Add FLEXCAN HW Filter in CAN driver
搜索替代
515 次查看
yogeshbsa89
I want to implement CAN HW filter in CAN driver.
As current can driver implementation is Network driver so can be accessed via socket.
So in this implementation CAN filter can be set at kernel level by using socket options.
I would like to use can Hw filter to reduce the load on CAN receive interrupt.
Since CAN is running at 1mbps. If load on CAN bus increases which increases the CAN interrupt rate in turn raise CPU load.
Please suggest which registers i need to change. if any patch is available for reference kindly share.
Yogesh
标签 (2)
标记 (1)
287 次查看
Jean-Philippe
Hi Igor,
I have the same request for iMX6ULL. I really need to enable hardware filtering to avoid to many irq and kernel filtering.
Could you send me the patch ?
Thank you !
Jean-Philippe
500 次查看
igorpadykov
Hi Yogesh
patch was sent you via mail.
457 次查看
thomas_mohnl
Hi Igor,
I have the same topic: need HW filter in flexcan driver.
Please provide me also with the patch.
Thomas
