About Imx28 Hab Mfgtool Error
496件の閲覧回数
bruce_chen
Acordding AN4555 Pdf file, I am create updater_ivt.sb and imx28_linux_ivt.sb files. use Mfgtool programming get like below error info:
Erasing 128 Kibyte @ 1ebe0000 -- 100 % complete
UTP: sending Success
UTP: received command 'send'
g_file_storage gadget: high speed config #1
UTP: received command '$ kobs-ng init $FILE'
UTP: sending Busy
UTP: executing "kobs-ng init $FILE"
Unable to find a matching key dictionary
ERROR: bootstream '/tmp/file.utp' is invalid
ROM Version 1
usage: kobs-ng [COMMAND] [ARGS]
Where [COMMAND] is one of:
  dump [-v] [KOBS] ........................ Verify/dump boot structures
    -v .................................... Verbose mode
  imgverify [-v] [KEY] <file> ............. Verify image validity
  init [-v] [KEY] [KOBS] <file> ........... Initialize boot structure &
                                            install bootstreams
    -n .................................... Dry run (don't commit to flash)
    -w .................................... Commit to flash
  update [-v] [KEY] [KOBS] [-0|1] <file> .. Update a single bootstream
    -0|1 .................................. Update specified bootstream #
  extract [-v] [KEY] [KOBS] [-0|1] <file> . Extract a bootstream from flash
    -0|1 .................................. Extract specified bootstream #
  [KOBS] boot structures config options
    --chip_0_device_path=<path> .......... Device of boot (default /dev/mtd0)
    --chip_1_device_path=<path> .......... The second chip in case of multichip NAND
    --search_exponent=<value> ............ NCB field (default 2)
    --data_setup_time=<value> ............ NCB field (default 80)
    --data_hold_time=<value> ............. NCB field (default 60)
    --address_setup_time=<value> ......... NCB field (default 25)
    --data_sample_time=<value> ........... NCB field (default 6)
    --row_address_size=<value> ........... NCB field (default 3)
    --column_address_size=<value> ........ NCB field (default 2)
    --read_command_code1=<value> ......... NCB field (default 0x00)
    --read_command_code2=<value> ......... NCB field (default 0x30)
    --boot_stream_major_version=<value> .. NCB field (default 1)
    --boot_stream_minor_version=<value> .. NCB field (default 0)
    --boot_stream_sub_version=<value> .... NCB field (default 0)
    --ncb_version=<value> ................ NCB field (default 3)
   [KEY] key management related options
        -d ............................... Use device key (OTP) (not yet supported)
        -z ............................... Use key of all zeroes (default)
        -k<hexadecimalkey> ............... Use hex key of 16 bytes
UTP: sending Non-success
utp_poll: exit with status 1280
The meaning the kobs-ng command error,  because the imx28_ivt_linux.sb file use like below command create it:
     elftosb -k customkey.txt -f imx28 -c  ./linux_ivt_kone.bd -o imx28_ivt_kone_linux.sb
so I am modify the Mfgtool UCL.xml file of kobs-ng command link below:
     <CMD type="push" body="$ kobs-ng -k A8CFA04D9FAD6972B2E74C371701EED7 init $FILE">Flashing firmware</CMD>
     add -k option for kobs-ng, re-programming and get like below error info:
UTP: executing "kobs-ng init -k A8CFA04D9FAD6972B2E74C371701EED7 $FILE"
Illegal key ''
I am check the kobs-ng source code need a 16 byte of key, but I don't know where is to find the key?
thnaks.
307件の閲覧回数
Hi bruce
please refer to AN4555 sect.6.3.3 KEYGEN and KEYGEN.EXE
Keygen is used to create random encryption keys called as input OTP keys..
On Windows (Keygen.exe), cryptographically secure RNG APIs in the OS are
used to generate the random key.
On Linux (Keygen), /dev/random is used to generate the random key.
307件の閲覧回数
bruce_chen
Hi igor:
     Yeah, I know use Keygen to create keys, the command
      The customkey.txt file is use keygen tool create it, and use otp_burner.py create OtpInit.sb file, use  BitInit.exe burn the OtpInit.sb
      The A8CFA04D9FAD6972B2E74C371701EED7  same is customkey.txt file key. but why the kobs-ng return Illegal key?
