Bitbake not working
Bitbake not working
6,615 次查看
VinithNama
      When i have build the complete booting process in Linux for imx8m mini EVK in the same build terminal the bitbake command works properly. when I have shutdown the Linux machine and I'm again turning on the PC at the time it throwing an exception bitbake command not found .
6,590 次查看
VinithNama
Thanks for your information,  it works for me
6 回复数
6,601 次查看
turker
You need to source environment setup scripts everytime you boot your PC or switch to another terminal.
标记 (1)
6,597 次查看
VinithNama
I doesn't have any idea about how to source can you help me how to source
6,593 次查看
turker
It is available in the README.
Run i.MX Linux Yocto Project Setup:
$: [MACHINE=<machine>] [DISTRO=fsl-imx-<backend>] source ./imx-setup-release.sh -b <build folder>
In my case I run:
MACHINE=imx8mmevk DISTRO=fsl-imx-xwayland source imx-setup-release.sh -b build/
6,591 次查看
VinithNama
6,610 次查看
Bio_TICFSL
Hello VinithNama,
If you have building and flashing correctly the MX8MM, then your problem is the host.
6,607 次查看
VinithNama
     Currently I'm using ubuntu 18.04 for building the image and i am able to flash through sd card .When I'm going to compile the device tree after rebooting the linux pc using  bitbake -c compile -f linux-imx it shows bitbake not found.
Thanks & Regards,
Vinith.
