About the use of i. MX8MPlus USB
249件の閲覧回数
pengluo
The number of USB ports of imx8M plus is not enough. Can I divide a USB 3.0 port difference into a USB 2.0 and a USB 3.0 port difference for use? If so, can one be the host, the other the device, or the otg?
Do you have any good suggestions?
237件の閲覧回数
riteshmpatel
Hi @pengluo,
I hope you are doing well.
If I understood correctly, you are looking to divide one USB port into two ports. However, that doesn't seem to be feasible.
If more USB ports are desired, one can use the USB Hub chipset.
Thanks & Regards,
Ritesh M Patel
229件の閲覧回数
pengluo
I see. Thank you for your advice
