 on i.mx6 SOLO
Or,
could you attach imximage.cfg file also?
2). Can i directly integrate these files in U-boot version v2015.04+gitAUTOINC+5d9ffd2214-r0 in order to boot from NAND?
3). Does this nand configworks as nand driver to copy U-boot/(next stage bootloader) to NAND flash(i think which initializes iomux and clocks alone)
or
do we need mtd/nand driver from kernel?
NOTE: i don't want to call kernel image in next level, instead i want to load another BL.
Please put some light :smileyhappy:
Mahesh.
タグ(2)
335件の閲覧回数
Hi Mahesh
it is from
uboot-imx.git - Freescale i.MX u-boot Tree
one can try to integrate to other versions, however I believe it is already integrated to uboot-imx
http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/tree/?h=imx_v2015.04_4.1.15_1.0.0_ga
Note there may be differencies between uboot-imx (nxp uboot) and u-boot-fslc (community uboot),
general discussion about differencies can be found in
difference between Yocto Community BSP and Freescale BSP Release
335件の閲覧回数
maheshkumarkoda
Hi Igor,
Thanks for the source link.
Is uboot-imx (nxp uboot) a static - freescale official release BSP?
can I use this source as a reference to build image with cross toolchain locally, without yocto project?
Mahesh.
