Accessing OCOTP fuses in linux-fslc 4.1.7
次の代わりに検索
437件の閲覧回数
spacemanspiff
Hi all,
I need access to the OCOTP-fuses of i.MX6 from Linux. Read access is currently sufficient.
I see that read support is in the 4.4 and 4.6 branches of linux-fslc, but I had no success porting it to our 4.1.7 tree.
I also tried to include the fsl_otp driver from wandboard-linux (linux-imx-wandboard/fsl_otp.c at master · wolfgar/linux-imx-wandboard · GitHub ). Since we based our board on the wandboard, we originally had this enabled, but now it is not there when we need it.
Are there other options for reading the fuses from Linux?
Does anyone have a patch that applies on 4.1.7? Since we have a bunch of custom patches I would prefer to stick with 4.1.7 for now if possible.
Mikkel Holm Olsen
ラベル(4)
200件の閲覧回数
Hi Mikkel
4.1.7 tree is not supported on nxp linux releases, one can try
to post this on meta-fsl-arm mailing list, so that someone familiar with
wandboard could try to assist you.
https://lists.yoctoproject.org/listinfo/meta-freescale
