Hello Community
About pin config of i.mx6, I have two questions.
Q1:
Only pad that used for input can have pull-up resistor, pad that used for output cannot have pull-up resister.
Is it right? why?
Q2:
For Pad Control Register(e.g. IOMUXC_SW_PAD_CTL_PAD_CSI0_DATA18),what does Keeper Enabled mean?
What is Keeper?
ZongbiaoLiao
已解决! 转到解答。
the following app note helps to setup pin’s electrical properties.
“Influence of Pin Setting on System Function and Performance”
http://www.nxp.com/files/32bit/doc/app_note/AN5078.pdf
Yuri.
Yuri.
Hi ZongbiaoLiao
1. output also can be configured with pull-up resister
2. keeper functionality is explained on
Bus-holder - Wikipedia, the free encyclopedia
