I would please like to verify the following,
We are going to use evaluation board (sabre x solo) which has both sd & qspi.
When we Linux boot from sd , do we have access to qspi partitions ?
I guess that if it is decalred in device tree , then linux can see both storage devices, but I am not sure about it, becuase I don't have the source code yet for the evaluation board.
Is it that sd is /dev/sdX , and qspi as /dev/mtdX ?
On starting working with the board we shall have more idea I'm sure, but as a prepearation, we just wanted to verify the above.
Thank you,
Ran
Solved! Go to Solution.
Hi Ran
it is /dev/mtd, some examples can be found in ucl2.xml from mfg tool.
Linux boot from sd , one has access to qspi partitions.
Hi Ran
