ASRC driver for i.MX6 Quad/DualLite
Search instead for
youngOne
Hello
Following this manual for asrc: https://community.nxp.com/t5/i-MX-Processors/Dose-imx6-yocto-BSP-including-fsl-alsa-plugin/m-p/81587... .
Using linux-imx-4.14.98 from https://source.codeaurora.org/external/imx/linux-imx/tree/drivers/mxc?h=imx_4.14.98_2.0.0_ga
However, as suggested in manual, none of the branches in above link have asrc driver in drivers/mxc/asrc. So is the repository/branch being used is correct?
Problem faced is that ASRC device is not recognized, despite fsl_asrc module being loaded.
Need some suggestions for above.
Thanks!
youngOne
Hello @igorpadykov
Thanks for your reply. As per Sec 7.2.2.5 in the i.MX reference manual
Compatible list, must contain "fsl,imx6q-asrc".
However as observed here in the driver file, it mentions like below:
static const struct of_device_id fsl_asrc_ids[] = {
	{ .compatible = "fsl,imx35-asrc", },
	{ .compatible = "fsl,imx53-asrc", },
	{ .compatible = "fsl,imx8qm-asrc0", },
	{ .compatible = "fsl,imx8qm-asrc1", },
Can this be reason of device not recognized?
Could you please confirm if the referred manual is correct version?
What further could be checked?
Thanks!
YoungOne
igorpadykov
