Bitbake not working
Search instead for
Bitbake not working
VinithNama
      When i have build the complete booting process in Linux for imx8m mini EVK in the same build terminal the bitbake command works properly. when I have shutdown the Linux machine and I'm again turning on the PC at the time it throwing an exception bitbake command not found .
VinithNama
Thanks for your information,  it works for me
turker
You need to source environment setup scripts everytime you boot your PC or switch to another terminal.
VinithNama
I doesn't have any idea about how to source can you help me how to source
turker
It is available in the README.
Run i.MX Linux Yocto Project Setup:
$: [MACHINE=<machine>] [DISTRO=fsl-imx-<backend>] source ./imx-setup-release.sh -b <build folder>
In my case I run:
MACHINE=imx8mmevk DISTRO=fsl-imx-xwayland source imx-setup-release.sh -b build/
VinithNama
Bio_TICFSL
Hello VinithNama,
If you have building and flashing correctly the MX8MM, then your problem is the host.
VinithNama
     Currently I'm using ubuntu 18.04 for building the image and i am able to flash through sd card .When I'm going to compile the device tree after rebooting the linux pc using  bitbake -c compile -f linux-imx it shows bitbake not found.
Thanks & Regards,
Vinith.
