Dear NXP,
I am working on IMX8QM with Android 9. I got build error after with clean Android 9 build.
Build Steps,
source build/envsetup.sh
lunch mek_8q_car-userdebug
make clean
make -j6
OpenJDK 64-Bit Server VM warning: INFO: os::commit_memory(0x00000000d4400000, 132120576, 0) failed; error='Not enough space' (errno=12)
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (mmap) failed to map 132120576 bytes for committing reserved memory.
Thanks & Regards,
VinothS,
Solved! Go to Solution.
Build was done. once reboot the system
Thanks & Regards,
VinothS,
Thanks & Regards,
VinothS,
Hello VinothS,
The AOSP is supported by Google so I would suggest that you consult the Google Developer Forums.
It seems, however, that you need more RAM (or SWAP) memory for building Android. Please review the requirements from the Android Source repository:
https://source.android.com/setup/build/requirements
I hope this helps.
Thank you Gusarambula,
Thanks & Regards,
VinothS,
