Adding LVDS Bridge (sn65dsi84) to iMX8mm
I am trying to add the LVDS bridge snd65dsi84 to our custom board based on the iMX8mm processor. I am having difficulty finding the right information on how to configure the DTS files for both PWM and for 2 enable lines for the backlight, and where to make changes for the LVDS.
Chris
specific timings for used lcd can be added to dts as in above example:
&mipi_dsi { |
status = "okay"; |
panel@0 { |
reg = <0>; |
compatible = "tn,dsi2lvds-panel"; |
dsi,flags = <0x0007>; |
dsi,format = <0>; |
dsi,lanes = <4>; |
panel-width-mm = <153>; |
panel-height-mm = <90>; |
bus-flags = <1>; |
refresh-rate = <60>; |
rotate = <0>; |
/* horz-flip; */ |
/* vert-flip; */ |
display-timings { |
native-mode = <&timing0>; |
timing0: hj070na { |
clock-frequency = <51000000>; |
hactive = <1024>; |
vactive = <600>; |
hfront-porch = <120>; |
hsync-len = <100>; |
hback-porch = <90>; |
vfront-porch = <1>; |
vsync-len = <33>; |
vback-porch = <1>; |
hsync-active = <1>; |
vsync-active = <1>; |
one can check with lcd manufacturer what should be correct initialization for
used lcd and add it in driver.
Hi injaneer1
one can look at below example
technexion linux already includes driver
https://github.com/TechNexion-customization/linux-imx-tn/tree/tn-imx_4.14.98_2.0.0_ga-wip-mipi2lvds
drivers/gpu/drm/bridge/sn65dsi84-dsi2lvds.c
General description on linux video subsystem can be found in i.MX Linux Reference Manual
This is not actually an example. Just pointed me to a dts file. However, I have been able to find the settings in here and the included dts, I found a driver I think (no readme or anything can be found). I have managed to get the backlight working with this post.
We are running Android 10 not linux so really need a copy of the kernel-imx folder with these settings.
When I run our board I get this.
[ 1.371688] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.378324] [drm] No driver support for vblank timestamp query.
[ 1.384326] imx-drm soc@0:bus@32c00000:display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 1.394252] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 1.402541] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[ 1.410878] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -517
[ 1.418669] imx-drm soc@0:bus@32c00000:display-subsystem: failed to bind 32e10000.mipi_dsi (ops imx_sec_dsim_ops): -517
[ 1.429543] imx-drm soc@0:bus@32c00000:display-subsystem: master bind failed: -517
