ADV7180 probing issue
Search instead for
purvi_billore1
Working on i.Mx6q based custom board. The kernel log shows following,
V4L2 device 'Mxc Camera' on IPU1_CSI0 registered as video0
ERROR: v4l2 capture: slave not found!
The ADV180 decoder worked when /unit_test/mxc_v4l2_tvin.out  run through command line. The video displayed on the screen. When simple opencv application of capturing video run, shows following error.
Thanks and Regards,
Purvi Billore
Hi Purvi
if ADV180 decoder worked  fine with v4l2_tvin.out probably
there are problems with image, one can try to rebuild all from scratch
including opencv application.
