About Table 6-50 (Quad SPI configuration parameters) of i.MX 7 Dual Reference Manual
goto11
For the settings of Full Speed Phase Selection and Full Speed Delay Selection, is the value of QuadSPIx_SMPR [DDRSMP] updated in DDR mode?
How many QuadSPIx_SMPR [DDRSMP] do you support for each of the examples below?
Example 1
Full Speed Phase Selection: 0
Full Speed Delay Selection: 1
Example 2
Full Speed Phase Selection: 1
Full Speed Delay Selection: 0
best regards
Goto
nxf63675
Hi Goto,
The first question is yes.
And for the second question, it just supports two modes for each example.
Hope this helps you.
Israel H.
goto11
hello,
I haven't received an answer back, so I'll change the question.
Is the correspondence of the QSPI_SMPR [DDRSMP] register for Full Speed Phase Selection and Full Speed Delay Selection (Table 6-50 in the Reference Manual) in DDR mode as follows?
Full Speed Phase Selection | 0 | 1 | 0 | 1
________________________________________________________
Full Speed Delay Selection | 0 | 0 | 1 | 1
QSPI_SMPR [DDRSMP]    | 0 | 1 | 2 | 3
Goto
goto11
Please tell me the correspondence between Full Speed Phase Selection and Full Speed Delay Selection with QSPI_SMPR [DDRSMP].
As an example, please tell us about two cases.
What is QSPI_SMPR [DDRSMP] set when Full Speed Phase Selection is "1" and Full Speed Delay Selection is "0"?
What is QSPI_SMPR [DDRSMP] set when Full Speed Phase Selection is "1" and Full Speed Delay Selection"1"?
Goto
