Android Build issue for imx6qsabresd
862 次查看
bandarulavanya
Contributor V
Hi all,
I am trying to build android Lollipop -android_L5.1.1_2.1.0 for imx6qsabresd board my bootimage is built fine, But when i building system image i am getting the errors.
No private recovery resources for TARGET_DEVICE sabresd 6dq
Gyp action: content_content_gyp_content_common_target_generate_webkit_version (out/target/product/sabresd_6dq/obj/GYP/shared_intermediates/webkit_version.h)
target SharedLib: libwebviewchromium (out/target/product/sabresd_6dq/obj/SHARED_LIBRARIES/libwebviewchromium_intermediates/LINKED/libwebviewchromium.so)
collect2: error: ld terminated with signal 11 [Segmentation fault], core dumped
After that "libwebviewchromium.so" not found is coming and make failed.. If any one knows kindly help me.
Lavanya
标签 (3)
555 次查看
gusarambula
Hello Bandaru Lavanya,
These linker problems are usually related to a lack of RAM memory. It is recommended to have at least 16GB RAM. A SWAP may also be used to increase the available memory if more physical RAM cannot be accessed. You can find a way to do this on the following document:
https://community.nxp.com/docs/DOC-102403
You would basically complement your RAM with a SWAP file. For example, for a 10GB SWAP file:
$ sudo fallocate -l 10g /mnt/10GB.swap
$ sudo chmod 600 /mnt/10GB.swap
$ sudo mkswap /mnt/10GB.swap
$ sudo swapon /mnt/10GB.swap
I hope this helps!
556 次查看
gusarambula
I hope this helps!
555 次查看
bandarulavanya
Contributor V
Hi gusarambula,
Thank you for giving solution, it works for me.
Lavanya
