Android9 imx8mm is not support wm8942 codec?
1,763件の閲覧回数
13660284951
I configure dts to codec as below
wm8524: wm8524 { compatible = "wlf,wm8524";
clocks = <&clk IMX8MM_CLK_SAI3_ROOT>;
clock-names = "mclk";
wlf,mute-gpios = <&gpio5 21 GPIO_ACTIVE_LOW>; };
sound-wm8524 { compatible = "fsl,imx-audio-wm8524";
model = "wm8524-audio";
audio-cpu = <&sai3>;
audio-codec = <&wm8524>;
audio-routing = "Line Out Jack", "LINEVOUTL",
"Line Out Jack", "LINEVOUTR"; };
while the start kernel log show us snd_soc_register_card
[ 2.058694] imx-wm8524 sound-wm8524: ASoC: CODEC DAI wm8524-hifi not registered
[ 2.066018] imx-wm8524 sound-wm8524: snd_soc_register_card failed (-517)
4 返答(返信)
1,587件の閲覧回数
injaneer1
Did you solve this ?  I am have the same issue with a driver I wrote in Android 10.
1,618件の閲覧回数
Hi zhou
for i.MX8M Mini supported codec is WM8524 as described in Table 2. Features
attached Release Notes. For other codec ona can try to port it:
How to port new audio codec into Android.docx
Porting custom audio codec in Linux BSP
1,618件の閲覧回数
13660284951
thks igorpadykov
I was tryed? but it still register snd card fail,and while checked ths asoc platform,and I think code is ok。
Is there any imx8xxx chips on android9 can be referenced?
1,618件の閲覧回数
one can look at Alsa Chapter Linux Manual in Linux 5.4.3_1.0.0 Documentation
